root@lila[~]# systemctl stop ntp; ntpd -gq; systemctl start ntp
20 Apr 08:44:14 ntpd[3843909]: ntpd
4.2.8p15@1.3728-o Wed Sep 23 11:46:38 UTC 2020 (1): Starting
20 Apr 08:44:14 ntpd[3843909]: Command line: ntpd -gq
20 Apr 08:44:14 ntpd[3843909]: ----------------------------------------------------
20 Apr 08:44:14 ntpd[3843909]: ntp-4 is maintained by Network Time Foundation,
20 Apr 08:44:14 ntpd[3843909]: Inc. (NTF), a non-profit 501(c)(3) public-benefit
20 Apr 08:44:14 ntpd[3843909]: corporation. Support and training for ntp-4 are
20 Apr 08:44:14 ntpd[3843909]: available at
https://www.nwtime.org/support
20 Apr 08:44:14 ntpd[3843909]: proto: precision = 0.039 usec (-25)
20 Apr 08:44:14 ntpd[3843909]: basedate set to 2020-09-11
20 Apr 08:44:14 ntpd[3843909]: gps base set to 2020-09-13 (week 2123)
20 Apr 08:44:14 ntpd[3843909]: Listen and drop on 0 v6wildcard [::]:123
20 Apr 08:44:14 ntpd[3843909]: Listen and drop on 1 v4wildcard 0.0.0.0:123
20 Apr 08:44:14 ntpd[3843909]: Listen normally on 2 lo 127.0.0.1:123
20 Apr 08:44:14 ntpd[3843909]: Listen normally on 3 br0 10.10.0.200:123
20 Apr 08:44:14 ntpd[3843909]: Listen normally on 4 kube-bridge 172.16.0.1:123
20 Apr 08:44:14 ntpd[3843909]: Listen normally on 5 kube-dummy-if 172.17.0.1:123
20 Apr 08:44:14 ntpd[3843909]: Listen normally on 6 kube-dummy-if 172.17.0.10:123
20 Apr 08:44:14 ntpd[3843909]: Listen normally on 7 kube-dummy-if 172.17.48.27:123
20 Apr 08:44:14 ntpd[3843909]: Listen normally on 8 kube-dummy-if 172.17.29.70:123
20 Apr 08:44:14 ntpd[3843909]: Listen normally on 9 lo [::1]:123
20 Apr 08:44:14 ntpd[3843909]: Listen normally on 10 enp8s0 [fe80::1efd:8ff:fe73:c849%3]:123
20 Apr 08:44:14 ntpd[3843909]: Listen normally on 11 br0 [2003:a:d5d:7901:a01f:2fff:fe5d:39a4]:123
20 Apr 08:44:14 ntpd[3843909]: Listen normally on 12 br0 [fe80::a01f:2fff:fe5d:39a4%4]:123
20 Apr 08:44:14 ntpd[3843909]: Listen normally on 13 vnet0 [fe80::fca0:98ff:fe53:ba18%5]:123
20 Apr 08:44:14 ntpd[3843909]: Listen normally on 14 kube-bridge [fe80::8c8e:f9ff:fed2:2629%6]:123
20 Apr 08:44:14 ntpd[3843909]: Listen normally on 15 kube-dummy-if [fe80::284b:45ff:fe7f:ab65%7]:123
20 Apr 08:44:14 ntpd[3843909]: Listen normally on 16 veth529af4bc [fe80::1086:92ff:fe25:ac74%11]:123
20 Apr 08:44:14 ntpd[3843909]: Listen normally on 17 veth9bf0496b [fe80::ac44:45ff:fecf:ad3e%12]:123
20 Apr 08:44:14 ntpd[3843909]: Listening on routing socket on fd #34 for interface updates
20 Apr 08:44:21 ntpd[3843909]: ntpd: time slew +0.071217 s
ntpd: time slew +0.071217s
root@lila[~]# journalctl -f -u ntp
-- Journal begins at Thu 2022-03-24 12:43:37 CET. --
Apr 20 08:44:21 lila.lan.local ntpd[3844379]: Listen normally on 12 br0 [fe80::a01f:2fff:fe5d:39a4%4]:123
Apr 20 08:44:21 lila.lan.local ntpd[3844379]: Listen normally on 13 vnet0 [fe80::fca0:98ff:fe53:ba18%5]:123
Apr 20 08:44:21 lila.lan.local ntpd[3844379]: Listen normally on 14 kube-bridge [fe80::8c8e:f9ff:fed2:2629%6]:123
Apr 20 08:44:21 lila.lan.local ntpd[3844379]: Listen normally on 15 kube-dummy-if [fe80::284b:45ff:fe7f:ab65%7]:123
Apr 20 08:44:21 lila.lan.local ntpd[3844379]: Listen normally on 16 veth529af4bc [fe80::1086:92ff:fe25:ac74%11]:123
Apr 20 08:44:21 lila.lan.local ntpd[3844379]: Listen normally on 17 veth9bf0496b [fe80::ac44:45ff:fecf:ad3e%12]:123
Apr 20 08:44:21 lila.lan.local ntpd[3844379]: Listening on routing socket on fd #34 for interface updates
Apr 20 08:44:21 lila.lan.local ntpd[3844379]: kernel reports TIME_ERROR: 0x41: Clock Unsynchronized
Apr 20 08:44:21 lila.lan.local systemd[1]: Started Network Time Service.
