QuasarBeam
- Sep 2, 2014
I am having a few problems getting SABnzbd to function as desired and it seems to come down to permission problems. I have tried a few of the guides available but haven't been able to get things sorted.
- My volume is called Storage.
- I have a windows CIFS share set up for my main dataset called 'Media'. I set the permission and sharing options according to the 'Configuring Anonymous Access', which created a guest user. I have no problems accessing or reading/writing this folder.
- I installed the SABnzbd plugin.
- When I don't mount any storage and just download with SABnzbd, there are no errors and the file saves to the jail in: /var/db/sabnzbd/Downloads/complete
- If I try and change the Temporary/Completed download folders in sabnzbd to something such as '/media' I get the error: download_dir directory: /media error accessing
- I can create folders in the /var/db/sabnzbd/ directory but nowhere else it seems.
- Set up storage: Soure:/mnt/Storage/downloads | Destination: /var/db/sabnzbd/Downloads
- 'downloads' data set has permissions set to 'downloads' user and group. This dataset and user/group were create from reading the jruehlig.com guide. Only instead of calling things media I called them downloads.
- Downloading another nzb again works fine and appears in the CIFS share of my downloads dataset.
- The CIFS share is set to 'Allow guest access' which allows me to see the files, but I do not have read/write permissions.
- So far any permission changes I make to allow me to make changes to the downloads dataset (i.e. giving it guest permissions like my main data set) also cause sabnzbd to stop working. It throws out the error: Failed making /var/db/sabnzbd/Downloads/incomplete/>nzb name<
