Hi there, i am trying to get a plugin to run (hombebridge) from the community plugins list.
when i try to install it, it hangs at
this is what the log sais:
after around 15 minutes the whole machine is not responding anymore and i need to hard shutdown it, after rebooting there is no evidence it did anything...
what can i do to figure out what the problem is?
Thanks a lot for help,
Pcace
if i click on the "task manager" icon on top of the website, it sais:50.00%
Installing pkg...
cachedplugin.create50.00%
Status: RUNNING
Start Time: 2023-02-08 20:01:23
Feb 8 20:06:23 hugo 1 2023-02-08T20:06:23.309657+01:00 hugo.local rtsold 884 - - <rtsock_input_ifannounce> interface epair0a removed
Feb 8 20:06:23 hugo kernel: bridge0: Ethernet address: 02:fe:47:21:d9:00
Feb 8 20:06:23 hugo kernel: bridge0: link state changed to UP
Feb 8 20:06:23 hugo kernel: ue0: promiscuous mode enabled
Feb 8 20:06:23 hugo kernel: epair0a: Ethernet address: 02:6e:37:b4:e7:0a
Feb 8 20:06:23 hugo kernel: epair0b: Ethernet address: 02:6e:37:b4:e7:0b
Feb 8 20:06:23 hugo kernel: epair0a: link state changed to UP
Feb 8 20:06:23 hugo kernel: epair0b: link state changed to UP
Feb 8 20:06:23 hugo kernel: epair0a: changing name to 'vnet0.1'
Feb 8 20:06:23 hugo 1 2023-02-08T20:06:23.492771+01:00 hugo.local rtsold 884 - - <rtsock_input_ifannounce> interface epair0b removed
Feb 8 20:06:24 hugo kernel: ue0: link state changed to DOWN
Feb 8 20:06:24 hugo kernel: vnet0.1: promiscuous mode enabled
Feb 8 20:06:24 hugo kernel: lo0: link state changed to UP
Feb 8 20:06:27 hugo kernel: ue0: link state changed to UP
Feb 8 20:06:27 hugo 1 2023-02-08T20:06:27.089741+01:00 hugo.local dhclient 18738 - - New IP Address (ue0): 192.168.1.60
Feb 8 20:06:27 hugo 1 2023-02-08T20:06:27.090366+01:00 hugo.local dhclient 18739 - - New Subnet Mask (ue0): 255.255.255.0
Feb 8 20:06:27 hugo 1 2023-02-08T20:06:27.090976+01:00 hugo.local dhclient 18741 - - New Broadcast Address (ue0): 192.168.1.255
Feb 8 20:06:27 hugo 1 2023-02-08T20:06:27.091596+01:00 hugo.local dhclient 18742 - - New Routers (ue0): 192.168.1.1
Feb 8 20:06:31 hugo 1 2023-02-08T20:06:31.615875+01:00 hugo.local rtsold 884 - - <rtsock_input_ifannounce> interface vnet0.1 removed
Feb 8 20:06:31 hugo kernel: vnet0.1: link state changed to DOWN
Feb 8 20:06:31 hugo kernel: epair0b: link state changed to DOWN
Feb 8 20:06:32 hugo kernel: ue0: link state changed to DOWN
Feb 8 20:06:32 hugo kernel: bridge0: link state changed to DOWN
Feb 8 20:06:32 hugo kernel: in6_purgeaddr: err=65, destination address delete failed
Feb 8 20:06:33 hugo 1 2023-02-08T20:06:33.164773+01:00 hugo.local rtsold 884 - - <rtsock_input_ifannounce> interface epair0a removed
Feb 8 20:06:33 hugo 1 2023-02-08T20:06:33.258795+01:00 hugo.local rtsold 884 - - <rtsock_input_ifannounce> interface epair0b removed
Feb 8 20:06:33 hugo kernel: epair0a: Ethernet address: 02:75:87:23:7e:0a
Feb 8 20:06:33 hugo kernel: epair0b: Ethernet address: 02:75:87:23:7e:0b
Feb 8 20:06:33 hugo kernel: epair0a: link state changed to UP
Feb 8 20:06:33 hugo kernel: epair0b: link state changed to UP
Feb 8 20:06:33 hugo kernel: epair0a: changing name to 'vnet0.2'
Feb 8 20:06:33 hugo kernel: vnet0.2: promiscuous mode enabled
Feb 8 20:06:33 hugo kernel: bridge0: link state changed to UP
Feb 8 20:06:33 hugo kernel: lo0: link state changed to UP
Feb 8 20:06:36 hugo 1 2023-02-08T20:06:36.798038+01:00 hugo.local dhclient 19422 - - New IP Address (ue0): 192.168.1.60
Feb 8 20:06:36 hugo 1 2023-02-08T20:06:36.798686+01:00 hugo.local dhclient 19424 - - New Subnet Mask (ue0): 255.255.255.0
Feb 8 20:06:36 hugo 1 2023-02-08T20:06:36.799312+01:00 hugo.local dhclient 19426 - - New Broadcast Address (ue0): 192.168.1.255
Feb 8 20:06:36 hugo 1 2023-02-08T20:06:36.799932+01:00 hugo.local dhclient 19427 - - New Routers (ue0): 192.168.1.1
Feb 8 20:06:36 hugo kernel: ue0: link state changed to UP
Pcace
