Hey all,
Total n00b here but I can follow instruction really well! :)
I have successfully installed FreeNAS 8.2 along with a jail and sabnzbd, sickbeard & couchpotato plugins and they all work great. I can access everything end ping out/in everywhere.
After reading this whole thread I decided to try and install mysql in the jail using the above listed method (pkg_add -r mysql55-server) and it went well... I also was able to add the mysql_enable="YES" to the rc.conf file and start the service. Then I added the xbmc user identified by xbmc and still everything is perfect.
But I think I'm missing something. I setup 2 windows PC's, installed xbmc, copy and pasted the advancedsettings.xml file in to the user data on both machines and edited them to be similar. FYI - My jail IP which is running mysql is 192.168.98.100 & my FreeNAS is being shared as smb://FREENAS; Which I changed all of my paths appropriately within the advancedsettings.xml file. However I'm not showing that the settings are being shared between the two xbmc installs.
MY question I guess is how do I 1. check that the sql server is running and accessible from the other pc's, and 2. how do I ensure the stuff inside xbmc is being saved to the mysql DB?
Did I miss the part where I was supposed to create a DB within the mysql server (all I did was create the xbmc user and grant all access). If so, could someone walk me through it if possible? Sorry for the trouble and punt me to the right place if this isn't it please.
Thanks,
Hanz
Thanks,
Hanz
