entheogenesis
- Oct 2, 2021
If you're using pfSense, you may find this bug report to be helpful.
ip -6 route add default via fe80::1 dev enp3s0
This thread discusses TrueNAS CORE.I have exactly the same problem at Hetzner from a dedicated server, so the problem is definitely related to TrueNAS-SCALE !
You installed Webmin on TrueNAS SCALE? You know that anything configured outside of the TrueNAS UI will not be persistent?I did several searches there, until helping me with Webmin,
So the problem seems very similar, I also remember that every time I insert the IPV6 gateway in the form, I had an error that I can't remember too much, but contained an error format in Python that talk a failure with the add argument, even with DHCP deactivation and then a server reboot.This thread discusses TrueNAS CORE.
It's even thought out to anticipate future updates with a script that redoes the installation of FirewallD and Webmin, then restores the internal paths to the confs files with symbolic links.You installed Webmin on TrueNAS SCALE? You know that anything configured outside of the TrueNAS UI will not be persistent ?
cli -c "system init_shutdown_script create comment=\"[FIX] Default IPv6 Route\" type=COMMAND command=\"ip -6 route add default via fe80::1 dev enp3s0\" when=POSTINIT enabled=true"
Both are static from the TrueNAS SCALE interface, it is not possible to put IPV4 or IPV6 if one of these two options is active.Could you try setting IPv4 statically instead of using DHCP and autoconfiguration for IPv6 only?
Thanks for pointing to that one. But I think you got it the wrong way round. This bug entry complains that pfSense also drops default routes advertised in RFC4191 fashion. Which is consistent because pfSense, OPNsense and TrueNAS CORE are all based on FreeBSD 13.If you're using pfSense, you may find this bug report to be helpful.
