MrMcLargeHuge
- Jan 28, 2014
An intro: I've been looking into a NAS for months now, primarily to be used as a Plex Media Server (transcoding required), but I will also use it for Time Machine backups, file-sharing, and probably some web hosting. OwnCloud intrigues me as well. My plan is to have 6 drives in a RAIDZ2 configuration.
With all that in mind, after reading the stickies, here's the build I've come up with:
- Case: Fractal Designs Define Mini (uATX)
- Board: SuperMicro X10SLL-F-O LGA1150 6xSATA DDR-1600 DIMM ECC Unbuffered
- CPU: Intel Quad-Core Xeon E3-1220 V3 3.1GHz LGA1150
- Memory: Kingston 8GB DDR3-1600 ECC Unbuffered (x2)
- $178.98
- http://www.newegg.com/Product/Product.aspx?Item=N82E16820239370
- Leaving two slots open for later upgrade to 32GB total
- PSU: Seasonic G-750 SSR-750RM 750W
- With regards to the board, I believe it's overkill, but seemed to be the best value. I don't need dual-LAN or IPMI support. Anyone know of a cheaper board that is known to work? My requirements are MicroATX, 6X SATA, and 32GB memory support. I'm willing to change the CPU if that's what it takes to save some money, though I'd still like it to be quad-core Xeon for future-proofing.
- I'm pretty much useless when it comes to selecting a power supply. I chose one I thought would have sufficient wattage, based on a VERY rough estimate (that I'm not even sure I did correctly). For those of you that do this more often, do you believe my selection is appropriate at first glance? Consider that there will be 6 HDD attached to it. Is it overkill? Not enough?
