I'm looking to do basically the exact same build. I had a question about that motherboard. It seems like SuperMicro has two, with almost exactly the same model number:
One is called X10SLL-F-O and one is X10SLL+-F-O. Despite looking various places, including the SuperMicro site, I can't see what the difference is– other than one costs about $10 more. Can anyone clarify the difference for me?
Thanks for the clarification. So here is my proposed build. Any comments or suggestions?
This is my first freenas build and 6TB usable will cover me for a long time. But I like having the option of six drives if I do find that I need extra storage in a few years. Also, it's my understanding that I can replace each of the drives, one at a time in the raidz2, and that after all the rebuilds it will expand to the size of the new drives.
- SUPERMICRO MBD-X10SLL-F-O ($170)
- Fractal Design Define Mini Black Micro ATX ($100)
- 2 x Kingston 4GB 240-Pin DDR3 SDRAM ECC Unbuffered DDR3 1600 (PC3 12800) ($100)
- CORSAIR CSM Series CS450M 450W GOLD Modular ($55)
- 4 x WD Red 3TB (raidz2) ($480)
- Intel Core i3-4150 Haswell 3.5GHz LGA 1150 54W ($120)
- SanDisk Cruzer Fit 8GB USB 2.0 ($6)
Thanks for the suggestion on the Seasonic. I've swapped it in place of the CS450M. I'm also planning to add a third fan (two total on the front), an Antec TrueQuiet 120mm. This brings me to one more question. Any thoughts on WD Red drives vs. Seagate NAS? The price is basically the same. I'm looking at 3TB drives.
Here is the revised build:
- SeaSonic G Series 550-Watt SSR-550RM ($80) - only $5 more than 450W
- [or possibly] 4 x Seagate NAS HDD 3TB (raidz2) ($460)
- Antec TrueQuiet 120mm ($10)
Thanks folks. One last question before I buy all this stuff– with the C222-based SuperMicro board and the Core i3-4150 do I get ECC functionality? I just ask because ark.intel makes it sounds like C222 requires Xeon, though SuperMicro lists the i3 as compatible. The original poster did go Xeon because he wanted the extra horsepower. I don't see a need for it in my case, but I do want to make sure I have ECC with the cheaper CPU.
SuperMicro Product Naming Convention. Looks like the "+" means "Extra DIMMs".I'm looking to do basically the exact same build. I had a question about that motherboard. It seems like SuperMicro has two, with almost exactly the same model number:
Almost forgot about the UPS. I'm looking for a brand-name (e.g. APC) which can power just this box long enough to cleanly power it down in the event of a power event. This requires USB connectivity, right? Any suggestions on suitable options?
