So, I have a UPS and I want to change a parameter on the UPS. The user is cyber and the password is cyber. When I go on the cli and get a listing, I can see it:
When I try to change it, I get this every time:
My /usr/local/etc/nut/upsd.users file is:
I've tried root/cyber, cyber/cyber, root and NAS password. I am confused as to what I should do to change this. I believe I have done this in the past and it was not all that painful. I am running FreeNAS-11.3-U3.1
root@NAS:/usr/local/etc/nut # upsrw ups@127.0.0.1 [battery.charge.low] Description unavailable Type: STRING Maximum length: 10 Value: 10 [battery.runtime.low] Description unavailable Type: STRING Maximum length: 10 Value: 300 [input.transfer.high] Description unavailable Type: STRING Maximum length: 10 Value: 140 [input.transfer.low] Description unavailable Type: STRING Maximum length: 10 Value: 100 [ups.delay.shutdown] Description unavailable Type: STRING Maximum length: 10 Value: 20 [ups.delay.start] Description unavailable Type: STRING Maximum length: 10 Value: 30
root@NAS:/usr/local/etc/nut # upsrw -s battery.runtime.low=100 ups Username (root): root Password: Unexpected response from upsd: ERR ACCESS-DENIED
[root]
password = cyber
upsmon master
root
[cyber]
password = cyber
actions = set
actions = fsd
instcmds = all
