When starting the NFS services i got the following error:
Also i don't see the menu on the console after the upgrade to 12.o-U6.
Any idee what's wrong.
Error: Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1247, in _execute_context self.dialect.do_execute( File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/default.py", line 590, in do_execute cursor.execute(statement, parameters) sqlite3.OperationalError: no such column: services_nfs.nfs_srv_v4_owner_major The above exception was the direct cause of the following exception: Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 138, in call_method result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self, File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1213, in _call return await methodobj(*prepared_call.args) File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 975, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/service.py", line 120, in start await service_object.start() File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/service_/services/base.py", line 78, in start return await self._start_freebsd() File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/service_/services/nfs.py", line 16, in _start_freebsd await self.middleware.call("nfs.setup_v4") File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1256, in call return await self._call( File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1224, in _call return await self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1128, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/nfs_/v4_freebsd.py", line 18, in setup_v4 config = self.middleware.call_sync("nfs.config") File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1272, in call_sync return self.run_coroutine(methodobj(*prepared_call.args)) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1312, in run_coroutine return fut.result() File "/usr/local/lib/python3.9/concurrent/futures/_base.py", line 438, in result return self.__get_result() File "/usr/local/lib/python3.9/concurrent/futures/_base.py", line 390, in __get_result raise self._exception File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 975, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/service.py", line 404, in config return await self._get_or_insert( File "/usr/local/lib/python3.9/site-packages/middlewared/service.py", line 385, in _get_or_insert return await self.middleware.call('datastore.config', datastore, options) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1256, in call return await self._call( File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1213, in _call return await methodobj(*prepared_call.args) File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 975, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/datastore/read.py", line 186, in config return await self.query(name, [], options) File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 975, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/datastore/read.py", line 157, in query result = await self.middleware.call("datastore.fetchall", qs) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1256, in call return await self._call( File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1213, in _call return await methodobj(*prepared_call.args) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/datastore/connection.py", line 81, in fetchall return await self.middleware.run_in_executor(self.thread_pool, self._fetchall, *args) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1128, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/datastore/connection.py", line 84, in _fetchall cursor = self.connection.execute(query, params or []) File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 984, in execute return meth(self, multiparams, params) File "/usr/local/lib/python3.9/site-packages/sqlalchemy/sql/elements.py", line 293, in _execute_on_connection return connection._execute_clauseelement(self, multiparams, params) File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1097, in _execute_clauseelement ret = self._execute_context( File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1287, in _execute_context self._handle_dbapi_exception( File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1481, in _handle_dbapi_exception util.raise_( File "/usr/local/lib/python3.9/site-packages/sqlalchemy/util/compat.py", line 178, in raise_ raise exception File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/base.py", line 1247, in _execute_context self.dialect.do_execute( File "/usr/local/lib/python3.9/site-packages/sqlalchemy/engine/default.py", line 590, in do_execute cursor.execute(statement, parameters) sqlalchemy.exc.OperationalError: (sqlite3.OperationalError) no such column: services_nfs.nfs_srv_v4_owner_major [SQL: SELECT services_nfs.id, services_nfs.nfs_srv_servers, services_nfs.nfs_srv_udp, services_nfs.nfs_srv_allow_nonroot, services_nfs.nfs_srv_v4, services_nfs.nfs_srv_v4_v3owner, services_nfs.nfs_srv_v4_krb, services_nfs.nfs_srv_bindip, services_nfs.nfs_srv_mountd_port, services_nfs.nfs_srv_rpcstatd_port, services_nfs.nfs_srv_rpclockd_port, services_nfs.nfs_srv_16, services_nfs.nfs_srv_mountd_log, services_nfs.nfs_srv_statd_lockd_log, services_nfs.nfs_srv_v4_domain, services_nfs.nfs_srv_v4_owner_major FROM services_nfs] (Background on this error at: http://sqlalche.me/e/e3q8)
