Hey all,
I've recently upgraded from TrueNAS to FreeNAS, and everything was going well until I got the warning via email that one of my drives has bad sectors.
It originally started with:
Shortly followed by a reboot to:
The interesting part was that this was a replacement drive from Seagate under warranty after the original failed within warranty.
Using the below command in the shell:
Which outputted:
Now my bad for not enabling S.M.A.R.T tests since replacing the drive (I didn't realise I only had single drives selected), but I find it slightly coincidental that I've now had two drives fail with a low number of hours. Could it be something within my hardware setup or just bad luck?
My setup:
AMD Athlon 3000G with Radeon Vega Graphics, Gigabyte B450 AORUS PRO, 16GB ECC DDR4 RAM (I know, I need more)
Device: /dev/ada2, 8 Currently unreadable (pending) sectors.
Device: /dev/ada2, 2840 Currently unreadable (pending) sectors.
smartctl -a /dev/ada2
Which outputted:
root@freenas[~]# smartctl -a /dev/ada2 smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p14 amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate IronWolf Device Model: ST3000VN007-2E4166 Serial Number: Z7311NV5 LU WWN Device Id: 5 000c50 0b2dbe8c4 Firmware Version: SC60 User Capacity: 3,000,592,982,016 bytes [3.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5900 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Wed Aug 24 20:58:07 2022 BST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 107) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 389) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x10bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 111 100 006 Pre-fail Always - 32811848 3 Spin_Up_Time 0x0003 093 093 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 11 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x000f 078 060 030 Pre-fail Always - 63340996 9 Power_On_Hours 0x0032 092 092 000 Old_age Always - 7548 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 11 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 094 000 Old_age Always - 30065229831 189 High_Fly_Writes 0x003a 069 069 000 Old_age Always - 31 190 Airflow_Temperature_Cel 0x0022 065 053 045 Old_age Always - 35 (Min/Max 32/35) 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 1 193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 32 194 Temperature_Celsius 0x0022 035 047 000 Old_age Always - 35 (0 21 0 0 0) 197 Current_Pending_Sector 0x0012 081 081 000 Old_age Always - 3272 198 Offline_Uncorrectable 0x0010 081 081 000 Old_age Offline - 3272 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 7547 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing
My setup:
