i get this when i try to enter Jail after upgrading from 8.3.0 to 8.3.1 p2
i cant enter jail.
~# jexec 1 csh
jexec: jail_attach(1): Invalid argument
help :)
jls jexec 2 csh
well I got everything working perfectly. 2 xbmc installs, syncing their media sources, thumbnails, and video databases.
NOTE - jail ip=192.168.1.30, freenas(nfs) ip=192.168.1.4
_______________________________________________________________________________
#in freenas shell
jexec 1 csh
#in jail
pkg_add -r mysql55-server
pkg_add -r mysql55-client
mysql_secure_installation
vi /etc/rc.conf
#add in
mysql_enable="YES"
service mysql-server start
mysql -u root -p
#in mysql
CREATE USER 'xbmc' IDENTIFIED BY 'xbmc';
GRANT ALL ON *.* TO 'xbmc';
quit;
### on my xbmc boxes ( .xbmc/userdata/advancedsettings.xml )
<advancedsettings>
<videodatabase>
<type>mysql</type>
<host>192.168.1.30</host>
<port>3306</port>
<user>xbmc</user>
<pass>xbmc</pass>
</videodatabase>
<pathsubstitution>
<substitute>
<from>special://masterprofile/Thumbnails/</from>
<to>nfs://192.168.1.4/mnt/RAID/Media/xbmc/Thumbnails/</to>
</substitute>
<substitute>
<from>special://masterprofile/sources.xml</from>
<to>nfs://192.168.1.4/mnt/RAID/Media/xbmc/sources.xml</to>
</substitute>
<substitute>
<from>special://masterprofile/mediasources.xml</from>
<to>nfs://192.168.1.4/mnt/RAID/Media/xbmc/mediasources.xml</to>
</substitute>
</pathsubstitution>
</advancedsettings>
I'm hoping someone can help me as even the simplest of anything on this FreeNAS doesn't work. My original server broke and I had to start from scratch. Now when trying to install mysql again it will not pull in from the ftp site. What am I doing wrong? I've spent hours trying to find a solution and can't see anything. I can actually go to FreeBSD and see the file, but can't pull it in.
[root@freenas ~]# jexec 1 csh
Jail# pkg_add -r mysql55-server
Error: Unable to get ftp://ftp.freebsd.org/pub/FreeBSD/ports/amd64/packages-8.3- release/Latest/mysql55-server.tbz: No address record pkg_add: unable to fetch 'ftp://ftp.freebsd.org/pub/FreeBSD/ports/amd64/packages -8.3-release/Latest/mysql55-server.tbz' by URL
Jail#
I'm able to ping both the freenas IP and my jail IP address with no problems.
Joshua Parker Ruehlig, I'm running FreeNAS-8.3.1-RELEASE-p2-x64 (r12686+b770da6_dirty) with MySQL in a jail. Would like to upgrade Freenas to 9.1. I have 12TB of storage on the server, would really like to not have to rebuild the XMBC DB. What are my options, if I have to rebuild the db and reinstall the jail and MySQL I can do that. Just want to be cover the bases before I do any major surgery on the server. I have not upgraded the jail the last few upgrades. Server feeds 4 XMBC Frodo systems and also contains backups and N: drive for the house and families PC's.
Thanks,
Bill
Thanks,
Bill
Hi guys,
Followed the guide on the 2nd page (thanks alot bcrowder).
Can't entirely tell if its working or not though, i started XBMC library was completely blank, so i added a source to see if it would create /xmbc/settings etc but i can't see anything in freenas.
Any ideas?
sounds like you didn't start mysqlWhen I run "mysql_secure_installation" after installing the packages ("pkg install mysql55-server"), I get the following error right after if asks me for the current password for root: "ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)" Any ideas?
sysrc 'mysql_enable=YES' service mysql-server start
Code:sysrc 'mysql_enable=YES' service mysql-server start
I see glad it's helpful.Dude, that is exactly what I'm looking for...using MySQL instead of sqlite (or whatever it's called). Thank you very much. I will follow it step by step.
For the record, I simply did the following:
entered OC jail that was created by FreeNAS plugin by running jexec -u root 2 csh
then, because the FreeBSD 9 port for mysql was missing on ftp.freebsd.org (I got an error when running pkg_add ... about it missing), I instead ran pkg install mysql55-server
the above apparently installed the client as well
the next step was running mysql_secure_install, which is where I got the error mentioned
sure, this link should work.Joshua, thank you so very much. Everything is working great. You take paypal donations or something?
