flyingdutchman
- Aug 4, 2017
Hi all, I've been using FreeNAS on an old work PC for some years now with little trouble apart from the odd death of a HDD. However I will say my knowledge of FreeNAS has only ever been just enough to get it to work.
Recently, after I had moved a different PC and made some cabling adjustments (including unplugging FreeNAS box) I noticed that FreeNAS was no longer accessible and threw a message "No configured interfaces were found. Try to do it manually."
1st thought - Try to configure network interfaces (option 1) - FAILED
2nd thought - Cable might be broken - Nope, tested cable on different PC and was able to connect to network fine
3rd thought - Perhaps ethernet port is dead - Purchased a PCIE network port on Ebay and tried again (getting hopeful) - FAILED
4th thought - Maybe if I download latest FreeNAS and try again - FAILED with exactly the same message
Now I feel like I'm pushing the limits of my knowledge and I'm struggling to know what else to try. I also haven't been able to find another thread that solves my problem. I'm hoping someone can help me troubleshoot this a bit further as I'm not sure where to look first.
During startup I get the following:
re0: link state changed to DOWN
Starting dhclient.
re0: no link.........giving up
/etc/rc.d./dhclient: WARNING: failed to start dhclient
bge0: link state changed to DOWN
Starting dhclient.
bge0: no link.........giving up
I'd really appreciate any advice on what to do next. Also, sorry if I haven't included relevant information.
Cheers
Starting dhclient.
Starting dhclient.
Cheers
