WhirlwindMonk
- Apr 13, 2013
So, I have a FreeNAS box running at home that I built a couple years back. Unfortunately, space is starting to run low, so I'm looking to upgrade. During my reading, though, I've come to realize that my old build does basically absolutely everything wrong. It's only saving grace is that it uses hard drives designed for servers. That's it, literally everything else is bad, gaming mobo and cpu, non-ECC ram, and raidz1. So, I'm looking to rectify that with my new build (and the new budget that a new job and two incomes can provide).
Case: SilverStone SST-PS07B - MicroATX mini-tower, nothing special about it, just one of the smallest cases I could find that would fit my needs, though it might need another fan or two
Mobo: Supermicro MBD-X9SCL-F-O
CPU: Xeon E3-1230 v2
Ram: 16 GB (2x8) Kingston DDR3 1600 ECC Unbuffered
Hard Drives: 6x3TB Seagate NAS drives to put in RaidZ2 for 12 TB total storage
PSU: SeaSonic SS-350TGM
My main question is the PSU. From the reading I've done, it looks like 350W will cover me, but a little extra assurance would make me feel better.
As for the rest of the parts, this server will be running plugins like SickBeard and Plex, but my research seems to show that this build will handle all the transcoding and encryption I want, so I'm not too worried.
Once the system is built, my biggest concern is testing the hard drives. I have had far too many bad drives over the years and want to make dead sure I don't have a bad drive putting this system together. I've read jgreco's thread on the topic, but he loses me on step 2 of the drive burn in. I understand the basics of the dd command after reading up on it, but how does one go about running multiple dds simultaneously as in step 2, and properly use it for seek testing in step 3? Either I'm misunderstanding what's being said, or my google skills have failed me.
Thank you for any help.
