root@freenas[~]# smartctl -x /dev/ada2
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Fujitsu MHY BH
Device Model: FUJITSU MHY2160BH
Serial Number: K428T812C4HL
LU WWN Device Id: 5 00000e 041887ccf
Firmware Version: 0040020B
User Capacity: 160,041,885,696 bytes [160 GB]
Sector Size: 512 bytes logical/physical
ATA Version is: ATA8-ACS T13/1699-D revision 3c
SATA Version is: SATA 2.5, 1.5 Gb/s
Local Time is: Mon Dec 2 21:48:51 2019 CET
SMART support is: Enabled
AAM feature is: Disabled
APM feature is: Disabled
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
was never started.
been run.
data collection: ( 649) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 92) minutes.
Conveyance self-test routine
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-- 100 100 046 - 95551
2 Throughput_Performance P-S--- 100 100 030 - 37487164
3 Spin_Up_Time PO---- 100 100 025 - 1
4 Start_Stop_Count -O--CK 099 099 000 - 2381
5 Reallocated_Sector_Ct PO--CK 100 100 024 - 0 (2000 0)
7 Seek_Error_Rate POSR-- 100 100 047 - 3385
8 Seek_Time_Performance P-S--- 100 100 019 - 4
9 Power_On_Hours -O--CK 040 040 000 - 30183
10 Spin_Retry_Count PO--C- 100 100 020 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 1681
192 Power-Off_Retract_Count -O--CK 100 100 000 - 85
193 Load_Cycle_Count -O--CK 090 090 000 - 209994
194 Temperature_Celsius -O---K 100 065 000 - 25 (Min/Max 2/67)
195 Hardware_ECC_Recovered -O-RC- 100 100 000 - 105
196 Reallocated_Event_Count -O--CK 100 100 000 - 0 (0 6790)
197 Current_Pending_Sector -O--C- 100 100 000 - 0
198 Offline_Uncorrectable ----C- 100 100 000 - 1
199 UDMA_CRC_Error_Count -OSRCK 200 253 000 - 0
200 Multi_Zone_Error_Rate POSR-- 100 100 060 - 26988
203 Run_Out_Cancel -O---- 100 100 000 - 2628584539262
240 Transfer_Error_Rate -OSRCK 200 200 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 GPL,SL R/O 1 Summary SMART error log
0x02 GPL,SL R/O 51 Comprehensive SMART error log
0x03 GPL,SL R/O 64 Ext. Comprehensive SMART error log
0x06 GPL,SL R/O 1 SMART self-test log
0x07 GPL,SL R/O 2 Extended self-test log
0x09 GPL,SL R/W 1 Selective self-test log
0x10 GPL,SL R/O 1 NCQ Command Error log
0x11 GPL,SL R/O 1 SATA Phy Event Counters log
0x23 GPL,SL R/O 1 Delayed sector log [OBS-8]
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa1 GPL,SL VS 1 Device vendor specific log
SMART Extended Comprehensive Error Log Version: 1 (64 sectors)
Device Error Count: 4
CR = Command Register
FEATR = Features Register
COUNT = Count (was: Sector Count) Register
LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8
LH = LBA High (was: Cylinder High) Register ] LBA
LM = LBA Mid (was: Cylinder Low) Register ] Register
LL = LBA Low (was: Sector Number) Register ]
DV = Device (was: Device/Head) Register
DC = Device Control Register
ER = Error register
ST = Status register
Error 4 [3] occurred at disk power-on lifetime: 13147 hours (547 days + 19 hours)
ER -- ST COUNT LBA_48 LH LM LL DV DC
40 -- 41 00 5b 00 04 50 00 d7 03 40 00 Error: UNC at LBA = 0x45000d703 = 18522101507
CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name
60 00 08 00 58 00 04 50 00 d7 00 40 00 40d+21:18:55.906 READ FPDMA QUEUED
60 00 08 00 50 00 04 4f 00 d7 f8 40 00 40d+21:18:55.906 READ FPDMA QUEUED
60 00 08 00 48 00 04 4f 00 d7 f0 40 00 40d+21:18:55.906 READ FPDMA QUEUED
60 00 08 00 40 00 04 4f 00 d7 e8 40 00 40d+21:18:55.905 READ FPDMA QUEUED
60 00 08 00 38 00 04 4f 00 d7 e0 40 00 40d+21:18:55.905 READ FPDMA QUEUED
Error 3 [2] occurred at disk power-on lifetime: 13118 hours (546 days + 14 hours)
40 -- 41 00 3b 00 04 50 00 d7 03 40 00 Error: UNC at LBA = 0x45000d703 = 18522101507
60 00 08 00 38 00 04 50 00 d7 00 40 00 39d+15:58:42.215 READ FPDMA QUEUED
60 00 08 00 30 00 04 4f 00 d7 f8 40 00 39d+15:58:42.214 READ FPDMA QUEUED
60 00 08 00 28 00 04 4f 00 d7 f0 40 00 39d+15:58:42.181 READ FPDMA QUEUED
60 00 08 00 20 00 04 4f 00 d7 e8 40 00 39d+15:58:42.181 READ FPDMA QUEUED
60 00 08 00 18 00 04 4f 00 d7 e0 40 00 39d+15:58:42.180 READ FPDMA QUEUED
Error 2 [1] occurred at disk power-on lifetime: 12457 hours (519 days + 1 hours)
40 -- 41 00 6b 00 04 50 00 d7 03 40 00 Error: UNC at LBA = 0x45000d703 = 18522101507
60 00 08 00 78 00 02 66 00 f5 c0 40 00 12d+03:16:14.908 READ FPDMA QUEUED
60 00 08 00 70 00 02 63 00 b7 00 40 00 12d+03:16:14.885 READ FPDMA QUEUED
60 00 08 00 68 00 04 50 00 d7 00 40 00 12d+03:16:14.885 READ FPDMA QUEUED
60 00 08 00 60 00 02 3d 00 09 e0 40 00 12d+03:16:14.867 READ FPDMA QUEUED
60 00 08 00 58 00 04 4f 00 d7 f8 40 00 12d+03:16:14.866 READ FPDMA QUEUED
Error 1 [0] occurred at disk power-on lifetime: 12305 hours (512 days + 17 hours)
40 -- 41 00 33 00 04 50 00 d7 09 40 00 Error: UNC at LBA = 0x45000d709 = 18522101513
60 00 08 00 48 00 00 4f 00 90 90 40 00 5d+18:38:18.704 READ FPDMA QUEUED
60 00 08 00 40 00 04 50 00 d7 00 40 00 5d+18:38:18.691 READ FPDMA QUEUED
60 00 08 00 38 00 00 4f 00 90 80 40 00 5d+18:38:18.666 READ FPDMA QUEUED
60 00 08 00 30 00 04 4f 00 d7 f8 40 00 5d+18:38:18.657 READ FPDMA QUEUED
60 00 40 00 28 00 00 aa 00 d3 88 40 00 5d+18:38:18.636 READ FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (2 sectors)
# 1 Short offline Completed without error 00% 1 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 2
SCT Version (vendor specific): 0 (0x0000)
SCT Support Level: 1
Device State: Active (0)
Current Temperature: 25 Celsius
Power Cycle Max Temperature: 29 Celsius
Lifetime Max Temperature: 67 Celsius
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 5/60 Celsius
Min/Max Temperature Limit: -40/65 Celsius
Temperature History Size (Index): 478 (263)
Index Estimated Time Temperature Celsius
264 2019-12-02 13:51 27 ********
... ..( 11 skipped). .. ********
276 2019-12-02 14:03 27 ********
277 2019-12-02 14:04 28 *********
... ..( 49 skipped). .. *********
327 2019-12-02 14:54 28 *********
328 2019-12-02 14:55 29 **********
329 2019-12-02 14:56 28 *********
... ..( 23 skipped). .. *********
353 2019-12-02 15:20 28 *********
354 2019-12-02 15:21 27 ********
... ..( 12 skipped). .. ********
367 2019-12-02 15:34 27 ********
368 2019-12-02 15:35 ? -
369 2019-12-02 15:36 27 ********
... ..( 3 skipped). .. ********
373 2019-12-02 15:40 27 ********
374 2019-12-02 15:41 26 *******
375 2019-12-02 15:42 26 *******
376 2019-12-02 15:43 27 ********
377 2019-12-02 15:44 26 *******
378 2019-12-02 15:45 27 ********
379 2019-12-02 15:46 27 ********
380 2019-12-02 15:47 26 *******
381 2019-12-02 15:48 26 *******
382 2019-12-02 15:49 26 *******
383 2019-12-02 15:50 27 ********
384 2019-12-02 15:51 ? -
385 2019-12-02 15:52 27 ********
386 2019-12-02 15:53 26 *******
387 2019-12-02 15:54 ? -
388 2019-12-02 15:55 26 *******
389 2019-12-02 15:56 27 ********
390 2019-12-02 15:57 26 *******
391 2019-12-02 15:58 26 *******
392 2019-12-02 15:59 27 ********
393 2019-12-02 16:00 27 ********
394 2019-12-02 16:01 ? -
395 2019-12-02 16:02 27 ********
396 2019-12-02 16:03 ? -
397 2019-12-02 16:04 27 ********
398 2019-12-02 16:05 27 ********
399 2019-12-02 16:06 27 ********
400 2019-12-02 16:07 ? -
401 2019-12-02 16:08 27 ********
405 2019-12-02 16:12 27 ********
406 2019-12-02 16:13 26 *******
... ..( 15 skipped). .. *******
422 2019-12-02 16:29 26 *******
423 2019-12-02 16:30 ? -
424 2019-12-02 16:31 26 *******
425 2019-12-02 16:32 26 *******
426 2019-12-02 16:33 26 *******
427 2019-12-02 16:34 ? -
428 2019-12-02 16:35 26 *******
... ..( 25 skipped). .. *******
454 2019-12-02 17:01 26 *******
455 2019-12-02 17:02 25 ******
... ..( 9 skipped). .. ******
465 2019-12-02 17:12 25 ******
466 2019-12-02 17:13 24 *****
... ..( 4 skipped). .. *****
471 2019-12-02 17:18 24 *****
472 2019-12-02 17:19 25 ******
473 2019-12-02 17:20 24 *****
... ..( 2 skipped). .. *****
476 2019-12-02 17:23 24 *****
477 2019-12-02 17:24 25 ******
0 2019-12-02 17:25 24 *****
1 2019-12-02 17:26 24 *****
2 2019-12-02 17:27 24 *****
3 2019-12-02 17:28 25 ******
4 2019-12-02 17:29 24 *****
5 2019-12-02 17:30 25 ******
6 2019-12-02 17:31 24 *****
7 2019-12-02 17:32 25 ******
8 2019-12-02 17:33 24 *****
9 2019-12-02 17:34 25 ******
10 2019-12-02 17:35 24 *****
... ..( 22 skipped). .. *****
33 2019-12-02 17:58 24 *****
34 2019-12-02 17:59 23 ****
35 2019-12-02 18:00 23 ****
36 2019-12-02 18:01 23 ****
37 2019-12-02 18:02 22 ***
... ..( 6 skipped). .. ***
44 2019-12-02 18:09 22 ***
45 2019-12-02 18:10 21 **
71 2019-12-02 18:36 21 **
72 2019-12-02 18:37 22 ***
73 2019-12-02 18:38 22 ***
74 2019-12-02 18:39 22 ***
75 2019-12-02 18:40 23 ****
78 2019-12-02 18:43 23 ****
79 2019-12-02 18:44 24 *****
92 2019-12-02 18:57 24 *****
93 2019-12-02 18:58 25 ******
94 2019-12-02 18:59 24 *****
95 2019-12-02 19:00 24 *****
96 2019-12-02 19:01 24 *****
97 2019-12-02 19:02 25 ******
... ..( 2 skipped). .. ******
100 2019-12-02 19:05 25 ******
101 2019-12-02 19:06 24 *****
102 2019-12-02 19:07 25 ******
... ..( 17 skipped). .. ******
120 2019-12-02 19:25 25 ******
121 2019-12-02 19:26 26 *******
122 2019-12-02 19:27 25 ******
... ..( 43 skipped). .. ******
166 2019-12-02 20:11 25 ******
167 2019-12-02 20:12 26 *******
168 2019-12-02 20:13 25 ******
... ..( 8 skipped). .. ******
177 2019-12-02 20:22 25 ******
178 2019-12-02 20:23 26 *******
... ..( 4 skipped). .. *******
183 2019-12-02 20:28 26 *******
184 2019-12-02 20:29 27 ********
... ..( 8 skipped). .. ********
193 2019-12-02 20:38 27 ********
194 2019-12-02 20:39 26 *******
199 2019-12-02 20:44 26 *******
200 2019-12-02 20:45 25 ******
218 2019-12-02 21:03 25 ******
219 2019-12-02 21:04 ? -
220 2019-12-02 21:05 25 ******
224 2019-12-02 21:09 25 ******
225 2019-12-02 21:10 ? -
226 2019-12-02 21:11 25 ******
236 2019-12-02 21:21 25 ******
237 2019-12-02 21:22 ? -
238 2019-12-02 21:23 25 ******
... ..( 5 skipped). .. ******
244 2019-12-02 21:29 25 ******
245 2019-12-02 21:30 ? -
246 2019-12-02 21:31 25 ******
247 2019-12-02 21:32 25 ******
248 2019-12-02 21:33 ? -
249 2019-12-02 21:34 25 ******
254 2019-12-02 21:39 25 ******
255 2019-12-02 21:40 24 *****
256 2019-12-02 21:41 ? -
257 2019-12-02 21:42 24 *****
258 2019-12-02 21:43 25 ******
263 2019-12-02 21:48 25 ******
SCT Error Recovery Control:
Read: Disabled
Write: Disabled
Device Statistics (GP/SMART Log 0x04) not supported
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 4 0 Command failed due to ICRC error
0x0002 4 0 R_ERR response for data FIS
0x0003 4 0 R_ERR response for device-to-host data FIS
0x0004 4 0 R_ERR response for host-to-device data FIS
0x0005 4 0 R_ERR response for non-data FIS
0x0006 4 0 R_ERR response for device-to-host non-data FIS
0x0008 4 0 Device-to-host non-data FIS retries
0x0009 4 5 Transition from drive PhyRdy to drive PhyNRdy
0x000a 4 5 Device-to-host register FISes sent due to a COMRESET
0x000b 4 0 CRC errors within host-to-device FIS
0x000d 4 0 Non-CRC errors within host-to-device FIS
0x000f 4 0 R_ERR response for host-to-device data FIS, CRC
0x0010 4 0 R_ERR response for host-to-device data FIS, non-CRC
root@freenas[~]#
