STREBLO
- Oct 23, 2015
I believe it was around the official transition to iocage, I started having networking issues in jails. for a while after iocage was added in "beta", they were working with no issues. The host never has any issues with networking and I have set the default gateway and nameservers in "global networking configuration".
I'm using a secondary NIC on a separate subnet for my jails, and would prefer to continue doing this. Unfortunately my jails continue to work off and on, and it's not apparent to me why. I am using VNET and have used static IPs, but sometime around the 11.2 upgrade I stopped being able to get networking with static IPs, at which point I could only get networking to work turning on DHCP, and specifying an IP, but only if I create the jail on the command line. In the web interface DHCP shows 'error'.
Is there no official way to use a secondary NIC with VNET? When I try specifying to use DHCP, and have it auto configure it uses the wrong subnet and I end up with a jail in the subnet of the host.
The way I used to create them with static IPs was with
I've created my jails with:
I will have a jail work for a while, then suddenly stop working. Often it seems to be unable to resolve DNS.
My
I have set the tunables:
dhcp=off.I've created my jails with:
iocage create --release 11.2-RELEASE --name sickchill0 \
boot=on vnet=on dhcp=on bpf=yes \
allow_raw_sockets="1" \
ip4_addr="vnet1|172.20.40.37/24" \
interfaces="vnet1:bridge1" \
defaultrouter="172.20.40.1" \
resolver="search example.network;nameserver 172.20.40.1;nameserver 8.8.8.8"I will have a jail work for a while, then suddenly stop working. Often it seems to be unable to resolve DNS.
My
/etc/resolv.conf inside the jails reflect the resolver setting above.I have set the tunables:
| Variable | Value | Type | | cloned_interfaces | bridge0 bridge1 | rc | | ifconfig_bridge1 | addm igb1 up | rc |
