PrincePaul
- Feb 26, 2012
Hello Guys,
its a long time ago that I was really active in this forum, mainly in the german threads.
But now its time to get back into it.
My current FreeNAS System is running for over 5 years in 24/7 Mode and I had zero issues so far. Even tho I made some major mistakes in the build process like not buying server hardware. But back in the day I didn`t want to spend so much money.
Now I wanna solve these mistakes once and for all. So its time to get proper hardware and to upgrade to the newest version of FreeNAS.
Usecase now and in the future for my NAS will be the following:
safe Backupstorage
ownCloud
Media Server probably with Plex for the new NAS atm its miniDLNA because of an old FreeNAS 8
maybe Transcoding for media content to watch on the go
I'm using it also for storing pictures, videos and other files for my website. So multiple users need fast access at the same time.
That´s why I want to give LACP a try - I already have a smart managed Switch from D-Link for that. DGS 1210-20. And you never know what else you do along the way. Maybe it´ll get more jobs to do in the future. Virtualisation brings interesting features.
So the plan is the following hardware vise:
Mainboard one of these or 4 core versions:
Supermicro A2SDi-8C+-HLN4F
ASRock Rack C3758D4I
ASRock Rack C3758D4U
8 cores is probably overkill, but better to have them now, than there is no need to upgrade in the future. Or what do you think?
The Marvell LAN controller on the ASRock D4I is a problem?
RAM:
Crucial 64GB Kit (4 x 16GB) DDR4 2400 RDIMM CT4K16G4RFD824A
Should also be safe for the future.
OS Storage:
2x SanDisk Ultra Fit V2 16GB
HDD:
I don´t know yet... in the first place I'll use my old drives. So RAID Z1 5x 2TB WD Red. I already tried an import over a VM. So I created a VM with my old FreeNAS 8, created a pool and imported it in a new FreeNAS 11 VM machine. Should work.
Later maybe RAID Z2 with only 4, but larger drives. Or 3 drive RAID Z1 with larger WD Red`s... IDK.
PSU:
350 Watt 80+ gold Cert. Super Flower from my current setup.
The case is the last thing, but as it just houses everything... it doesn't really matter. I`m also looking into an USV this time.
What do you think of this setup. I like to here your thoughts. Thanks in advance.
Am I missing something - should work flawless in my opinion :D
Update: The case will be a Fractal Design Forcus G mini. It will be modified to hold more HDDs. So additional HDD Cages are coming in and it`ll get soundproofed with king mod mats. Noctua FANs will take care of the airflow.
In my current setup are Noiseblocker eLoops which are starting to make noises after 5 years 24/7. We`ll see if the Noctua FANs hold longer. Probalby use 3 NF-S12A.
Which USV should I get? USB connection for safe shutdown, min. 10 min runtime is important. It doesn`t need to smooth out the power.
Experience with this unit: APC Back-UPS ES 550VA
safe Backupstorage
ownCloud
RAM:
OS Storage:
HDD:
PSU:
