WhiteTiger
- Jan 2, 2014
Creating a Pool I got the error I report below
They are 4 HDDs WD 1TB with RAIDZ.
I had already created a test pool using the same configuration and there were no errors.
Then I removed the Pool with "Export / Disconnect", and now I was recreating it.
I wiped each disk, but the error reappears.
=== Update ===
I restarted TrueNAS and the pool was created (with another name)
=== Update ===
[EFAULT] Failed to wipe disk ada6: [Errno 5] Input/output error Error: Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 355, in run await self.future File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 391, in __run_body rv = await self.method(*([self] + args)) File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 975, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 677, in do_create await self.middleware.call('pool.format_disks', job, disks) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1305, in call return await self._call( File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1262, in _call return await methodobj(*prepared_call.args) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/format_disks.py", line 28, in format_disks await asyncio_map(format_disk, disks.items(), limit=16) File "/usr/local/lib/python3.9/site-packages/middlewared/utils/asyncio_.py", line 16, in asyncio_map return await asyncio.gather(*futures) File "/usr/local/lib/python3.9/site-packages/middlewared/utils/asyncio_.py", line 13, in func return await real_func(arg) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool_/format_disks.py", line 24, in format_disk await self.middleware.call('disk.format', disk, swapgb if config['create_swap'] else 0, False) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1305, in call return await self._call( File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1273, in _call return await self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1166, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/disk_/format.py", line 21, in format raise CallError(f'Failed to wipe disk {disk}: {job.error}') middlewared.service_exception.CallError: [EFAULT] Failed to wipe disk ada6: [Errno 5] Input/output error
