Need Ram info
> dmidecode -t memory
root@NAS-1[~]# dmidecode -t memory
# dmidecode 3.2
# SMBIOS entry point at 0x000f05b0
Found SMBIOS entry point in EFI, reading table from /dev/mem.
SMBIOS 3.0 present.
Handle 0x0028, DMI type 16, 23 bytes
Physical Memory Array
    Use: System Memory
    Error Correction Type: None
    Maximum Capacity: 8 GB
    Error Information Handle: Not Provided
    Number Of Devices: 2
Handle 0x002A, DMI type 17, 40 bytes
Memory Device
    Array Handle: 0x0028
    Total Width: 64 bits
    Data Width: 64 bits
    Form Factor: DIMM
    Set: None
    Locator: A1_DIMM0
    Bank Locator: A1_BANK0
    Type: DDR3
    Type Detail: Synchronous
    Speed: 1600 MT/s
    Manufacturer: Crucial
    Serial Number: E064B7DB
    Asset Tag: A1_AssetTagNum0
    Part Number: CT102464BF160B.M16
    Rank: 2
    Configured Memory Speed: 1600 MT/s
    Minimum Voltage: 1.35 V
    Maximum Voltage: 1.5 V
    Configured Voltage: 1.35 V
Handle 0x002C, DMI type 17, 40 bytes
Memory Device
    Data Width: 64 bits
    Form Factor: DIMM
    Set: None
    Locator: A1_DIMM1
    Bank Locator: A1_BANK1
    Type: DDR3
    Speed: 1600 MT/s
    Serial Number: E064B7DA
    Asset Tag: A1_AssetTagNum1
    Rank: 2
mvcad
Anyway to know if there is any slot available to put more ram in? My client is remote so I cannot see by myself
spuky
Shows you the number installed dims together with the spec of the motherboard you should be able to work it out...
on Dual CPU systems you might get multible Memory arrays...
Jim Reese
Your filled DIMM slots will show up as elvis showed above; empty slots will show something like this:
root@truenas[~]# dmidecode -t memory # dmidecode 3.2 # SMBIOS entry point at 0x7f0c7000 Found SMBIOS entry point in EFI, reading table from /dev/mem. SMBIOS 3.0 present. Handle 0x0017, DMI type 16, 23 bytes Physical Memory Array Location: System Board Or Motherboard Use: System Memory Error Correction Type: Single-bit ECC Maximum Capacity: 128 GB Error Information Handle: Not Provided Number Of Devices: 4 Handle 0x0019, DMI type 17, 40 bytes Memory Device Array Handle: 0x0017 Error Information Handle: Not Provided Total Width: 72 bits Data Width: 64 bits Size: 16384 MB Form Factor: DIMM Set: None Locator: DIMMA1 Bank Locator: P0_Node0_Channel0_Dimm0 Type: DDR4 Type Detail: Synchronous Registered (Buffered) Speed: 2400 MT/s Manufacturer: SK Hynix Serial Number: 2BCE2302 Asset Tag: DIMMA1_AssetTag (date: 18/10) Part Number: HMA82GR7AFR8N-UH Rank: 2 Configured Memory Speed: 2400 MT/s Minimum Voltage: 1.2 V Maximum Voltage: 1.2 V Configured Voltage: 1.2 V Handle 0x001B, DMI type 17, 40 bytes Memory Device Array Handle: 0x001 Error Information Handle: Not Provided Total Width: Unknown Data Width: Unknown Size: No Module Installed Form Factor: DIMM Set: None Locator: DIMMA2 Bank Locator: P0_Node0_Channel0_Dimm1 Type: Unknown Type Detail: Unknown Speed: Unknown Manufacturer: NO DIMM Serial Number: NO DIMM Asset Tag: NO DIMM ...
This partial example shows that there are 4 DIMM slots: A1, A2, B1 & B2. DIMMA1 is filled with a 16GB module, but DIMMA2 is empty.
Hope that helps.
Jim
