One or more devices has experienced an unrecoverable error. An attempt was made to correct...
EvanVanVan
I just mistakenly opened up one of the freenas.local emails that are normally clear (and that I normal don't read), and saw the following:
Checking status of zfs pools:
NAME SIZE ALLOC FREE EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
freenas-boot 7.19G 1.92G 5.27G - - 26% 1.00x ONLINE -
volume1 21.8T 9.95T 11.8T - 6% 45% 1.00x ONLINE /mnt
pool: volume1
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: http://illumos.org/msg/ZFS-8000-9P
scan: resilvered 8K in 0h0m with 0 errors on Thu Dec 3 21:08:41 2015
NAME STATE READ WRITE CKSUM
volume1 ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/2a0e67aa-b790-11e3-b9da-002590d65107.eli ONLINE 0 0 0
gptid/2a82eeea-b790-11e3-b9da-002590d65107.eli ONLINE 0 0 0
gptid/2afb7434-b790-11e3-b9da-002590d65107.eli ONLINE 0 0 0
gptid/2b79a9e5-b790-11e3-b9da-002590d65107.eli ONLINE 0 0 0
gptid/2bf1472f-b790-11e3-b9da-002590d65107.eli ONLINE 0 0 0
gptid/2c67faef-b790-11e3-b9da-002590d65107.eli ONLINE 0 1 0
gptid/2cedc0a0-b790-11e3-b9da-002590d65107.eli ONLINE 0 0 0
gptid/2d7a9191-b790-11e3-b9da-002590d65107.eli ONLINE 0 0 0
errors: No known data errors
-- End of daily output --
It appears I started getting these emails on a daily basis (rather than weekly(?)) on Dec 3rd. The logs from that date show the following:
Dec 3 21:08:35 freenas (da4:mps0:0:4:0): WRITE(10). CDB: 2a 00 bf f7 b7 68 00 00 08 00 length 4096 SMID 818 terminated ioc 804b scsi 0 state 0 xfer 0
Dec 3 21:08:35 freenas (da4:mps0:0:4:0): WRITE(10). CDB: 2a 00 bf f7 b8 d0 00 00 08 00
Dec 3 21:08:35 freenas (da4:mps0:0:4:0): CAM status: SCSI Status Error
Dec 3 21:08:35 freenas (da4:mps0:0:4:0): SCSI status: Check Condition
Dec 3 21:08:35 freenas (da4:mps0:0:4:0): SCSI sense: ILLEGAL REQUEST asc:21,0 (Logical block address out of range)
Dec 3 21:08:35 freenas (da4:mps0:0:4:0): Info: 0xbff7b8d0
Dec 3 21:08:35 freenas (da4:mps0:0:4:0): Error 22, Unretryable error
Dec 3 21:08:36 freenas GEOM_ELI: Crypto WRITE request failed (error=22). gptid/2c67faef-b790-11e3-b9da-002590d65107.eli[WRITE(offset=1646842126336, length=4096)]
Dec 3 21:08:42 freenas freenas[3356]: Traceback (most recent call last):
Dec 3 21:08:42 freenas freenas[3356]: File "/usr/local/www/freenasUI/common/system.py", line 184, in send_mail
Dec 3 21:08:42 freenas freenas[3356]: local_hostname=local_hostname)
Dec 3 21:08:42 freenas freenas[3356]: File "/usr/local/lib/python2.7/smtplib.py", line 781, in __init__
Dec 3 21:08:42 freenas freenas[3356]: SMTP.__init__(self, host, port, local_hostname, timeout)
Dec 3 21:08:42 freenas freenas[3356]: File "/usr/local/lib/python2.7/smtplib.py", line 251, in __init__
Dec 3 21:08:42 freenas freenas[3356]: (code, msg) = self.connect(host, port)
Dec 3 21:08:42 freenas freenas[3356]: File "/usr/local/lib/python2.7/smtplib.py", line 311, in connect
Dec 3 21:08:42 freenas freenas[3356]: self.sock = self._get_socket(host, port, self.timeout)
Dec 3 21:08:42 freenas freenas[3356]: File "/usr/local/lib/python2.7/smtplib.py", line 787, in _get_socket
Dec 3 21:08:42 freenas freenas[3356]: new_socket = ssl.wrap_socket(new_socket, self.keyfile, self.certfile)
Dec 3 21:08:42 freenas freenas[3356]: File "/usr/local/lib/python2.7/ssl.py", line 392, in wrap_socket
Dec 3 21:08:42 freenas freenas[3356]: ciphers=ciphers)
Dec 3 21:08:42 freenas freenas[3356]: File "/usr/local/lib/python2.7/ssl.py", line 148, in __init__
Dec 3 21:08:42 freenas freenas[3356]: self.do_handshake()
Dec 3 21:08:42 freenas freenas[3356]: File "/usr/local/lib/python2.7/ssl.py", line 310, in do_handshake
Dec 3 21:08:42 freenas freenas[3356]: self._sslobj.do_handshake()
Dec 3 21:08:42 freenas freenas[3356]: SSLError: [Errno 1] _ssl.c:510: error:140943FC:SSL routines:SSL3_READ_BYTES:sslv3 alert bad record mac
Does anyone have any ideas what the problem is? I run plex in a jail, and my first instinct is to update python, but I don't know if I should clear the error or not after.
I do monthly scrubs. The last one happened pm Nov. 29.
Thanks
SweetAndLow
Sweet'NASty
You have something going wrong with your hardware. Maybe a bad disk or maybe a loose cable. Can you post smart data for your disks and check your cable? All other hardware information is also required when making a forum post.
EvanVanVan
Yeah, I'll run a smart test on the drive. As for the other hardware information, it's all included in my sig (and up to date), sorry for not clarifying that.
SweetAndLow
Sweet'NASty
It needs to be in the forum post, signatures don't show up for people when using mobile clients. Smart tests should be running weekly so if you don't have that setup you should configure it.
EvanVanVan
Please, all my smart tests/scrubs/cron jobs/whatever have been set up from day 1 in accordance with CyberJock's guide.
Thanks for the help :]
gpsguy
Active Member
Posting the OP's hardware data, so folks on mobile devices can see it.
SUPERMICRO MBD-X9SCL-F-O Intel Xeon E3 Server
Intel Xeon E3-1230 V2
Kingston Technology ValueRAM 32GB DDR3 1600MHz PC3 12800 ECC
WD RED (8x) 3GB
IBM ServeRAID M1015 (crossflashed into IT Mode) (All eight of my HDs are plugged into it)
FreeNAS 9.3-STABLE
EvanVanVan
I double checked the results of the latest automatic S.M.A.R.T. tests and they completed without error, I ended up rebooting my server for another reason and the error/alert had cleared when it booted back up. I'll keep an eye on it going forward to see if it returns.
It was 1 error a month ago, searching I saw someone's post with "1.13M" errors. That sounds much more serious than my case at this point.
Bidule0hm
Server Electronics Sorcerer
A test can complete without error but the drive be bad enough to cause problems like that. Please post the output of smartctl -a /dev/yourdrive between codes tags.
EvanVanVan
Done, thank you. Hid them in spoiler tags to to keep the size down. At first I was only going to post da5 since it looks like it was the 6th of the 8 drives that had the error, but I then posted the rest for reference.
/dev/da0:
[root@freenas] ~# smartctl -a /dev/da0
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p13 amd64] (local build)
Model Family:     Western Digital Red
Device Model:     WDC WD30EFRX-68EUZN0
Serial Number:    WD------------------------
LU WWN Device Id: 5 0014ee 003b5ac0d
Firmware Version: 80.00A80
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Dec 18 08:12:27 2015 EST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (40500) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 406) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x703d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   183   175   021    Pre-fail  Always       -       5850
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       58
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   080   080   000    Old_age   Always       -       15058
10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       58
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       57
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       19
194 Temperature_Celsius     0x0022   123   114   000    Old_age   Always       -       27
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%     15027         -
# 2  Short offline       Completed without error       00%     14979         -
# 3  Short offline       Completed without error       00%     14931         -
# 4  Short offline       Completed without error       00%     14883         -
# 5  Short offline       Completed without error       00%     14835         -
# 6  Extended offline    Completed without error       00%     14820         -
# 7  Short offline       Completed without error       00%     14787         -
# 8  Short offline       Completed without error       00%     14739         -
# 9  Short offline       Completed without error       00%     14691         -
#10  Short offline       Completed without error       00%     14643         -
#11  Short offline       Completed without error       00%     14600         -
#12  Short offline       Completed without error       00%     14547         -
#13  Short offline       Completed without error       00%     14499         -
#14  Short offline       Completed without error       00%     14451         -
#15  Extended offline    Completed without error       00%     14436         -
#16  Short offline       Completed without error       00%     14403         -
#17  Short offline       Completed without error       00%     14355         -
#18  Short offline       Completed without error       00%     14307         -
#19  Short offline       Completed without error       00%     14259         -
#20  Short offline       Completed without error       00%     14211         -
#21  Short offline       Completed without error       00%     14163         -
/dev/da1:
[root@freenas] ~# smartctl -a /dev/da1
LU WWN Device Id: 5 0014ee 2b447e295
Local Time is:    Fri Dec 18 08:13:10 2015 EST
                                        was never started.
                                        been run.
data collection:                (42780) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 429) minutes.
  3 Spin_Up_Time            0x0027   183   176   021    Pre-fail  Always       -       5825
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       59
  9 Power_On_Hours          0x0032   080   080   000    Old_age   Always       -       15051
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       59
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       58
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       14
194 Temperature_Celsius     0x0022   121   110   000    Old_age   Always       -       29
No Errors Logged
# 1  Short offline       Completed without error       00%     15020         -
# 2  Short offline       Completed without error       00%     14972         -
# 3  Short offline       Completed without error       00%     14924         -
# 4  Short offline       Completed without error       00%     14876         -
# 5  Short offline       Completed without error       00%     14828         -
# 6  Extended offline    Completed without error       00%     14813         -
# 7  Short offline       Completed without error       00%     14780         -
# 8  Short offline       Completed without error       00%     14732         -
# 9  Short offline       Completed without error       00%     14684         -
#10  Short offline       Completed without error       00%     14636         -
#11  Short offline       Completed without error       00%     14595         -
#12  Short offline       Completed without error       00%     14540         -
#13  Short offline       Completed without error       00%     14492         -
#14  Short offline       Completed without error       00%     14444         -
#15  Extended offline    Completed without error       00%     14430         -
#16  Short offline       Completed without error       00%     14396         -
#17  Short offline       Completed without error       00%     14348         -
#18  Short offline       Completed without error       00%     14300         -
#19  Short offline       Completed without error       00%     14252         -
#20  Short offline       Completed without error       00%     14204         -
#21  Short offline       Completed without error       00%     14157         -
/dev/da2:
[root@freenas] ~# smartctl -a /dev/da2
LU WWN Device Id: 5 0014ee 25ef238d3
Local Time is:    Fri Dec 18 08:13:31 2015 EST
                                        was never started.
                                        been run.
data collection:                (44520) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 446) minutes.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       1
  3 Spin_Up_Time            0x0027   180   174   021    Pre-fail  Always       -       5958
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       15
No Errors Logged
# 6  Extended offline    Completed without error       00%     14814         -
# 8  Short offline       Completed without error       00%     14733         -
# 9  Short offline       Completed without error       00%     14685         -
#10  Short offline       Completed without error       00%     14637         -
#11  Short offline       Completed without error       00%     14590         -
#12  Short offline       Completed without error       00%     14541         -
#13  Short offline       Completed without error       00%     14493         -
#14  Short offline       Completed without error       00%     14445         -
#15  Extended offline    Completed without error       00%     14431         -
#16  Short offline       Completed without error       00%     14397         -
#17  Short offline       Completed without error       00%     14349         -
#18  Short offline       Completed without error       00%     14301         -
#19  Short offline       Completed without error       00%     14253         -
#20  Short offline       Completed without error       00%     14205         -
/dev/da3:
[root@freenas] ~# smartctl -a /dev/da3
Serial Number:    WD-------------------------------
LU WWN Device Id: 5 0014ee 6aeaeaaa7
Local Time is:    Fri Dec 18 08:13:53 2015 EST
                                        was never started.
                                        been run.
data collection:                (40020) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 401) minutes.
  3 Spin_Up_Time            0x0027   180   172   021    Pre-fail  Always       -       5983
  9 Power_On_Hours          0x0032   080   080   000    Old_age   Always       -       15034
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       17
No Errors Logged
# 1  Short offline       Completed without error       00%     15002         -
# 2  Short offline       Completed without error       00%     14955         -
# 3  Short offline       Completed without error       00%     14907         -
# 4  Short offline       Completed without error       00%     14859         -
# 5  Short offline       Completed without error       00%     14811         -
# 6  Extended offline    Completed without error       00%     14795         -
# 7  Short offline       Completed without error       00%     14763         -
# 8  Short offline       Completed without error       00%     14715         -
# 9  Short offline       Completed without error       00%     14667         -
#10  Short offline       Completed without error       00%     14619         -
#11  Short offline       Completed without error       00%     14571         -
#12  Short offline       Completed without error       00%     14523         -
#13  Short offline       Completed without error       00%     14475         -
#14  Short offline       Completed without error       00%     14427         -
#15  Extended offline    Completed without error       00%     14412         -
#16  Short offline       Completed without error       00%     14379         -
#17  Short offline       Completed without error       00%     14331         -
#18  Short offline       Completed without error       00%     14283         -
#19  Short offline       Completed without error       00%     14235         -
#20  Short offline       Completed without error       00%     14187         -
#21  Short offline       Completed without error       00%     14139         -
EvanVanVan
/dev/da4:
[root@freenas] ~# smartctl -a /dev/da4
LU WWN Device Id: 5 0014ee 6aeae7072
Local Time is:    Fri Dec 18 08:14:16 2015 EST
                                        was never started.
                                        been run.
data collection:                (40080) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 402) minutes.
  3 Spin_Up_Time            0x0027   181   173   021    Pre-fail  Always       -       5916
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       60
  9 Power_On_Hours          0x0032   080   080   000    Old_age   Always       -       15065
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       60
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       59
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       18
194 Temperature_Celsius     0x0022   123   111   000    Old_age   Always       -       27
No Errors Logged
# 1  Short offline       Completed without error       00%     15033         -
# 2  Short offline       Completed without error       00%     14986         -
# 3  Short offline       Completed without error       00%     14938         -
# 4  Short offline       Completed without error       00%     14890         -
# 5  Short offline       Completed without error       00%     14842         -
# 6  Extended offline    Completed without error       00%     14827         -
# 7  Short offline       Completed without error       00%     14794         -
# 8  Short offline       Completed without error       00%     14746         -
# 9  Short offline       Completed without error       00%     14698         -
#10  Short offline       Completed without error       00%     14650         -
#11  Short offline       Completed without error       00%     14602         -
#12  Short offline       Completed without error       00%     14554         -
#13  Short offline       Completed without error       00%     14506         -
#14  Short offline       Completed without error       00%     14458         -
#15  Extended offline    Completed without error       00%     14443         -
#16  Short offline       Completed without error       00%     14410         -
#17  Short offline       Completed without error       00%     14362         -
#18  Short offline       Completed without error       00%     14314         -
#19  Short offline       Completed without error       00%     14266         -
#20  Short offline       Completed without error       00%     14218         -
#21  Short offline       Completed without error       00%     14170         -
/dev/da5:
[root@freenas] ~# smartctl -a /dev/da5
Device Model:     WDC WD30EFRX-68AX9N0
LU WWN Device Id: 5 0014ee 6032ef910
Local Time is:    Fri Dec 18 08:05:43 2015 EST
                                        was never started.
                                        been run.
data collection:                (38400) seconds.
                                        Auto Offline data collection on/off supp         ort.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 385) minutes.
SCT capabilities:              (0x70bd) SCT Status supported.
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_         FAILED RAW_VALUE
  3 Spin_Up_Time            0x0027   184   178   021    Pre-fail  Always       -                5758
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -                525
  9 Power_On_Hours          0x0032   068   068   000    Old_age   Always       -                23546
10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -                0
11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -                0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -                218
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -                101
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -                440
194 Temperature_Celsius     0x0022   122   106   000    Old_age   Always       -                28
No Errors Logged
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA         _of_first_error
# 1  Short offline       Completed without error       00%     23516         -
# 2  Short offline       Completed without error       00%     23468         -
# 3  Short offline       Completed without error       00%     23420         -
# 4  Short offline       Completed without error       00%     23372         -
# 5  Short offline       Completed without error       00%     23324         -
# 6  Extended offline    Completed without error       00%     23308         -
# 7  Short offline       Completed without error       00%     23276         -
# 8  Short offline       Completed without error       00%     23228         -
# 9  Short offline       Completed without error       00%     23180         -
#10  Short offline       Completed without error       00%     23132         -
#11  Short offline       Completed without error       00%     23106         -
#12  Short offline       Completed without error       00%     23036         -
#13  Short offline       Completed without error       00%     22988         -
#14  Short offline       Completed without error       00%     22940         -
#15  Extended offline    Completed without error       00%     22925         -
#16  Short offline       Completed without error       00%     22892         -
#17  Short offline       Completed without error       00%     22844         -
#18  Short offline       Completed without error       00%     22796         -
#19  Short offline       Completed without error       00%     22748         -
#20  Short offline       Completed without error       00%     22700         -
#21  Short offline       Completed without error       00%     22652         -
/dev/da6:
[root@freenas] ~# smartctl -a /dev/da6
Serial Number:    WD-WMC1T2597357
LU WWN Device Id: 5 0014ee 6add98aa7
Local Time is:    Fri Dec 18 08:08:27 2015 EST
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
  3 Spin_Up_Time            0x0027   185   179   021    Pre-fail  Always       -       5716
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       523
  9 Power_On_Hours          0x0032   068   068   000    Old_age   Always       -       23537
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       216
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       100
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       436
194 Temperature_Celsius     0x0022   122   108   000    Old_age   Always       -       28
No Errors Logged
# 1  Short offline       Completed without error       00%     23506         -
# 2  Short offline       Completed without error       00%     23458         -
# 3  Short offline       Completed without error       00%     23410         -
# 4  Short offline       Completed without error       00%     23362         -
# 5  Short offline       Completed without error       00%     23314         -
# 6  Extended offline    Completed without error       00%     23299         -
# 7  Short offline       Completed without error       00%     23266         -
# 8  Short offline       Completed without error       00%     23218         -
# 9  Short offline       Completed without error       00%     23170         -
#10  Short offline       Completed without error       00%     23122         -
#11  Short offline       Completed without error       00%     23096         -
#12  Short offline       Completed without error       00%     23026         -
#13  Short offline       Completed without error       00%     22979         -
#14  Short offline       Completed without error       00%     22931         -
#15  Extended offline    Completed without error       00%     22915         -
#16  Short offline       Completed without error       00%     22883         -
#17  Short offline       Completed without error       00%     22835         -
#18  Short offline       Completed without error       00%     22787         -
#19  Short offline       Completed without error       00%     22739         -
#20  Short offline       Completed without error       00%     22691         -
#21  Short offline       Completed without error       00%     22643         -
/dev/da7:
[root@freenas] ~# smartctl -a /dev/da7
Serial Number:    WD----------------------------------
LU WWN Device Id: 5 0014ee 0ae60628c
Local Time is:    Fri Dec 18 08:11:00 2015 EST
                                        was never started.
                                        been run.
data collection:                (40860) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 410) minutes.
  3 Spin_Up_Time            0x0027   185   178   021    Pre-fail  Always       -       5725
194 Temperature_Celsius     0x0022   123   113   000    Old_age   Always       -       27
No Errors Logged
# 1  Short offline       Completed without error       00%     15003         -
# 6  Extended offline    Completed without error       00%     14796         -
# 9  Short offline       Completed without error       00%     14668         -
#10  Short offline       Completed without error       00%     14620         -
#11  Short offline       Completed without error       00%     14572         -
#12  Short offline       Completed without error       00%     14524         -
#13  Short offline       Completed without error       00%     14476         -
#14  Short offline       Completed without error       00%     14428         -
#15  Extended offline    Completed without error       00%     14413         -
#16  Short offline       Completed without error       00%     14380         -
#17  Short offline       Completed without error       00%     14332         -
#18  Short offline       Completed without error       00%     14284         -
#19  Short offline       Completed without error       00%     14236         -
#20  Short offline       Completed without error       00%     14188         -
#21  Short offline       Completed without error       00%     14140         -
solarisguy
I cannot see anything wrong with your da4, so just in case please perform the extended (long) test on it. It would take almost 7 hours to complete.
EvanVanVan
Will do, da4 you say?
EvanVanVan
da4 is in your error log
However, the error looks to me more like a SATA cable that needs to be replaced.
Oh I see that now, strange how they ordered the drives in the email I received.
solarisguy
glabel status
and in the output da4 should match the line with error gptid/2c67faef-b790-11e3-b9da-002590d65107
Bidule0hm
Yep, all the drives are in a very good condition AFAICS ;)
Next culprit --> the SATA cable. Try to reseat the connectors (both ends).
EvanVanVan
Thanks for all the replies, I'm actually away from my house for the weekend so I won't be able to check the results or play with the data cable until at least Sunday. I'll post back then.
EvanVanVan
I completed the long test on DA4, I still think everything looks good, correct? I'll try reseating the sata cable before I replace it entirely. But on the plus side, haven't had any errors (but I also haven't written anything to the drive in a while).
DA4 (after long test)
Serial Number:    WD-WMC4N1073799
Local Time is:    Tue Dec 22 07:45:45 2015 EST
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
  9 Power_On_Hours          0x0032   080   080   000    Old_age   Always       -       15160
194 Temperature_Celsius     0x0022   122   111   000    Old_age   Always       -       28
No Errors Logged
# 1  Extended offline    Completed without error       00%     15158         -
# 2  Short offline       Completed without error       00%     15129         -
# 3  Short offline       Completed without error       00%     15082         -
# 4  Short offline       Completed without error       00%     15033         -
# 5  Short offline       Completed without error       00%     14986         -
# 6  Short offline       Completed without error       00%     14938         -
# 7  Short offline       Completed without error       00%     14890         -
# 8  Short offline       Completed without error       00%     14842         -
# 9  Extended offline    Completed without error       00%     14827         -
#10  Short offline       Completed without error       00%     14794         -
#11  Short offline       Completed without error       00%     14746         -
#12  Short offline       Completed without error       00%     14698         -
#13  Short offline       Completed without error       00%     14650         -
#14  Short offline       Completed without error       00%     14602         -
#15  Short offline       Completed without error       00%     14554         -
#16  Short offline       Completed without error       00%     14506         -
#17  Short offline       Completed without error       00%     14458         -
#18  Extended offline    Completed without error       00%     14443         -
#19  Short offline       Completed without error       00%     14410         -
#20  Short offline       Completed without error       00%     14362         -
#21  Short offline       Completed without error       00%     14314         -
Bidule0hm
I don't see anything wrong with that drive, his status is perfect ;)
