Yeah thats me. It was the same when i had it out of isolation. Or without isolation however to say that correctly :)
I can remove the isolation and reboot if you want. Here is lspci -v (many IOMMUs removed to fit the size):
root@freenas:~# lspci -v
00:00.0 Host bridge: Intel Corporation Sky Lake-E DMI3 Registers (rev 06)
Subsystem: Super Micro Computer Inc X11SPM-TF
Flags: fast devsel, NUMA node 0, IOMMU group 0
Capabilities: [90] Express Root Port (Slot-), MSI 00
Capabilities: [e0] Power Management version 3
Capabilities: [100] Vendor Specific Information: ID=0002 Rev=0 Len=00c <?>
Capabilities: [144] Vendor Specific Information: ID=0004 Rev=1 Len=03c <?>
Capabilities: [1d0] Vendor Specific Information: ID=0003 Rev=1 Len=00a <?>
Capabilities: [250] Secondary PCI Express
Capabilities: [280] Vendor Specific Information: ID=0005 Rev=3 Len=018 <?>
Capabilities: [298] Vendor Specific Information: ID=0007 Rev=0 Len=024 <?>
Capabilities: [300] Vendor Specific Information: ID=0008 Rev=0 Len=038 <?>
00:04.0 System peripheral: Intel Corporation Sky Lake-E CBDMA Registers (rev 06)
Subsystem: Intel Corporation Sky Lake-E CBDMA Registers
Flags: bus master, fast devsel, latency 0, IRQ 400, NUMA node 0, IOMMU group 1
Memory at 383ffff1c000 (64-bit, non-prefetchable) [size=16K]
Capabilities: [80] MSI-X: Enable+ Count=1 Masked-
Capabilities: [90] Express Root Complex Integrated Endpoint, MSI 00
Kernel driver in use: ioatdma
Kernel modules: ioatdma
00:04.1 System peripheral: Intel Corporation Sky Lake-E CBDMA Registers (rev 06)
Flags: bus master, fast devsel, latency 0, IRQ 402, NUMA node 0, IOMMU group 2
Memory at 383ffff18000 (64-bit, non-prefetchable) [size=16K]
00:04.2 System peripheral: Intel Corporation Sky Lake-E CBDMA Registers (rev 06)
Flags: bus master, fast devsel, latency 0, IRQ 400, NUMA node 0, IOMMU group 3
Memory at 383ffff14000 (64-bit, non-prefetchable) [size=16K]
00:04.3 System peripheral: Intel Corporation Sky Lake-E CBDMA Registers (rev 06)
Flags: bus master, fast devsel, latency 0, IRQ 402, NUMA node 0, IOMMU group 4
Memory at 383ffff10000 (64-bit, non-prefetchable) [size=16K]
00:04.4 System peripheral: Intel Corporation Sky Lake-E CBDMA Registers (rev 06)
Flags: bus master, fast devsel, latency 0, IRQ 400, NUMA node 0, IOMMU group 5
Memory at 383ffff0c000 (64-bit, non-prefetchable) [size=16K]
00:04.5 System peripheral: Intel Corporation Sky Lake-E CBDMA Registers (rev 06)
Flags: bus master, fast devsel, latency 0, IRQ 402, NUMA node 0, IOMMU group 6
Memory at 383ffff08000 (64-bit, non-prefetchable) [size=16K]
00:04.6 System peripheral: Intel Corporation Sky Lake-E CBDMA Registers (rev 06)
Flags: bus master, fast devsel, latency 0, IRQ 400, NUMA node 0, IOMMU group 7
Memory at 383ffff04000 (64-bit, non-prefetchable) [size=16K]
00:04.7 System peripheral: Intel Corporation Sky Lake-E CBDMA Registers (rev 06)
Flags: bus master, fast devsel, latency 0, IRQ 402, NUMA node 0, IOMMU group 8
Memory at 383ffff00000 (64-bit, non-prefetchable) [size=16K]
00:05.0 System peripheral: Intel Corporation Sky Lake-E MM/Vt-d Configuration Registers (rev 06)
Subsystem: Intel Corporation Sky Lake-E MM/Vt-d Configuration Registers
Flags: fast devsel, NUMA node 0, IOMMU group 9
Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00
00:05.2 System peripheral: Intel Corporation Sky Lake-E RAS (rev 06)
Flags: fast devsel, NUMA node 0, IOMMU group 10
00:05.4 PIC: Intel Corporation Sky Lake-E IOAPIC (rev 06) (prog-if 20 [IO(X)-APIC])
Subsystem: Intel Corporation Sky Lake-E IOAPIC
Flags: bus master, fast devsel, latency 0, NUMA node 0, IOMMU group 11
Memory at aa21a000 (32-bit, non-prefetchable) [size=4K]
Capabilities: [44] Express Root Complex Integrated Endpoint, MSI 00
00:11.5 SATA controller: Intel Corporation C620 Series Chipset Family SSATA Controller [AHCI mode] (rev 09) (prog-if 01 [AHCI 1.0])
Subsystem: Super Micro Computer Inc C620 Series Chipset Family SSATA Controller [AHCI mode]
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 41, NUMA node 0, IOMMU group 15
Memory at aa216000 (32-bit, non-prefetchable) [size=8K]
Memory at aa219000 (32-bit, non-prefetchable)
I/O ports at 0800
I/O ports at 0810
I/O ports at 0820
Memory at aa180000 (32-bit, non-prefetchable) [size=512K]
Capabilities: [80] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [70] Power Management version 3
Capabilities: [a8] SATA HBA v1.0
Capabilities: [b0] PCI Advanced Features
Kernel driver in use: ahci
Kernel modules: ahci
00:14.0 USB controller: Intel Corporation C620 Series Chipset Family USB 3.0 xHCI Controller (rev 09) (prog-if 30 [XHCI])
Flags: bus master, medium devsel, latency 0, IRQ 40, NUMA node 0, IOMMU group 16
Memory at aa200000 (64-bit, non-prefetchable) [size=64K]
Capabilities: [70] Power Management version 2
Capabilities: [80] MSI: Enable+ Count=1/8 Maskable- 64bit+
Kernel driver in use: xhci_hcd
Kernel modules: xhci_pci
00:14.2 Signal processing controller: Intel Corporation C620 Series Chipset Family Thermal Subsystem (rev 09)
Flags: fast devsel, IRQ 18, NUMA node 0, IOMMU group 16
Memory at 383ffff23000 (64-bit, non-prefetchable) [size=4K]
Capabilities: [50] Power Management version 3
Capabilities: [80] MSI: Enable- Count=1/1 Maskable- 64bit-
Kernel driver in use: intel_pch_thermal
Kernel modules: intel_pch_thermal
00:16.0 Communication controller: Intel Corporation C620 Series Chipset Family MEI Controller #1 (rev 09)
Flags: bus master, fast devsel, latency 0, IRQ 11, NUMA node 0, IOMMU group 17
Memory at 383ffff22000 (64-bit, non-prefetchable) [size=4K]
Capabilities: [8c] MSI: Enable- Count=1/1 Maskable- 64bit+
Kernel modules: mei_me
00:16.1 Communication controller: Intel Corporation C620 Series Chipset Family MEI Controller #2 (rev 09)
Memory at 383ffff21000 (64-bit, non-prefetchable) [size=4K]
00:16.4 Communication controller: Intel Corporation C620 Series Chipset Family MEI Controller #3 (rev 09)
Memory at 383ffff20000 (64-bit, non-prefetchable) [size=4K]
00:17.0 SATA controller: Intel Corporation C620 Series Chipset Family SATA Controller [AHCI mode] (rev 09) (prog-if 01 [AHCI 1.0])
Subsystem: Super Micro Computer Inc C620 Series Chipset Family SATA Controller [AHCI mode]
Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 399, NUMA node 0, IOMMU group 18
Memory at aa214000 (32-bit, non-prefetchable) [size=8K]
Memory at aa218000 (32-bit, non-prefetchable)
I/O ports at 0840
I/O ports at 0850
I/O ports at 0860
Memory at aa100000 (32-bit, non-prefetchable) [size=512K]
00:1c.0 PCI bridge: Intel Corporation C620 Series Chipset Family PCI Express Root Port #1 (rev f9) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 24, NUMA node 0, IOMMU group 19
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: [disabled]
Memory behind bridge: [disabled]
Prefetchable memory behind bridge: [disabled]
Capabilities: [40] Express Root Port (Slot+), MSI 00
Capabilities: [90] Subsystem: Super Micro Computer Inc C620 Series Chipset Family PCI Express Root Port
Capabilities: [a0] Power Management version 3
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Access Control Services
Capabilities: [220] Secondary PCI Express
Kernel driver in use: pcieport
00:1c.5 PCI bridge: Intel Corporation C620 Series Chipset Family PCI Express Root Port #6 (rev f9) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 25, NUMA node 0, IOMMU group 20
Bus: primary=00, secondary=02, subordinate=03, sec-latency=0
I/O behind bridge: 00003000-00003fff [size=4K]
Memory behind bridge: a9000000-aa0fffff [size=17M]
Capabilities: [40] Express Root Port (Slot-), MSI 00
00:1f.0 ISA bridge: Intel Corporation C622 Series Chipset LPC/eSPI Controller (rev 09)
Flags: fast devsel, NUMA node 0, IOMMU group 21
Kernel modules: lpc_ich
00:1f.2 Memory controller: Intel Corporation C620 Series Chipset Family Power Management Controller (rev 09)
Memory at aa210000 (32-bit, non-prefetchable) [disabled] [size=16K]
00:1f.4 SMBus: Intel Corporation C620 Series Chipset Family SMBus (rev 09)
Flags: medium devsel, IRQ 16, NUMA node 0, IOMMU group 21
Memory at 90000000 (64-bit, non-prefetchable)
I/O ports at 0780
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
00:1f.5 Serial bus controller [0c80]: Intel Corporation C620 Series Chipset Family SPI Controller (rev 09)
Memory at fe010000 (32-bit, non-prefetchable) [size=4K]
02:00.0 PCI bridge: ASPEED Technology, Inc. AST1150 PCI-to-PCI Bridge (rev 04) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 17, NUMA node 0, IOMMU group 22
Bus: primary=02, secondary=03, subordinate=03, sec-latency=32
Capabilities: [50] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Power Management version 3
Capabilities: [80] Express PCI-Express to PCI/PCI-X Bridge, MSI 00
Capabilities: [c0] Subsystem: ASPEED Technology, Inc. AST1150 PCI-to-PCI Bridge
Capabilities: [100] Virtual Channel
Capabilities: [800] Advanced Error Reporting
03:00.0 VGA compatible controller: ASPEED Technology, Inc. ASPEED Graphics Family (rev 41) (prog-if 00 [VGA controller])
DeviceName: ASPEED Video AST2500
Subsystem: Super Micro Computer Inc ASPEED Graphics Family
Flags: medium devsel, IRQ 17, NUMA node 0, IOMMU group 22
Memory at a9000000 (32-bit, non-prefetchable) [size=16M]
Memory at aa000000 (32-bit, non-prefetchable) [size=128K]
I/O ports at 3000
Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/2 Maskable- 64bit+
Kernel driver in use: ast
Kernel modules: ast
16:00.0 PCI bridge: Intel Corporation Sky Lake-E PCI Express Root Port A (rev 06) (prog-if 00 [Normal decode])
Physical Slot: 1
Flags: bus master, fast devsel, latency 0, IRQ 27, NUMA node 0, IOMMU group 23
Bus: primary=16, secondary=17, subordinate=17, sec-latency=0
I/O behind bridge: 00007000-00007fff [size=4K]
Memory behind bridge: c5c00000-c5efffff [size=3M]
Capabilities: [40] Subsystem: Super Micro Computer Inc Sky Lake-E PCI Express Root Port A
Capabilities: [60] MSI: Enable+ Count=1/2 Maskable+ 64bit-
Capabilities: [90] Express Root Port (Slot+), MSI 00
Capabilities: [110] Access Control Services
Capabilities: [148] Advanced Error Reporting
16:05.0 System peripheral: Intel Corporation Sky Lake-E VT-d (rev 06)
Subsystem: Intel Corporation Sky Lake-E VT-d
Flags: fast devsel, NUMA node 0, IOMMU group 24
16:05.2 System peripheral: Intel Corporation Sky Lake-E RAS Configuration Registers (rev 06)
Flags: fast devsel, NUMA node 0, IOMMU group 25
16:05.4 PIC: Intel Corporation Sky Lake-E IOxAPIC Configuration Registers (rev 06) (prog-if 20 [IO(X)-APIC])
Subsystem: Intel Corporation Sky Lake-E IOxAPIC Configuration Registers
Flags: bus master, fast devsel, latency 0, NUMA node 0, IOMMU group 26
Memory at c5f00000 (32-bit, non-prefetchable) [size=4K]
16:08.0 System peripheral: Intel Corporation Sky Lake-E CHA Registers (rev 06)
Subsystem: Intel Corporation Sky Lake-E CHA Registers
Flags: fast devsel, NUMA node 0, IOMMU group 27
16:1e.6 System peripheral: Intel Corporation Sky Lake-E PCU Registers (rev 06)
Subsystem: Intel Corporation Sky Lake-E PCU Registers
Flags: fast devsel, NUMA node 0, IOMMU group 36
17:00.0 Serial Attached SCSI controller: Broadcom / LSI MegaRAID SAS-3 3108 [Invader] (rev 02)
Subsystem: Broadcom / LSI MegaRAID SAS-3 3108 [Invader]
Flags: bus master, fast devsel, latency 0, IRQ 39, NUMA node 0, IOMMU group 37
I/O ports at 7000
Memory at c5e00000 (64-bit, non-prefetchable) [size=64K]
Memory at c5d00000 (64-bit, non-prefetchable) [size=1M]
Expansion ROM at c5c00000 [disabled] [size=1M]
Capabilities: [68] Express Endpoint, MSI 00
Capabilities: [d0] Vital Product Data
Capabilities: [a8] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [c0] MSI-X: Enable+ Count=97 Masked-
Capabilities: [1e0] Secondary PCI Express
Capabilities: [1c0] Power Budgeting <?>
Capabilities: [148] Alternative Routing-ID Interpretation (ARI)
Kernel driver in use: megaraid_sas
Kernel modules: megaraid_sas
64:00.0 PCI bridge: Intel Corporation Sky Lake-E PCI Express Root Port A (rev 06) (prog-if 00 [Normal decode])
Physical Slot: 5
Flags: bus master, fast devsel, latency 0, IRQ 29, NUMA node 0, IOMMU group 38
Bus: primary=64, secondary=65, subordinate=65, sec-latency=0
Memory behind bridge: df000000-dfffffff [size=16M]
Prefetchable memory behind bridge: 000038b000000000-000038b801ffffff [size=32800M]
64:05.0 System peripheral: Intel Corporation Sky Lake-E VT-d (rev 06)
Flags: fast devsel, NUMA node 0, IOMMU group 39
64:05.2 System peripheral: Intel Corporation Sky Lake-E RAS Configuration Registers (rev 06)
Flags: fast devsel, NUMA node 0, IOMMU group 40
64:05.4 PIC: Intel Corporation Sky Lake-E IOxAPIC Configuration Registers (rev 06) (prog-if 20 [IO(X)-APIC])
Flags: bus master, fast devsel, latency 0, NUMA node 0, IOMMU group 41
Memory at e0000000 (32-bit, non-prefetchable) [size=4K]
64:08.0 System peripheral: Intel Corporation Sky Lake-E Integrated Memory Controller (rev 06)
Subsystem: Intel Corporation Sky Lake-E Integrated Memory Controller
Flags: fast devsel, NUMA node 0, IOMMU group 42
Kernel driver in use: skx_uncore
64:0d.3 System peripheral: Intel Corporation Sky Lake-E LMDP Channel 2 (rev 06)
Subsystem: Intel Corporation Sky Lake-E LMDP Channel 2
Flags: fast devsel, NUMA node 0, IOMMU group 67
65:00.0 3D controller: NVIDIA Corporation GV100GL [Tesla V100 PCIe 32GB] (rev a1)
Subsystem: NVIDIA Corporation GV100GL [Tesla V100 PCIe 32GB]
Flags: fast devsel, IRQ 410, NUMA node 0, IOMMU group 68
Memory at df000000 (32-bit, non-prefetchable) [size=16M]
Memory at 38b000000000 (64-bit, prefetchable) [size=32G]
Memory at 38b800000000 (64-bit, prefetchable) [size=32M]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [250] Latency Tolerance Reporting
Capabilities: [258] L1 PM Substates
Capabilities: [128] Power Budgeting <?>
Capabilities: [420] Advanced Error Reporting
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] Secondary PCI Express
Capabilities: [ac0] Designated Vendor-Specific: Vendor=10de ID=0001 Rev=1 Len=12 <?>
Kernel driver in use: vfio-pci
Kernel modules: nouveau, nvidia_current_drm, nvidia_current
b2:00.0 PCI bridge: Intel Corporation Sky Lake-E PCI Express Root Port A (rev 06) (prog-if 00 [Normal decode])
Physical Slot: 9
Flags: bus master, fast devsel, latency 0, IRQ 31, NUMA node 0, IOMMU group 69
Bus: primary=b2, secondary=b3, subordinate=b5, sec-latency=0
Memory behind bridge: fbc00000-fbefffff [size=3M]
Prefetchable memory behind bridge: 000038c000000000-000038c003ffffff [size=64M]
b2:02.0 PCI bridge: Intel Corporation Sky Lake-E PCI Express Root Port C (rev 06) (prog-if 00 [Normal decode])
Physical Slot: 11
Flags: bus master, fast devsel, latency 0, IRQ 32, NUMA node 0, IOMMU group 70
Bus: primary=b2, secondary=b6, subordinate=b9, sec-latency=0
Memory behind bridge: fb900000-fbbfffff [size=3M]
Capabilities: [40] Subsystem: Super Micro Computer Inc Sky Lake-E PCI Express Root Port C
b2:05.2 System peripheral: Intel Corporation Sky Lake-E RAS Configuration Registers (rev 06)
Flags: fast devsel, NUMA node 0, IOMMU group 72
b2:05.4 PIC: Intel Corporation Sky Lake-E IOxAPIC Configuration Registers (rev 06) (prog-if 20 [IO(X)-APIC])
Flags: bus master, fast devsel, latency 0, NUMA node 0, IOMMU group 73
Memory at fbf00000 (32-bit, non-prefetchable) [size=4K]
b3:00.0 PCI bridge: Intel Corporation Device 37c0 (rev 09) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 33, NUMA node 0, IOMMU group 86
Memory at fbe00000 (64-bit, non-prefetchable) [size=128K]
Bus: primary=b3, secondary=b4, subordinate=b5, sec-latency=0
Memory behind bridge: fbd00000-fbdfffff [size=1M]
Expansion ROM at fbc00000 [disabled] [size=1M]
Capabilities: [40] Express Upstream Port, MSI 00
Capabilities: [80] Power Management version 3
Capabilities: [88] Subsystem: Intel Corporation Device 0000
Capabilities: [200] Secondary PCI Express
b4:03.0 PCI bridge: Intel Corporation Device 37c5 (rev 09) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 33, NUMA node 0, IOMMU group 87
Bus: primary=b4, secondary=b5, subordinate=b5, sec-latency=0
Capabilities: [40] Express Downstream Port (Slot-), MSI 00
Capabilities: [138] Access Control Services
b5:00.0 Ethernet controller: Intel Corporation Ethernet Connection X722 for 10GBASE-T (rev 09)
DeviceName: Intel LAN X722 #1
Subsystem: Super Micro Computer Inc Ethernet Connection X722 for 10GBASE-T
Flags: bus master, fast devsel, latency 0, IRQ 37, NUMA node 0, IOMMU group 88
Memory at 38c000000000 (64-bit, prefetchable) [size=16M]
Memory at 38c002800000 (64-bit, prefetchable) [size=32K]
Expansion ROM at fbd00000 [disabled] [size=512K]
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [70] MSI-X: Enable+ Count=129 Masked-
Capabilities: [a0] Express Endpoint, MSI 00
Capabilities: [e0] Vital Product Data
Capabilities: [140] Device Serial Number e6-bb-ba-ff-ff-6b-1f-ac
Capabilities: [150] Alternative Routing-ID Interpretation (ARI)
Capabilities: [160] Single Root I/O Virtualization (SR-IOV)
Capabilities: [1a0] Transaction Processing Hints
Capabilities: [1b0] Access Control Services
Kernel driver in use: i40e
Kernel modules: i40e
b5:00.1 Ethernet controller: Intel Corporation Ethernet Connection X722 for 10GBASE-T (rev 09)
DeviceName: Intel LAN X722 #2
Flags: bus master, fast devsel, latency 0, IRQ 37, NUMA node 0, IOMMU group 89
Memory at 38c001000000 (64-bit, prefetchable) [size=16M]
Memory at 38c002808000 (64-bit, prefetchable) [size=32K]
Expansion ROM at fbd80000 [disabled] [size=512K]
b6:00.0 PCI bridge: PLX Technology, Inc. PEX 8718 16-Lane, 5-Port PCI Express Gen 3 (8.0 GT/s) Switch (rev aa) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 34, NUMA node 0, IOMMU group 90
Memory at fbb00000 (32-bit, non-prefetchable) [size=256K]
Bus: primary=b6, secondary=b7, subordinate=b9, sec-latency=0
Memory behind bridge: fb900000-fbafffff [size=2M]
Capabilities: [48] MSI: Enable- Count=1/8 Maskable+ 64bit+
Capabilities: [68] Express Upstream Port, MSI 00
Capabilities: [a4] Subsystem: PLX Technology, Inc. PEX 8718 16-Lane, 5-Port PCI Express Gen 3 (8.0 GT/s) Switch
Capabilities: [100] Device Serial Number aa-87-00-10-b5-df-0e-00
Capabilities: [fb4] Advanced Error Reporting
Capabilities: [138] Power Budgeting <?>
Capabilities: [10c] Secondary PCI Express
Capabilities: [148] Virtual Channel
Capabilities: [e00] Multicast
Capabilities: [b00] Latency Tolerance Reporting
Capabilities: [b70] Vendor Specific Information: ID=0001 Rev=0 Len=010 <?>
b7:01.0 PCI bridge: PLX Technology, Inc. PEX 8718 16-Lane, 5-Port PCI Express Gen 3 (8.0 GT/s) Switch (rev aa) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 36, NUMA node 0, IOMMU group 91
Bus: primary=b7, secondary=b8, subordinate=b8, sec-latency=0
Memory behind bridge: fba00000-fbafffff [size=1M]
Capabilities: [48] MSI: Enable+ Count=1/8 Maskable+ 64bit+
Capabilities: [68] Express Downstream Port (Slot+), MSI 00
Capabilities: [f24] Access Control Services
b7:02.0 PCI bridge: PLX Technology, Inc. PEX 8718 16-Lane, 5-Port PCI Express Gen 3 (8.0 GT/s) Switch (rev aa) (prog-if 00 [Normal decode])
Flags: bus master, fast devsel, latency 0, IRQ 38, NUMA node 0, IOMMU group 92
Bus: primary=b7, secondary=b9, subordinate=b9, sec-latency=0
Memory behind bridge: fb900000-fb9fffff [size=1M]
b8:00.0 Non-Volatile memory controller: KIOXIA Corporation NVMe SSD Controller Cx6 (rev 01) (prog-if 02 [NVM Express])
Subsystem: KIOXIA Corporation NVMe SSD Controller Cx6
Flags: bus master, fast devsel, latency 0, IRQ 35, NUMA node 0, IOMMU group 93
Memory at fba10000 (64-bit, non-prefetchable) [size=32K]
Expansion ROM at fba00000 [disabled] [size=64K]
Capabilities: [70] Express Endpoint, MSI 00
Capabilities: [b0] MSI-X: Enable+ Count=129 Masked-
Capabilities: [148] Device Serial Number 00-ed-f0-02-e2-8e-e3-8c
Capabilities: [158] Alternative Routing-ID Interpretation (ARI)
Capabilities: [168] Secondary PCI Express
Capabilities: [188] Physical Layer 16.0 GT/s <?>
Capabilities: [1b0] Lane Margining at the Receiver <?>
Kernel driver in use: nvme
Kernel modules: nvme
b9:00.0 Non-Volatile memory controller: KIOXIA Corporation NVMe SSD Controller Cx6 (rev 01) (prog-if 02 [NVM Express])
Flags: bus master, fast devsel, latency 0, IRQ 37, NUMA node 0, IOMMU group 94
Memory at fb910000 (64-bit, non-prefetchable) [size=32K]
Expansion ROM at fb900000 [disabled] [size=64K]
Capabilities: [148] Device Serial Number 00-eb-f0-02-e2-8e-e3-8c
