Heavywun
- Jul 26, 2023
Link: Flashstor fan control on GitHub
I am looking for a more 'iX-acceptable' method of implementing fan control on my Asustor Flashstor 12 Pro (a pure NVMe drive NAS device).
BACKGROUND: Asustor have left some of their NAS devices open to installing alternative operating systems and RAID/Storage solutions. They have published a video guide covering installing TrueNAS-SCALE on the Flashstor devices.
THE PROBLEM: There is no native support for Asustor's temperature monitoring and fan control hardware under TrueNAS-SCALE, so the fan defaults to a low 1500-odd rpm and things get toasty.
MY CURRENT SOLUTION: Relies on compiling and installing a custom kmod to monitor NVMe and system temperatures and control fan speed. I then use two scripts to implement fan control. The first script runs as a post-init script to check if the kmod exists (in case of an update or upgrade), compiles and installs it if necessary, and then runs a second script in the background to adjust fan speed in response to temp changes.
MY CONCERN: is the kernel module component of this solution. What happens if/when iX disable
The code for my post-init dash script is below, so you have an idea of what I currently do to enable temp monitoring and fan control on the flashstor. There's a more detailed explanation in the readme of the GitHub repository above, as well as the longer temp monitoring script.
Any guidance and suggestions would be greatly appreciated.
make
and make install
? Does anyone have any suggestions for an alternative method that I could explore that would avoid tinkering under the hood of TrueNAS-SCALE? The code for my post-init dash script is below, so you have an idea of what I currently do to enable temp monitoring and fan control on the flashstor. There's a more detailed explanation in the readme of the GitHub repository above, as well as the longer temp monitoring script.
#!/bin/sh # Asustor Flashstor kernel module check/compile script for TrueNAS-SCALE # Checks to see if the necessary it87 kmod exists, installs it if not, and runs the fan control script # Add this as a post-init script so that it runs on every boot # Check if the kmod exists and is installed if ! modinfo asustor-it87 >/dev/null 2>&1; then echo "asustor-it87 kmod not found or not installed. Compiling and installing..." # Clone the repository git clone https://github.com/mafredri/asustor-platform-driver cd asustor-platform-driver # Checkout the it87 branch git checkout it87 # Compile the kmod sudo make # Install the kmod sudo make install # Update module dependencies sudo depmod -a # Load the module sudo modprobe -a asustor_it87 echo "asustor-it87 kmod compiled, installed, and loaded successfully." else # Load the module sudo modprobe -a asustor_it87 echo "asustor-it87 kmod is already installed." fi # Run the fan control script nohup /home/admin/temp_monitor.sh >/dev/null 2>&1 &
