One or more devices has experienced an error resulting in data corruption.
Jonas LV
Hi all, Can someone please help me with the following, I am even ready to hire someone to help me with this:
I have assembled my self a small NAS:
  • ASRock Z87E-ITX Motherboard (Socket 1150, Z87 Express, DDR3, S-ATA 600, WiFi, Mini ITX, Haswell)
  • Intel Core i5 4570T CPU (2.9GHz, 2 Core, 4 Threads, 4MB Cache, LGA1150 Socket)
  • Ballistix Tactical BLT2C8G3D1608ET3LX0CEU 16GB kit (8GB x 2) DDR3 PC3-12800 Unbuffered NON-ECC 1.35V
  • Seasonic SS-400FL2 F3 - 400w FANLESS '80 Plus Platinum' Modular Power Supply
  • Fractal Design Node 304 Case
  • 4 x WD Red NAS Hard Drive (3TB)
  • 1 x 128GB Samsung SSD
  • 1x Noctua NF-A14 PWM Fan (140mm)
  • 2x Noctua NF-F12 PWM Fan (120mm)
  • FreeNAS 9.3 STABLE 201506042008
Created RAID10 (2x2) pool and started sharing for Windows (CIF)
Transferred number of files to that share and one day after power outage I have got an alert in Web interface saying there is a critical error that some files are corrupted. I have ran the following in the console to see what the state is:
zpool status -v
  pool: freenas-boot
state: ONLINE
  scan: none requested
        NAME          STATE     READ WRITE CKSUM
        freenas-boot  ONLINE       0     0     0
               ada4p2    ONLINE       0     0     0
errors: No known data errors
  pool: mynaspool
state: ONLINE
status: One or more devices has experienced an error resulting in data corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
        mynas                                           ONLINE       0     0     0
         mirror-0                                       ONLINE       0     0     0
            gptid/8fced0b9-0edf-11e5-905b-d050991bb0dd  ONLINE       0     0     0
            gptid/902dcd99-0edf-11e5-905b-d050991bb0dd  ONLINE       0     0     0
         mirror-1                                       ONLINE       0     0     0
            gptid/908f7fb9-0edf-11e5-905b-d050991bb0dd  ONLINE       0     0     0
            gptid/90ee212a-0edf-11e5-905b-d050991bb0dd  ONLINE       0     0     0
/mnt/mynas/myfiles/thefile.rar
the list of files continues...
and this is for another 122 files. They account for 100GB data.
Most of them I would survive without, but I am really keen to get back at least 20 of them.
While trying to access the share through Windows all works fine, all files are displayed but the files in questions can't be touched by any means - no renaming, no copying (I/O error), just moving around in the same share.
I have extracted all the files that are not harmed, now somehow need to get out those 20 important and corrupted.
Can someone please help me with this issue? Thank you in advance...
m0nkey_
Can you provide more detail on your system specifications. Such as motherboard make/model, NIC, etc. I will point out, and as most people on the forum will also, you're running an i5 which does not support ECC. You may want to perform a memory test to ensure you RAM isn't going bad. Bad RAM will cause data corruption.
Jonas LV
Here is my current FreeNAS build:
Jonas LV
I am mainly interested in recovering simply the data - not all just some of corrupted files. If I was to take our one HDD will the system restore from part of RAID that is still healthy? Or do I do it without interrupting from hardware perspective?
Mirfster
I would venture to say that you are not going to safely get that data recovered for the corrupted files. That is the problem of running non-ECC memory and why it is strongly advised against.
Jonas LV
How come after doing some research I was given advice to use non-ECC memory...? But this is not the topic - I still would like to recover the data.. .is there someone who could help me to figure out if any of volumes holds it...?
joeschmuck
Old Man
I wouldn't expect you to be able to recover the files since the file system has stated the files are corrupt. I think you have done all that you can to copy your data off the NAS. Hopefully if that data was important, you have another copy of it elsewhere.
I highly doubt that. If so, please point out the posting here in these forums and we will make the person walk the plank. ECC RAM is a requirement due to the way the ZFS file system operates, and it's a NAS which should have ECC RAM regardless. Whoever let you believe non-ECC RAM was okay was an idiot, unless your data isn't important at all, then you just run the risk of data corruption.
But in your situation here it appears the error was not having an UPS on your NAS and configured to shut it down during a power outage. This too although not a requirement to get FreeNAS running, is a requirement if you value your system and it's data.
Cheers,
Joe
Jonas LV
Did you try a scrub?
Did you have any periodic snapshots enabled?
I can not see any periodic snapshots setup. (I did not know I should do it my self - not out of box)
I still do not understand SCRUB. It says I need to specify existing name, but what name it might be? In the WebUI I can see 1 scrub "name" (the same as my zfs pool. Threshold days 35, Days of Month: Everyday. - What do I do with it? - What do I type in to console?
Jonas LV
I see the reason why they might be an idiot. My self did not came across very smart not reading up my self about it...
What comes to UPS - I have and had one when broke my system. I accidentally switched it off......
Well, yes, you should have used ECC memory. If/when you upgrade your hardware, you'll know that, and will hopefully make better choices. For now, running a memory test is a good idea, though it still can't rule out the possibility that there was a temporary error which caused data corruption (even if it reports all clear, there are temporary failure modes for RAM).
If you never set up a scrub, you probably never set up SMART tests for your drives either. To start the scrub from the command line, run 'zpool scrub mynaspool'. Run 'zpool scrub freenas-boot' as well, just to be on the safe side. The scrub on freenas-boot should only take a few seconds, but expect the scrub on your main pool to take several hours. Once that's complete, post the output of zpool status (in code tags, please) again. Then run long SMART tests on all of your drives--'smartctl -t long /dev/ada0', repeat for ada1, ada2, ada3. Expect those also to run for several hours (though you can start them in immediate succession--you don't have to wait for ada0 to finish before starting ada1). When those are complete, post the output of 'smartctl -a' for each of your drives ('smartctl -a /dev/ada0', etc.), again in code tags to preserve the formatting.
Next, what version of FreeNAS are you actually running? You say you're running 9.1, but that can't be true, as you have a ZFS boot pool. What's the actual, exact version you're running?
Finally, do you leave this machine running 24/7? Because there should be a scrub scheduled every 6 weeks by default, on both the main and the boot pool, but it doesn't look like either of those has ever run. Or has it been running less than 6 weeks?
Robert Trevellyan
Pony Wrangler
You can start a scrub from the GUI too. Select a pool in the Storage tab and three buttons will appear at the bottom of the page. One looks like a broom. Click it to start a scrub of the selected pool.
Then you have a lot of homework to do. There's lots of great information in the form of pinned or "sticky" posts in these forums. The Wikipedia page on ZFS is also an excellent starting point.
Jonas LV
Thank you danb35 - you are being extremely helpful. I have got new messages...:
I ran 'zpool scrub mynaspool' and 'zpool scrub freenas-boot'. It ran very quickly both of them.
Then repeated zpool status -v and that is what I have got:
pool: freenas-boot
state: ONLINE
  scan: scrub repaired 0 in 0h0m with 0 errors on Sun Mar 27 18:26:56 2016
     ada4p2    ONLINE       0     0     0
  pool: mynaspool
state: DEGRADED
  scan: scrub repaired 0 in 0h7m with 141 errors on Sun Mar 27 18:34:02 2016
        kuparas                                         DEGRADED     0     0   141
          mirror-0                                      DEGRADED     0     0   132
            gptid/8fced0b9-0edf-11e5-905b-d050991bb0dd  DEGRADED     0     0   132  too many errors
            gptid/902dcd99-0edf-11e5-905b-d050991bb0dd  DEGRADED     0     0   132  too many errors
          mirror-1                                      DEGRADED     0     0   150
            gptid/908f7fb9-0edf-11e5-905b-d050991bb0dd  DEGRADED     0     0   150  too many errors
            gptid/90ee212a-0edf-11e5-905b-d050991bb0dd  DEGRADED     0     0   150  too many errors
Also sorry for my mistake - It's FreeNAS 9.3 I am running - corrected in previous posts as well.
So far (before errors) I was turning this machine on just to add some backups on and sync few folders. Opposite of 24/7. Max 10h a week.
SMART tests are started, will update the post as soon as they have finished.
Any thoughts on new zpool status? - Should I still have hope to restore those few files?
SweetAndLow
Sweet'NASty
Like already started there is about 0% chance you will get those files back. Your pool is basically dead probably because of hardware failure.
devnullius
Sad story to read :/ Above story can only happen if more than 1 disc goes bad, right? If only 1 disk started failing, all his files should be recoverable, right? I feel your pain, Jonas. Good luck :/
Devnullius
I don't think it's disk failure, as such, that's doing this (mainly because it doesn't seem likely that all four disks would die at the same time), but the SMART results will help figure that out. (Very) bad RAM could certainly have scrambled the data. Other hardware problems--bad power supply, for example--could cause widespread problems like this.
The problem with this is that system maintenance tasks (like scrubs and SMART tests) are scheduled at particular times. If the system isn't on at that time, they don't happen. The SMART tests are something that you'd schedule, so if you know that you run the system on Tuesday evenings, for example, you can schedule them for that time. The scrubs are automatically scheduled when a pool is created, but you can change that schedule to a time when you know the system will be up, if it is up on a set schedule. But in both cases, you'd need to manually work on that schedule. Other tasks aren't adjustable through the GUI, though, which is one reason it's recommended to run FreeNAS 24/7.
Very unlikely, I'm afraid.
Jonas LV
S.M.A.R.T. Results:
ada0:
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p13 amd64] (local build)
Model Family:     Western Digital Red (AF)
Device Model:     WDC WD30EFRX-68EUZN0
Serial Number:    WD-WCC4N4EZ78UE
LU WWN Device Id: 5 0014ee 20ba9f44a
Firmware Version: 82.00A82
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Mon Mar 28 12:47:41 2016 BST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity was never started.        Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0) The previous self-test routine completed without error or no self-test has ever been run.
data collection:                (38940) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        Suspend Offline collection upon new command.
                                        Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 391) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x703d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   175   174   021    Pre-fail  Always       -       6241
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       80
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       205
10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       80
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       6
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       77
194 Temperature_Celsius     0x0022   125   118   000    Old_age   Always       -       25
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%       194         -
ada1:
Serial Number:    WD-WMC4N0J49C2N
LU WWN Device Id: 5 0014ee 65aaeddc5
Local Time is:    Mon Mar 28 12:55:11 2016 BST
data collection:                (40560) seconds.
                                        power-saving mode.
recommended polling time:        ( 407) minutes.
  3 Spin_Up_Time            0x0027   176   174   021    Pre-fail  Always       -       6200
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       206
194 Temperature_Celsius     0x0022   125   119   000    Old_age   Always       -       25
No Errors Logged
# 1  Extended offline    Completed without error       00%       195         -
Jonas LV
S.M.A.R.T. results continued:
ada2:
Serial Number:    WD-WCC4N3HZTLKR
LU WWN Device Id: 5 0014ee 260febc82
Local Time is:    Mon Mar 28 12:57:52 2016 BST
data collection:                (41280) seconds.
                                        power-saving mode.
recommended polling time:        ( 414) minutes.
  3 Spin_Up_Time            0x0027   177   176   021    Pre-fail  Always       -       6133
194 Temperature_Celsius     0x0022   127   119   000    Old_age   Always       -       23
No Errors Logged
ada3:
Serial Number:    WD-WMC4N0J07CSE
LU WWN Device Id: 5 0014ee 6b0041c1b
Local Time is:    Mon Mar 28 12:59:06 2016 BST
                                        was never started.
data collection:                (40500) seconds.
                                        power-saving mode.
recommended polling time:        ( 406) minutes.
  3 Spin_Up_Time            0x0027   177   176   021    Pre-fail  Always       -       6141
194 Temperature_Celsius     0x0022   127   118   000    Old_age   Always       -       23
No Errors Logged
Jonas LV
Thank you all for commenting and hand holding through figuring out on what is going on.
So to my understanding the HDD's are fine? It is just a soft issue? - Please comment.
Do I perform RAM test - if the RAM pair is any bad? (what command should I run?)
Please comment, as this will help me to raise questions and make decision should I throw away my current configured hardware and or software.
From you comments I am now convinced that the data that is corrupted is buried for good?
