I'm pretty sure this must have been already discussed here, well here we go (sorry if double posted):
In FreeNAS 8.2.0-p1 (and also 8.0.4), there is no way to select some UPSes.
Try selecting Liebert ups2 Powershure PSA USB (usbhid ups), apply, and when reopening GUI, you'll find Tripp-Lite ups 2 smart2200RMXL2U USB, newer models (usbhid-ups) instead of the one you selected.
There is noway to get NUT running. When trying, i get
"Communication with UPS ups lost"
Device should be working as NUT can detect it right:
# nut-scanner
Scanning USB bus.
No start IP, skipping SNMP
No start IP, skipping NUT bus (old connect method)
[nutdev1]
driver = "usbhid-ups"
port = "auto"
vendorid = "10AF"
productid = "0001"
bus = "/dev/usb"
I'm also pretty sure to have selected the right usb port (i checked with # dmesg where the UPS is connected).
Here's my /etc/local/nut/ups.conf file
[ups]
driver = usbhid-ups
port = /dev/ugen1.5
desc = "Liebert"
Well i'm clueless...
I'll be gratefull for any illumination here.
Thanks.
# nut-scanner
Scanning USB bus.
[nutdev1]
port = "auto"
vendorid = "10AF"
productid = "0001"
bus = "/dev/usb"
[ups]
driver = usbhid-ups
port = /dev/ugen1.5
desc = "Liebert"
Thanks.
