NZB Files sitting in queue and not downloading
jeffprandall
I installed the FreeNas Sabnzbd jail, configured my newhosting server (tested), and created my categories. I have configured the API key in Sonnar which also tests successfully. Sonnar will find the file and pass it on to the Sab queue but it just sits there at 0%. I also have tried to manually upload an NZB and get the same thing. What am I missing?
Joshua Parker Ruehlig
by default sabnzbd should download fine. if you changed the folder sabnzbd downloads to its user needs write permissions to that folder
jeffprandall
I have mounted a shared folder to the /media directory and assigned the 777 permissions and it still doesn't work.
are there any errors, can you post sabnzbds log. you have tested any other nzbs?
something with ssl and your usenet server isn't working.
The "Test Server" button works as expected?
jeffprandall
Yes, the Test comes back successful.
I'm not sure why the test would work but the actual downloading would not work.
I suggest you post your log in the sabnzbd forum, and if they knoenthe issue I can help solve it
