New Plugins on fresh install (imported ZFS pool) systematically fail installing
stephenreda
So, as I described in https://forums.freenas.org/index.php?threads/importing-zfs-created-in-9-2-1-5-on-latest-build.60681/
I imported an existing ZFS pool on a new installation of the latest stable build of Freenas.
I am however puzzled, I can't seem to properly install plugins. (tried sonarr, plexmediaserver). The installatation seems to go fine,
the plugins appear in the 'installed' section of plugins, but never in the tree. Also, I cannot start these plugins. I just get a message on the GUI that something went wrong.
this is the extract of /var/log/messages/
Jan 15 23:01:15 freenas warden: Building new Jail... Please wait...
Jan 15 23:01:15 freenas warden: zfs clone Main/jails_2/.warden-template-pluginjail@clean Main/jails_2/sonarr_1
Jan 15 23:01:15 freenas warden: Success!
Jan 15 23:01:15 freenas warden: Jail created at /mnt/Main/jails_2/sonarr_1
Jan 15 23:01:16 freenas bridge0: Ethernet address: 02:5c:9b:a4:96:00
Jan 15 23:01:16 freenas kernel: em0: promiscuous mode enabled
Jan 15 23:01:16 freenas kernel: bridge0: link state changed to UP
Jan 15 23:01:16 freenas epair0a: Ethernet address: 02:d0:50....
Jan 15 23:01:16 freenas epair0b: Ethernet address: 02:d0:a0...
Jan 15 23:01:16 freenas kernel: epair0a: link state changed to UP
Jan 15 23:01:16 freenas kernel: epair0b: link state changed to UP
Jan 15 23:01:16 freenas kernel: em0: link state changed to DOWN
Jan 15 23:01:16 freenas kernel: epair0a: promiscuous mode enabled
Jan 15 23:01:19 freenas kernel: em0: link state changed to UP
Jan 15 23:01:28 freenas notifier: jexec 1 /usr/pbi/sonarr-amd64/control stop
Jan 15 23:01:28 freenas uwsgi: jexec 1 /usr/pbi/sonarr-amd64/control start 192.168.1.1 12346
Jan 15 23:01:36 freenas uwsgi: [freeadmin.navtree:562] Couldn't retrieve http://192.168.1.100/plugins/sonarr/1/_s/treemenu: timed outx
note that I already had a jail dataset. I couldn't delete it as the drive was 'busy'. I did however remove the existant jails.
any ideas to move forward?
nojohnny101
Something is wrong with your jail’s networking. Go into each jail’s networking settings (under advanced) and make sure have a proper IP address set, DNS, gateway, etc.
nojohnny101
Not necessarily.
SweetAndLow
Sweet'NASty
You need to set a gateway.
stephenreda
Hi Guys,
So since i set the gateway (192.168.1.254) in the jail settings, the plugins menu now shows the plugin.
However, the plugin still doesn't load. What I also noticed is that the plugin image is not loaded on that view.
Jan 16 22:33:37 freenas uwsgi: [plugins.utils:88] Couldn't retrieve http://192.168.1.100/plugins/sonarr/1/_s/status: timed out
This indicates that also need to set the gateway address somewhere else?
Jail settings:
nojohnny101
Did you confirm your "IPv4 netmask" is correct?
I think I already know the answer to this, but your FreeNAS box can ping 8.8.8.8 correct?
stephenreda
I did get a strange ping reply
root@freenas:~ # ping -c3 8.8.8.8
PING 8.8.8.8 (8.8.8.8): 56 data bytes
64 bytes from 8.8.8.8: icmp_seq=0 ttl=52 time=20.308 ms
64 bytes from 8.8.8.8: icmp_seq=0 ttl=52 time=20.311 ms (DUP!)
64 bytes from 8.8.8.8: icmp_seq=1 ttl=52 time=19.157 ms
64 bytes from 8.8.8.8: icmp_seq=1 ttl=52 time=19.159 ms (DUP!)
64 bytes from 8.8.8.8: icmp_seq=2 ttl=52 time=19.308 ms
--- 8.8.8.8 ping statistics ---
3 packets transmitted, 3 packets received, +2 duplicates, 0.0% packet loss
round-trip min/avg/max/stddev = 19.157/19.649/20.311/0.542 ms
I then disables VIMAGE and restarted the jail; everything now works fine. Thanks guys
