No SpinDown of HDD
s25a
this topic has been discussed several times however after 2 Hours of reading I did niot find a solution. Maybe I missed something.
Goal is to send my HDDs in standby (Spin-Down) after 1 hour of no usage.
Here's the screenshot for it (It's 5 Minutes just for testing purpose)
I also deactivated most of bthe services (Just for testing)
Unfortunately the HHDs do not spin Down and Standby. There's definitely no PC accessing (Shut down everything). So I wonder what could be missing.
Thanks
S
Where is your system dataset?
Also what is your system configuration (according to the forum rules, you should supply that when you ask a question to help others see the context)?
s25a
thank you very much for your quick answer and sorry for my late one. My system Dataset is on a different POOL - I checked it again to be really sure.
OS Version:
FreeNAS-11.2-BETA1
(Build Date: Jul 6, 2018 22:29)
Processor: Intel(R) Xeon(R) CPU E3-1235L v5 @ 2.00GHz (4 cores)
Memory: 16 GB
Thanks S
To borrow from a post from @Elliot Dierksen , you could try:
lsof | egrep '^COMMAND|/mnt/poolname'
To see which files are holding the drive spinning, maybe this will give you a clue to work with.
s25a
thanks a lot for this information
nas# lsof | egrep '^COMMAND|/mnt/LPS'
lsof: WARNING: compiled for FreeBSD release 11.0-RELEASE; this is 11.1-STABLE.
COMMAND	PID	   USER   FD	 TYPE			 DEVICE		   SIZE/OFF   NODE NAME
smbd	  3680	   root	9r	VDIR	  117,357695584				 10	  4 /mnt/LPS/ShareLps
smbd	  3680	   root   34r	VDIR	 118,2276720645				  8	  4 /mnt/LPS/Videos
smbd	  3680	   root   35r	VDIR	  117,357695584				 10	  4 /mnt/LPS/ShareLps
smbd	  3680	   root   39r	VDIR	 118,2276720645				  8	  4 /mnt/LPS/Videos
smbd	  3680	   root   43r	VDIR	  117,357695584				 10	  4 /mnt/LPS/ShareLps
smbd	  3766	   root  cwd	 VDIR	 118,2276720645				  8	  4 /mnt/LPS/Videos
So what I see here is only the Samba Service right? If this would block the drives from spinning down this would really confuse me. I have used Freenas over years and there have been no problems with the Spin Down as far as I remeber.
(Of course I did not test every feature in every release)
However after a clean & Fresh install of the the actual Beta no Spin Down. Maybe the Beta causes the Problem if so I would just wait until the next stable.
If you need any Debug Files or so please let me know and I will provide.
Thanks S
s25a
any further ideas? I also stopped the SMB Service but still no spindown.
Thanks S
s25a
Hi Again,
I just upgraded to latest Version. But still no way to sent the HDDS to Standby.
OS Version:
FreeNAS-11.2-BETA3
(Build Date: Sep 10, 2018 1:18)
Processor:
Memory:
16 GiB
Is it possible that there's a bug? It worked with the smae Hardware on older Freenas Version (FN 11.1) without any issue.
Any idea?
Attached find my settings
According to: https://forums.freenas.org/index.ph...ut-if-a-drive-is-spinning-down-properly.2068/
root@nas[~]# ./standby_check
ADA2: 50 00 00 F0 00 00 00 00 00 FF 00 -- ADA3: 50 00 00 F0 00 00 00 00 00 FF 00
ADA4: 50 00 00 F0 00 00 00 00 00 FF 00 -- ADA5: 50 00 00 F0 00 00 00 00 00 FF 00
Result after 30 Minutes - Still Up
I see you're showing Advanced Power Management as disabled for all drives... ?
s25a
thanks for your reply. I thought it would not be necessary to configure the Advanced options for the spindown. Anyway I set to Level 1 but it didn't change anything - still no spindown.
Any ideas?
Thanks S
