Hey all,
I've recently upgraded from TrueNAS to FreeNAS, and everything was going well until I got the warning via email that one of my drives has bad sectors.
It originally started with:
Shortly followed by a reboot to:
The interesting part was that this was a replacement drive from Seagate under warranty after the original failed within warranty.
Using the below command in the shell:
Which outputted:
Now my bad for not enabling S.M.A.R.T tests since replacing the drive (I didn't realise I only had single drives selected), but I find it slightly coincidental that I've now had two drives fail with a low number of hours. Could it be something within my hardware setup or just bad luck?
My setup:
AMD Athlon 3000G with Radeon Vega Graphics, Gigabyte B450 AORUS PRO, 16GB ECC DDR4 RAM (I know, I need more)
Device: /dev/ada2, 8 Currently unreadable (pending) sectors.
Device: /dev/ada2, 2840 Currently unreadable (pending) sectors.
smartctl -a /dev/ada2
Which outputted:
root@freenas[~]# smartctl -a /dev/ada2
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p14 amd64] (local build)
Model Family: Seagate IronWolf
Device Model: ST3000VN007-2E4166
Serial Number: Z7311NV5
LU WWN Device Id: 5 000c50 0b2dbe8c4
Firmware Version: SC60
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 5900 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Aug 24 20:58:07 2022 BST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 107) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 389) minutes.
Conveyance self-test routine
SCT capabilities: (0x10bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 111 100 006 Pre-fail Always - 32811848
3 Spin_Up_Time 0x0003 093 093 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 11
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 078 060 030 Pre-fail Always - 63340996
9 Power_On_Hours 0x0032 092 092 000 Old_age Always - 7548
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 11
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 094 000 Old_age Always - 30065229831
189 High_Fly_Writes 0x003a 069 069 000 Old_age Always - 31
190 Airflow_Temperature_Cel 0x0022 065 053 045 Old_age Always - 35 (Min/Max 32/35)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 1
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 32
194 Temperature_Celsius 0x0022 035 047 000 Old_age Always - 35 (0 21 0 0 0)
197 Current_Pending_Sector 0x0012 081 081 000 Old_age Always - 3272
198 Offline_Uncorrectable 0x0010 081 081 000 Old_age Offline - 3272
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 7547 -
1 0 0 Not_testing
2 0 0 Not_testingNow my bad for not enabling S.M.A.R.T tests since replacing the drive (I didn't realise I only had single drives selected), but I find it slightly coincidental that I've now had two drives fail with a low number of hours. Could it be something within my hardware setup or just bad luck?
My setup:
