Opinions on these SMART Extended tests? Worth reusing?
thirdgen89gta
I recently had a SATA cable go bad, but it kicked off a Pending sector relocation count on one of the drives. Being that they were about 3.5 years old I decided it was time to move to a new drive array.
After I migrated all data to the new array I decided to do extended SMART test on all the old 4TB drives.
What do you think of these old disks? Worth keeping around in a non-important array or ditch them? I'm happily sitting on a new 32TB WD RED array, so I've done a extended DOD 3 pass wipe on them, then ran SMART long tests on all of them. So now they are scrubbed clean and ready for re-use if I decide too.
However, two of the drives report RAW_READ_ERROR_RATE values of non-zero while the rest are at Zero. They have between 29,xxx and 31,xxx hours on all drives. So even without errors its getting near time to move off them.
smartctl 6.5 2016-05-07 r4318 [x86_64-linux-4.12.9-pmagic64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:	 Western Digital Green
Device Model:	 WDC WD40EZRX-00SPEB0
Serial Number:	WD-WCC4E0843937
LU WWN Device Id: 5 0014ee 2b461980a
Firmware Version: 80.00A80
User Capacity:	4,000,787,030,016 bytes [4.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	5400 rpm
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Tue Oct  3 22:21:26 2017 AKDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82)	Offline data collection activity
					was completed without error.
Self-test execution status:	  (   0)	The previous self-test routine completed
					been run.
data collection:		 (52860) seconds.
capabilities:			 (0x7b) SMART execute Offline immediate.
					command.
					Self-test supported.
SMART capabilities:			(0x0003)	Saves SMART data before entering
					power-saving mode.
Error logging capability:		(0x01)	Error logging supported.
Short self-test routine
recommended polling time:	 (   2) minutes.
Extended self-test routine
recommended polling time:	 ( 529) minutes.
Conveyance self-test routine
recommended polling time:	 (   5) minutes.
SCT capabilities:			(0x7035)	SCT Status supported.
					SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   97
  3 Spin_Up_Time			0x0027   196   178   021	Pre-fail  Always	   -	   7200
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   989
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x002e   200   200   000	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   058   058   000	Old_age   Always	   -	   30757
10 Spin_Retry_Count		0x0032   100   100   000	Old_age   Always	   -	   0
11 Calibration_Retry_Count 0x0032   100   100   000	Old_age   Always	   -	   0
12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   149
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   78
193 Load_Cycle_Count		0x0032   153   153   000	Old_age   Always	   -	   143038
194 Temperature_Celsius	 0x0022   105   104   000	Old_age   Always	   -	   47
196 Reallocated_Event_Count 0x0032   200   200   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0030   200   200   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   0
200 Multi_Zone_Error_Rate   0x0008   200   200   000	Old_age   Offline	  -	   0
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline	Completed without error	   00%	 30757		 -
# 2  Extended offline	Completed without error	   00%	 30593		 -
# 3  Extended offline	Completed without error	   00%	  8706		 -
# 4  Short offline	   Completed without error	   00%	  5440		 -
# 5  Short offline	   Completed without error	   00%	  5368		 -
# 6  Short offline	   Completed without error	   00%	  5320		 -
# 7  Short offline	   Completed without error	   00%	  5272		 -
# 8  Short offline	   Completed without error	   00%	  5200		 -
# 9  Short offline	   Completed without error	   00%	  5152		 -
#10  Short offline	   Completed without error	   00%	  5105		 -
#11  Short offline	   Completed without error	   00%	  5040		 -
#12  Short offline	   Completed without error	   00%	  4992		 -
#13  Short offline	   Completed without error	   00%	  4944		 -
#14  Short offline	   Completed without error	   00%	  4872		 -
#15  Short offline	   Completed without error	   00%	  4824		 -
#16  Short offline	   Completed without error	   00%	  4776		 -
#17  Short offline	   Completed without error	   00%	  4704		 -
#18  Short offline	   Completed without error	   00%	  4656		 -
#19  Short offline	   Completed without error	   00%	  4608		 -
#20  Short offline	   Completed without error	   00%	  4536		 -
#21  Short offline	   Completed without error	   00%	  4492		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
Serial Number:	WD-WCC4E0968013
LU WWN Device Id: 5 0014ee 2b473f399
Local Time is:	Tue Oct  3 22:38:40 2017 AKDT
					been run.
data collection:		 (53940) seconds.
					command.
					power-saving mode.
recommended polling time:	 ( 539) minutes.
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   520
  3 Spin_Up_Time			0x0027   195   179   021	Pre-fail  Always	   -	   7208
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   119
  9 Power_On_Hours		  0x0032   060   060   000	Old_age   Always	   -	   29680
12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   119
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   72
193 Load_Cycle_Count		0x0032   168   168   000	Old_age   Always	   -	   98049
194 Temperature_Celsius	 0x0022   094   092   000	Old_age   Always	   -	   58
No Errors Logged
# 1  Extended offline	Completed without error	   00%	 29680		 -
# 2  Short offline	   Completed without error	   00%	 29504		 -
# 3  Extended offline	Completed without error	   00%	 29498		 -
# 4  Extended offline	Completed without error	   00%	  7629		 -
# 5  Short offline	   Completed without error	   00%	  4362		 -
# 6  Short offline	   Completed without error	   00%	  4291		 -
# 7  Short offline	   Completed without error	   00%	  4243		 -
# 8  Short offline	   Completed without error	   00%	  4195		 -
# 9  Short offline	   Completed without error	   00%	  4123		 -
#10  Short offline	   Completed without error	   00%	  4075		 -
#11  Short offline	   Completed without error	   00%	  4027		 -
#12  Short offline	   Completed without error	   00%	  3962		 -
#13  Short offline	   Completed without error	   00%	  3914		 -
#14  Short offline	   Completed without error	   00%	  3866		 -
#15  Short offline	   Completed without error	   00%	  3794		 -
#16  Short offline	   Completed without error	   00%	  3746		 -
#17  Short offline	   Completed without error	   00%	  3698		 -
#18  Short offline	   Completed without error	   00%	  3626		 -
#19  Short offline	   Completed without error	   00%	  3578		 -
#20  Short offline	   Completed without error	   00%	  3530		 -
#21  Short offline	   Completed without error	   00%	  3459		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
Serial Number:	WD-WCC4E0986840
LU WWN Device Id: 5 0014ee 25f1e4901
Local Time is:	Tue Oct  3 22:34:23 2017 AKDT
					been run.
data collection:		 (53520) seconds.
					command.
					power-saving mode.
recommended polling time:	 ( 535) minutes.
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   0
  3 Spin_Up_Time			0x0027   191   175   021	Pre-fail  Always	   -	   7408
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   118
12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   118
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   71
193 Load_Cycle_Count		0x0032   168   168   000	Old_age   Always	   -	   98532
194 Temperature_Celsius	 0x0022   092   092   000	Old_age   Always	   -	   60
No Errors Logged
# 2  Extended offline	Completed without error	   00%	 29516		 -
# 3  Extended offline	Completed without error	   00%	 21732		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
Serial Number:	WD-WCC4E0991455
LU WWN Device Id: 5 0014ee 2b473c0bb
Local Time is:	Tue Oct  3 22:43:41 2017 AKDT
					been run.
data collection:		 (54300) seconds.
					command.
					power-saving mode.
recommended polling time:	 ( 543) minutes.
  3 Spin_Up_Time			0x0027   192   174   021	Pre-fail  Always	   -	   7391
193 Load_Cycle_Count		0x0032   168   168   000	Old_age   Always	   -	   98339
194 Temperature_Celsius	 0x0022   095   095   000	Old_age   Always	   -	   57
No Errors Logged
# 3  Extended offline	Completed without error	   00%	 22038		 -
# 4  Extended offline	Interrupted (host reset)	  90%	 21997		 -
# 5  Extended offline	Completed without error	   00%	  7629		 -
# 6  Extended offline	Interrupted (host reset)	  60%	  7618		 -
# 7  Short offline	   Completed without error	   00%	  7615		 -
# 8  Extended offline	Interrupted (host reset)	  90%	  7614		 -
# 9  Extended offline	Interrupted (host reset)	  90%	  7091		 -
#10  Short offline	   Completed without error	   00%	  7091		 -
#11  Short offline	   Completed without error	   00%	  5914		 -
#12  Short offline	   Completed without error	   00%	  4362		 -
#13  Short offline	   Completed without error	   00%	  4291		 -
#14  Short offline	   Completed without error	   00%	  4243		 -
#15  Short offline	   Completed without error	   00%	  4195		 -
#16  Short offline	   Completed without error	   00%	  4123		 -
#17  Short offline	   Completed without error	   00%	  4075		 -
#18  Short offline	   Completed without error	   00%	  4027		 -
#19  Short offline	   Completed without error	   00%	  3962		 -
#20  Short offline	   Completed without error	   00%	  3914		 -
#21  Short offline	   Completed without error	   00%	  3866		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
Serial Number:	WD-WCC4E0856115
LU WWN Device Id: 5 0014ee 2b461a924
Local Time is:	Tue Oct  3 22:42:40 2017 AKDT
					been run.
data collection:		 (54240) seconds.
					command.
					power-saving mode.
recommended polling time:	 ( 542) minutes.
  3 Spin_Up_Time			0x0027   193   176   021	Pre-fail  Always	   -	   7333
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   991
  9 Power_On_Hours		  0x0032   058   058   000	Old_age   Always	   -	   30784
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   74
193 Load_Cycle_Count		0x0032   153   153   000	Old_age   Always	   -	   143880
No Errors Logged
# 1  Extended offline	Completed without error	   00%	 30784		 -
# 2  Extended offline	Completed without error	   00%	 30620		 -
# 3  Extended offline	Completed without error	   00%	  8733		 -
# 4  Short offline	   Completed without error	   00%	  5466		 -
# 5  Short offline	   Completed without error	   00%	  5395		 -
# 6  Short offline	   Completed without error	   00%	  5347		 -
# 7  Short offline	   Completed without error	   00%	  5299		 -
# 8  Short offline	   Completed without error	   00%	  5227		 -
# 9  Short offline	   Completed without error	   00%	  5179		 -
#10  Short offline	   Completed without error	   00%	  5131		 -
#11  Short offline	   Completed without error	   00%	  5066		 -
#12  Short offline	   Completed without error	   00%	  5018		 -
#13  Short offline	   Completed without error	   00%	  4970		 -
#14  Short offline	   Completed without error	   00%	  4898		 -
#15  Short offline	   Completed without error	   00%	  4850		 -
#16  Short offline	   Completed without error	   00%	  4802		 -
#17  Short offline	   Completed without error	   00%	  4730		 -
#18  Short offline	   Completed without error	   00%	  4682		 -
#19  Short offline	   Completed without error	   00%	  4635		 -
#20  Short offline	   Completed without error	   00%	  4563		 -
#21  Short offline	   Completed without error	   00%	  4518		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
The raw read error rate number is close to meaningless to the user, other than more is bad. It's weakly correlated with more serious indicators of issues, like multi-zone errors or bad sectors.
Chris Moore
Definitely send them to me, you don't want them anymore.
Chris Moore
PS. Seriously, you should run a SMART long on a regular basis. That is what allows you to catch drive faults before they can become significant enough to damage your data. I run a short test daily and a long test weekly on every drive in every array I manage at the place I work.
thirdgen89gta
Yeah, I read a bit about how the UD1 isn't very useful or meaningful. But with 29,000+ hours on a Green drive, even with WDIDLE is not sure. The Load Cycle count is high on two of them because they sat in Raid1 without being WDIDLEd in my old MacPro.
Ahh, there are a few people inline in front of you. :)
thirdgen89gta
I thought I had it setup correctly in FreeNAS, but guess I didn't because the logs don't show enough long tests.
Since nobody else has mentioned it, those drives are all too hot, and all but the first and last are way too hot. Not good for lifespan.
Inxsible
I did a double take on the temperature too. My 7200RPM Ironwolfs occasionally hit 40/41 Celcius and I am worried about them and thinking of ways to further cool them. 47 - 58 C would drive me nuts.
thirdgen89gta
The case I had to stick them in kind of sucks. No fans. It was the only case I had to fit them in.
The case they normally sit in have fans specifically for the drives.
