Having issues with NVIDIA Quadro K420
jdogocder
I have 2 NVIDIA Quadro K420s installed in my system, but when I try and add them into an app, the GPU Passthrough option is disabled.
When running lspci | grep VGA, I see both GPU's detect
01:00.0 VGA compatible controller: NVIDIA Corporation GK107GL [Quadro K420] (rev a1)
02:00.0 VGA compatible controller: NVIDIA Corporation GK107GL [Quadro K420] (rev a1)
My GPU is on the confirmed model list, but when I run nvidia-smi, I get the error NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
12f23eddde
Kepler GPUs are too old on 22.12 (535 drivers are installed by default). You may install the legacy driver if you would like to accept the risk of breaking the stock drivers stack:
