Moppen
- Sep 27, 2016
Hi *.*
as far as I understood it, it is at the moment not possible to install Ombi v3 on FreeBSD.
So I tried it with v2 (v2.2.1 was the last v2) with this: https://forums.freenas.org/index.php?threads/plex-request-or-similar.42187/#post-272728
Only that I pkg locked sqlite3 at first because Apps like Radarr, Sonarr, Lidarr and so on have troubles with it.
Now, that FreeBSD has passed a Mono Version thats works like a charm with Radarr etc. I hoped it'll do for Ombi, too. But it didn't.
When I start Ombi manually with 'screen mono /usr/local/Ombi/Ombi.exe' got Errormessages and Ombi wont start.
So I tried to pkg unlocked sqlite3, updated it or even installed from the ports but I keep getting this:
Does anyone know if there is a way to get Ombi running in a jail at all?
Regards,
Stefan
Starting Up! Please wait, this can usually take a few seconds.
Version: 2.2.1678
Location of the database: /usr/local/Ombi/Ombi.sqlite
Your operating system's sysconf (3) function doesn't correctly report physical memory size!
[ERROR] FATAL UNHANDLED EXCEPTION: NLog.NLogConfigurationException: Error when setting property 'Format' on Layout Renderer: ${exception} ---> System.ArgumentException: Object of type 'System.ReadOnlySpan`1[System.Char]' cannot be converted to type 'System.String'.
at System.RuntimeType.CheckValue (System.Object value, System.Reflection.Binder binder, System.Globalization.CultureInfo culture, System.Reflection.BindingFlags invokeAttr) [0x00071] in <d7767e54cb234318be4a1e7ddd12ca51>:0
at System.Reflection.MonoMethod.ConvertValues (System.Reflection.Binder binder, System.Object[] args, System.Reflection.ParameterInfo[] pinfo, System.Globalization.CultureInfo culture, System.Reflection.BindingFlags invokeAttr) [0x00069] in <d7767e54cb234318be4a1e7ddd12ca51>:0
at System.Reflection.MonoMethod.Invoke (System.Object obj, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) [0x00011] in <d7767e54cb234318be4a1e7ddd12ca51>:0
at System.Reflection.MonoProperty.SetValue (System.Object obj, System.Object value, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] index, System.Globalization.CultureInfo culture) [0x0005d] in <d7767e54cb234318be4a1e7ddd12ca51>:0
at System.Reflection.PropertyInfo.SetValue (System.Object obj, System.Object value, System.Object[] index) [0x00000] in <d7767e54cb234318be4a1e7ddd12ca51>:0
at NLog.Internal.PropertyHelper.SetPropertyFromString (System.Object obj, System.String propertyName, System.String value, NLog.Config.ConfigurationItemFactory configurationItemFactory) [0x00108] in <3ba0cff67b4d49d79d53f79e839f8ad9>:0
--- End of inner exception stack trace --Does anyone know if there is a way to get Ombi running in a jail at all?
Regards,
Stefan
