hi all.
i have this motherboard, an intel I7-4820K and 16gb Tram Group 2400MHZ Ram
i know that the CPU and the ram are not recomended for freenas, but i am wondering if i replace them with more suited parts, if the motherboard will work well. or am i best off getting rid of it aswell and just getting all new gear?
my plan is
Home server system, running
if i can have it to sleep, i will move the odroid to the modem directly, so that the server sleeping and losing the firewall connection wont effect it.
the system will also be used for backing up
and am i able to start with drives that already have data on them? i currently use flexraid, but am wanting to try something different, that is a bit more reliable. as i am having alot of issues trying to make a AIO system for gaming and serving.
the case i am using is a Backblaze pod, and has plenty of airflow over the drives. i have installed 6 of noctua's new Industrial series 3000RPM fans and they do a great job keeping my current drives at ambient temps.
my current drives are a mixture of 3TB Wd Greens and Seagate's. aswell as a few 2TB WD/Seagate. and 2 6TB Wd Red's. i have ~10 3Tb drives in the mixture.
i hope that i have provided enough info on my aim for the system.
please advise me on what the best route i should take is.
Jason
my plan is
- Plex
- Sabnzb (Have an Odroid XU that i may run this on instead)
- Sickbeard
- CouchPotato
- Deluge/Transmission (Have an Odroid XU that i may run this on instead)
- 2 Samsung Android Phones
- 2 Android Tablets
- 2 Windows Laptops
- 3 Windows Pc's
Jason
