Hi, I've been running FreeNAS (now TrueNAS) for many many years now (although, I am still an amateur). I seem to have an issue with one of my disks:
1 Currently unreadable (pending) sectors
1 Offline uncorrectable sectors
However, I'm not entirely clear on what (if anything) needs doing here. I've searched historical threads for these errors and see people post the output of their smartctl report and get tailored advice. While I would certainly appreciate that (and have attached my report here) I'm also looking for some guidance that I can follow in general to help interpret what the numbers mean and the significance, so I don't have to create a thread asking for help if something else goes wrong in the future. Is there any such guidance available? I googled but couldn't find much. Thanks for any help and recommendations!
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p7 amd64] (local build)
Model Family: Western Digital Blue
Device Model: WDC WD10EZEX-00BN5A0
Serial Number: WD-WCC3F0NTKXHK
LU WWN Device Id: 5 0014ee 2b6ac9712
Firmware Version: 01.01A01
User Capacity: 1,000,204,886,016 bytes [1.00 TB]
Rotation Rate: 7200 rpm
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Wed May 3 19:17:37 2023 BST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: (10800) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 113) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x3035) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 175 173 021 Pre-fail Always - 2250
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 198
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 017 017 000 Old_age Always - 61281
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 198
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 163
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 1017
194 Temperature_Celsius 0x0022 109 099 000 Old_age Always - 34
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 1
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 1
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 1
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 26293 -
# 2 Short offline Completed without error 00% 26218 -
# 3 Short offline Completed without error 00% 26050 -
# 4 Extended offline Completed without error 00% 25957 -
# 5 Short offline Completed without error 00% 25883 -
# 6 Short offline Completed without error 00% 22382 -
# 7 Extended offline Completed without error 00% 22289 -
# 8 Short offline Completed without error 00% 22214 -
# 9 Short offline Completed without error 00% 21974 -
#10 Extended offline Completed without error 00% 21881 -
#11 Short offline Completed without error 00% 21806 -
#12 Extended offline Completed without error 00% 21546 -
#13 Short offline Completed without error 00% 21471 -
#14 Short offline Completed without error 00% 21255 -
#15 Extended offline Completed without error 00% 21162 -
#16 Short offline Completed without error 00% 21087 -
#17 Short offline Completed without error 00% 20919 -
#18 Extended offline Completed without error 00% 20826 -
#19 Short offline Completed without error 00% 20751 -
#20 Short offline Completed without error 00% 20512 -
#21 Extended offline Completed without error 00% 20419 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
