SOLVED NUT: Where do you add a UPS that is not listed?
kikotte
I have written to Nut and my UPS works with 2.7.4 but since it is not included in the list, I can not use it and can you add it to the list?
I have tried debug and it works.
/usr/local/libexec/nut/usbhid-ups -a ups
D
dlavigne
Guest
What list? Also which FreeNAS version (System -> Information)?
kikotte
kikotte
Nick2253
What UPS is it? What driver?
The list of UPSes is just for convenience. You can select any UPS with the same driver/options as the one your UPS needs to work.
kikotte
Nick2253
/usr/local/libexec/nut/usbhid-ups -a ups -x vendorid=06da -x explore -DD
Pick any UPS that shows "usbhid-ups" as the driver. The other options you've provided are only needed if you are trying to select a specific UPS in a multi-UPS system.
kikotte
Thanks, it got to work now.
