Onboard NIC Failure
The Shim
Hello, My onboard NIC failed, and I am not sure how to configure a secondary NIC that I have installed in the machine...
D
dlavigne
Guest
Does it automatically get an IP if you reboot the system? If not, post the complete output of ifconfig within code tags.
The Shim
I will check it after work, I will send the output as a JPEG file as I will not be able to email it from the NAS machine.
The Shim
I haven't been able to figure out a way to reduce the text size of that output. If I reinstall the OS is there a way to NOT erase all my drives?
