When starting the NFS services i got the following error:
Also i don't see the menu on the console after the upgrade to 12.o-U6.
Any idee what's wrong.
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1247, in _execute_context
self.dialect.do_execute(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/default.py", line 590, in do_execute
cursor.execute(statement, parameters)
sqlite3.OperationalError: no such column: services_nfs.nfs_srv_v4_owner_major
The above exception was the direct cause of the following exception:
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 138, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self,
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1213, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 975, in nf
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/service.py", line 120, in start
await service_object.start()
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/service_/services/base.py", line 78, in start
return await self._start_freebsd()
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/service_/services/nfs.py", line 16, in _start_freebsd
await self.middleware.call("nfs.setup_v4")
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1256, in call
return await self._call(
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1224, in _call
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1128, in run_in_executor
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/nfs_/v4_freebsd.py", line 18, in setup_v4
config = self.middleware.call_sync("nfs.config")
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1272, in call_sync
return self.run_coroutine(methodobj(*prepared_call.args))
File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1312, in run_coroutine
return fut.result()
File "/usr/local/lib/python3.9/concurrent/futures/_base.py", line 438, in result
return self.__get_result()
File "/usr/local/lib/python3.9/concurrent/futures/_base.py", line 390, in __get_result
raise self._exception
File "/usr/local/lib/python3.9/site-packages/middlewared/service.py", line 404, in config
return await self._get_or_insert(
File "/usr/local/lib/python3.9/site-packages/middlewared/service.py", line 385, in _get_or_insert
return await self.middleware.call('datastore.config', datastore, options)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/datastore/read.py", line 186, in config
return await self.query(name, [], options)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/datastore/read.py", line 157, in query
result = await self.middleware.call("datastore.fetchall", qs)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/datastore/connection.py", line 81, in fetchall
return await self.middleware.run_in_executor(self.thread_pool, self._fetchall, *args)
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/datastore/connection.py", line 84, in _fetchall
cursor = self.connection.execute(query, params or [])
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 984, in execute
return meth(self, multiparams, params)
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/sql/elements.py", line 293, in _execute_on_connection
return connection._execute_clauseelement(self, multiparams, params)
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1097, in _execute_clauseelement
ret = self._execute_context(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1287, in _execute_context
self._handle_dbapi_exception(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1481, in _handle_dbapi_exception
util.raise_(
File "/usr/local/lib/python3.9/site-packages/sqlalchemy/util/compat.py", line 178, in raise_
raise exception
sqlalchemy.exc.OperationalError: (sqlite3.OperationalError) no such column: services_nfs.nfs_srv_v4_owner_major
[SQL: SELECT services_nfs.id, services_nfs.nfs_srv_servers, services_nfs.nfs_srv_udp, services_nfs.nfs_srv_allow_nonroot, services_nfs.nfs_srv_v4, services_nfs.nfs_srv_v4_v3owner, services_nfs.nfs_srv_v4_krb, services_nfs.nfs_srv_bindip, services_nfs.nfs_srv_mountd_port, services_nfs.nfs_srv_rpcstatd_port, services_nfs.nfs_srv_rpclockd_port, services_nfs.nfs_srv_16, services_nfs.nfs_srv_mountd_log, services_nfs.nfs_srv_statd_lockd_log, services_nfs.nfs_srv_v4_domain, services_nfs.nfs_srv_v4_owner_major
FROM services_nfs]
(Background on this error at: http://sqlalche.me/e/e3q8)Also i don't see the menu on the console after the upgrade to 12.o-U6.
