- May 17, 2014
I bought this UPS because it was small, had built in networking and had a 5 year battery life. Ended up with some other great features, like outlet power consumption and individual outlet power control.
But, I was never able to get it to work with my FreeNAS using Nut. Neither USB or network seemed to work. So I just hoped my power outages were short term. So far, all have been.
Today, I think I found the magic spell to make it work.
Now that I have it working, I might get a second one for the desktop side.
Things to do:
- Using
dmesg | grep -i --color american
I determined that my UPS was a HID USB device, not augen
which is the only USB menu options. Turns out I can change it to/dev/uhid0
. - Select an APC model that uses
usbhid-ups
for the driver. The closest one by name wasAPC ups 2 Back-UPS Pro USB USB
- Next, my product ID code was not recognized. So, poking around I found I could add this to the
ups.conf
extra options,productid = 0004
Things to do:
- Try a power fail. (FreeNAS is running a scrub, no need to interrupt that.)
- Reboot and make sure Nut works after. (Try another power fail.)
- Check Nut's
productid
on their web site. If not present, report upstream bug. If present, report a FreeNAS bug to refresh Nut.
