Not sure if this belongs in plugins, since it's not a plugin per se. (If not, mods, please feel free to move to appropriate section.) It's kind of a request that pertains to an add-on, I guess - and from the little I've read, it'll have to be dealt with through the jail construct and such.
Thing is, if I got my FreeNAS box to also host my MySQL XBMC database, my setup would now be absolutely complete. =)
First : There is a (Light, as I understand it) version of MySQL as part of FreeNAS as it is. Correct?
Second : Is there any hope of a MySQL plugin being developed for us FreeBSD retards?
Third : FYI, the MySQL setup part, for running an XBMC database, only includes these two lines in the MySQL command line :
CREATE USER 'xbmc' IDENTIFIED BY 'xbmc'
GRANT ALL ON *.* TO 'xbmc'
After that, it's a question of pointing XBMC to the IP address of the computer hosting the MySQL database (via its advancedsettings.xml file), and creating necessary exceptions in the client computer's firewall, but all that's a cinch. So, my third question is : any way to enter these two lines of code into the MySQL database that I presume is already in my FreeNAS box?
I'm assuming that once those two lines of code were put in, the rest would just flow very nicely - point XBMC to the ip address of my FreeNAS box (to be precise, the JAIL IP address, as I assume this MySQL would be run from within the jail) and off I go?
Thanks a lot in advance! You guys rock!!!
