chrisbarnes1981
- Feb 1, 2016
Hi
New to the whole Freenas game however been reading from the shadows for a while and taken some pointers towards designing a build. i was wondering if you could all tell me what your opinions are of the following build which has been designed through the cyberpower website. I am using that site so that i can get it on a finance deal as i cant pull it all out in cash in one
have i missed anything?
Do you think this case is the right size or would it be better inside a mini case?
Sorry if this all seems a bit noob but im reaching out to you guys who know your stuff to help me! :)
- Cooler Master N300 Mid-Tower Gaming Case w/USB3
- MSI Z170-A Krait Gaming INTEL Z170 Chipset, ATX Mainboard w/ 4 RAM slots, USB 3.1, 3 PCIe x16, 3 PCIe x1, 1 SATA Express, 4 SATA3, 1 Ultra M.2
- INTEL® Core™ i3-6320 Dual Core 3.90 GHz 4MB Cache LGA1151 + HD Graphics
- Maximum Airflow with 3 x 120mm Silent Case Cooling Fans in selected case key areas for ultra silent operation - AKASA Silent Fans1,200 RPM with Sleeve Ball Bearing 17 dBA and LED light to match the Fans already in the case
- Cyberpower Sound Absorbing Foam -- reducing audible noise transmitted through solid case panels by up to 75%
- Cyberpower Anti-Vibration Fan Mounts -- reducing the noise transmitted from Fans
- Cyberpower Power Supply Gasket -- reducing the noice transmitted from Power Supply
- Be Quiet Dark Rock 3 CPU Fan with 6 x Direct Contact heat-pipes
- 60 GB(ish) SSD to run the OS from
- 2 x WD Red 3TB 3.5" SATA NAS Hard Drives
- 2 x 8gb ECC Ram
- Integrated onboard Graphics and audio cards
- Cooler Master 500 Watts B500 B2 Gaming Power Supply, 80+
