George Hartzell
- Jan 26, 2019
Wanted to share a quick note about running FreeNAS 11.2 on the Odroid H2: It Just Works(tm).
I'm running an Odroid H2 with 8GB of A-Tech RAM and two 3TB WD RED drives. Installed FreeNAS 11.2 from a SanDisk Cruzer I had in a desk drawer and am running it on a pair of SanDisk Ultra Fit 32GB USB 3.0 Flash Drives.
Some folks have reported problems with drives disconnecting (inadequate power, perhaps?), but I haven't had any trouble.
I ordered the board with its power supply via Amazon, and a "type1 case", and power/SATA cables from Ameridroid. The case is a bit of a puzzle to put together, but Hardkernel's youtube video was sufficient.
The only trouble I've had is with the system losing time. I set the `ktern.timecounter.hardware` tunable (via the FreeNAS UI) to `HPET` (it was `TSC-low`) and it's keeping time beautifully.
The type1 case has a large fan at one end, I have it plugged into the boards FAN connector and the BIOS fan enabled, when it starts spinning it's audible, but only just barely.
Running the Plex plugin and Logitech Music Server in a jail, and dumping Carbon Copy Cloner backups onto it every night.
So far it's running fine.
