bigdaddyo811
 - Jun 24, 2015
I am having permission problems.
I have the following storage settings:
/mnt/tank/media/TV mapped to /var/db/sabnzbd/downloads
The user and group is media/media
This works fine. Sickrage serves the nzb and sab downloads and saves it into the directory media/TV/Showname/Season#/Episode
Now if I go into categories and set the path /mnt/tank/media/TV it doesnt work. It gives me "could not create directory or file" (i.e. having sabnzbd ignore the default directory structure and use the hardcoded one in categories)
I want to do this because right now everything out of sabnzbd is going into the TV folder so I cant use couchpotato. If I try to enter /mnt/tank/media/TV for the "TV" category and /mnt/tank/media/Movies for the "Movie" category they both fail due to "cant create..."
I have also tried changing the jail storage map to /mnt/tank/media to /var/db/sabnzbd/downloads and then setting /TV or /Movies in the category section but that doesnt work ( I assume because if you enter a path in categories in Sabnzbd it ignores some sort of permission?)
Thanks
Thanks
