Shroom
- Mar 19, 2014
So I've been reading up on all the most recent mini-ITX builds and hardware discussion and the latest chatter seems to be on these Avoton/Rangeley boards which feature next-generation 8-core Atoms which supposedly benchmark on par with some E3s.
I've recently been stuck in a toss up between going with a simpler ASRock E3C226D2I 2-DIMM 1150 board and a Haswell Pentium G3220 or with the Rangeley board by SuperMicro, which has 4 SO-DIMMs, the 8-core Atom C2758, and a quad-Gb NIC.
I plan to build a small Mini-ITX home NAS with 6 WD Red 3TB and 8GB ECC memory to start - I will upgrade to 16GB if this does not prove to be enough for ZFS/RAID-Z2.
For home purposes, is this new cutting edge 8-core Atom overkill, underkill, or just the right balance between power and energy efficiency? Would a Pentium G3220 (Haswell-based) work better in any situation where heavy applications outside of file storage/file serving would not be used?
The Atom in this case seems to be more sophisticated as it is a SoC, and probably boasts a wider range of features, including supporting 32GB/64GB of RAM, whereas the Haswell board only supports 16GB. For a 6 x 3 TB setup in RAID-Z2, which would be 18TB in total, would 16GB of RAM be plenty, or will speeds suffer until I upgrade it to 24GB?
It seems like the Rangeley board is a clear winner but I can help but wonder if the Atom ends up being underpowered in certain scenarios, or if FreeNAS wont even utilize all those 8 threads and instead relies more heavily on single-core performance.
