SOLVED Need help please-FN 11.2.U5 Unusable Pool-ports using Sata Express (backward to Sata only ports)
199 UDMA_CRC_Error_Count 0x003e 200 192 000 Old_age Always - 178
The fact that that last number is not a 0 indicates an issue communicating with the system. Most often this is a cable issue, it may have become lose, but other times it could be a failing controller either on the motherboard or add on card. These could certainly put your pool in an unknown state. I'm curious to see the results for all of your drives once the tests complete.
1kokies
this interpretation is very helpful even at this point, thanks. This disk and all other in this pool, (should have separated some to mobo SATA) is plugged to the raid card and the cable is this https://www.amazon.com/Cable-Matters-Internal-SFF-8087-Breakout/dp/B012BPLYJC. the first disk scanned is at 30%, while the rest is at 80-90%. should be completed within 10 hours. will update and post complete results
1kokies
current controller arrangement are 8 disks in affected pool are plugged to raid card, previously before pool unknown was
1. Data Storage (affected pool) 4 disk plugged to raid card
2. Data Media 4 disk plugged to raid card
3. Data Storage (affected pool) 4 disk plugged to mobo
4. Slog 1 disk plugged to mobo
1kokies
all smart scan done for da0-da3, attached results (post max 3k characters). da4-da7 in next post.
Comments and opinions much appreciated
The disks & pool looks ok, if cables or controller is the suspected problem , will use new ones and isolate one by one
root@freenas:~ # smartctl -a /dev/da0
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Seagate IronWolf
Device Model:     ST4000VN008-2DR166
Serial Number:    ZDH1E7MA
LU WWN Device Id: 5 000c50 0a2ca53df
Firmware Version: SC60
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5980 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Oct 18 19:06:00 2019 +08
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  581) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 631) minutes.
Conveyance self-test routine
SCT capabilities:              (0x50bd) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   082   064   044    Pre-fail  Always       -       176119726
  3 Spin_Up_Time            0x0003   093   093   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       540
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   090   060   045    Pre-fail  Always       -       906516910
  9 Power_On_Hours          0x0032   081   081   000    Old_age   Always       -       16872 (64 249 0)
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       545
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   001   000    Old_age   Always       -       667
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   060   055   040    Old_age   Always       -       40 (Min/Max 33/45)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       205
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       891
194 Temperature_Celsius     0x0022   040   045   000    Old_age   Always       -       40 (0 21 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       16862 (237 254 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       65529703758
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       46229415874
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Completed without error       00%     16865         -
# 2  Short offline       Completed without error       00%     16857         -
root@freenas:~ #
root@freenas:~ # smartctl -a /dev/da1
Serial Number:    ZGY02DMS
LU WWN Device Id: 5 000c50 0a2c9d3c3
Local Time is:    Fri Oct 18 17:50:32 2019 +08
                                        been run.
data collection:                (  591) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 646) minutes.
  1 Raw_Read_Error_Rate     0x000f   072   064   044    Pre-fail  Always       -       17564311
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       528
  7 Seek_Error_Rate         0x000f   088   060   045    Pre-fail  Always       -       679162100
  9 Power_On_Hours          0x0032   081   081   000    Old_age   Always       -       16845 (174 175 0)
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       532
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   064   056   040    Old_age   Always       -       36 (Min/Max 31/42)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       225
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       959
194 Temperature_Celsius     0x0022   036   044   000    Old_age   Always       -       36 (0 22 0 0 0)
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       16838 (215 51 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       65542818809
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       46208949750
No Errors Logged
# 1  Extended offline    Completed without error       00%     16843         -
root@freenas:~ #
root@freenas:~ # smartctl -a /dev/da2
Serial Number:    ZGY02E9G
LU WWN Device Id: 5 000c50 0a2c98452
Local Time is:    Fri Oct 18 17:56:13 2019 +08
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 616) minutes.
  1 Raw_Read_Error_Rate     0x000f   075   064   044    Pre-fail  Always       -       33043800
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       526
  7 Seek_Error_Rate         0x000f   089   060   045    Pre-fail  Always       -       871349013
  9 Power_On_Hours          0x0032   081   081   000    Old_age   Always       -       16850 (131 92 0)
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       530
188 Command_Timeout         0x0032   100   090   000    Old_age   Always       -       4295032844
190 Airflow_Temperature_Cel 0x0022   056   046   040    Old_age   Always       -       44 (Min/Max 35/54)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       194
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       924
194 Temperature_Celsius     0x0022   044   054   000    Old_age   Always       -       44 (0 22 0 0 0)
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       10
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       16842 (245 26 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       68351130361
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       47441722477
No Errors Logged
# 1  Extended offline    Completed without error       00%     16848         -
root@freenas:~ #
root@freenas:~ # smartctl -a /dev/da3
Serial Number:    ZDH1E7GD
LU WWN Device Id: 5 000c50 0a2caa646
Local Time is:    Fri Oct 18 18:01:07 2019 +08
See vendor-specific Attribute list for marginal Attributes.
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 634) minutes.
  1 Raw_Read_Error_Rate     0x000f   083   064   044    Pre-fail  Always       -       193439027
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       238
  7 Seek_Error_Rate         0x000f   088   060   045    Pre-fail  Always       -       594037128
  9 Power_On_Hours          0x0032   083   083   000    Old_age   Always       -       15607 (99 240 0)
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       239
190 Airflow_Temperature_Cel 0x0022   059   040   040    Old_age   Always   In_the_past 41 (Min/Max 33/51)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       191
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       423
194 Temperature_Celsius     0x0022   041   060   000    Old_age   Always       -       41 (0 22 0 0 0)
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       15592 (186 188 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       58283525612
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       29460162131
No Errors Logged
# 1  Extended offline    Completed without error       00%     15604         -
root@freenas:~ #
1kokies
smart scan for da4-da7
root@freenas:~ # smartctl -a /dev/da4
Serial Number:    ZDH1NGK4
LU WWN Device Id: 5 000c50 0a317875a
Local Time is:    Fri Oct 18 18:07:07 2019 +08
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 636) minutes.
  1 Raw_Read_Error_Rate     0x000f   076   064   044    Pre-fail  Always       -       38570718
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       234
  7 Seek_Error_Rate         0x000f   089   060   045    Pre-fail  Always       -       754316353
  9 Power_On_Hours          0x0032   083   083   000    Old_age   Always       -       15613 (74 180 0)
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       235
190 Airflow_Temperature_Cel 0x0022   063   040   040    Old_age   Always   In_the_past 37 (Min/Max 31/46)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       227
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       424
194 Temperature_Celsius     0x0022   037   060   000    Old_age   Always       -       37 (0 22 0 0 0)
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       15592 (158 248 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       60902870916
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       29207973635
No Errors Logged
# 1  Extended offline    Completed without error       00%     15611         -
root@freenas:~ #
root@freenas:~ # smartctl -a /dev/da5
Serial Number:    ZDH1NGQN
LU WWN Device Id: 5 000c50 0a3178b7d
Local Time is:    Fri Oct 18 18:11:46 2019 +08
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 643) minutes.
  1 Raw_Read_Error_Rate     0x000f   080   064   044    Pre-fail  Always       -       98585899
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       231
  7 Seek_Error_Rate         0x000f   088   060   045    Pre-fail  Always       -       654032983
  9 Power_On_Hours          0x0032   083   083   000    Old_age   Always       -       15606 (248 72 0)
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       232
190 Airflow_Temperature_Cel 0x0022   055   041   040    Old_age   Always       -       45 (Min/Max 35/56)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       185
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       414
194 Temperature_Celsius     0x0022   045   059   000    Old_age   Always       -       45 (0 22 0 0 0)
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       15587 (236 31 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       60909784332
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       27064090934
No Errors Logged
root@freenas:~ #
root@freenas:~ # smartctl -a /dev/da6
Serial Number:    ZDH1E73Y
LU WWN Device Id: 5 000c50 0a2ca86e0
Local Time is:    Fri Oct 18 18:12:40 2019 +08
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 642) minutes.
  1 Raw_Read_Error_Rate     0x000f   082   064   044    Pre-fail  Always       -       171196199
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       232
  7 Seek_Error_Rate         0x000f   088   060   045    Pre-fail  Always       -       592364782
  9 Power_On_Hours          0x0032   083   083   000    Old_age   Always       -       15594 (144 127 0)
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       1
190 Airflow_Temperature_Cel 0x0022   061   043   040    Old_age   Always       -       39 (Min/Max 32/49)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       215
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       431
194 Temperature_Celsius     0x0022   039   057   000    Old_age   Always       -       39 (0 21 0 0 0)
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       15577 (87 218 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       58260424356
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       27312759066
No Errors Logged
# 1  Extended offline    Completed without error       00%     15592         -
root@freenas:~ #
root@freenas:~ # smartctl -a /dev/da7
Serial Number:    ZDH1NJ64
LU WWN Device Id: 5 000c50 0a317467f
Local Time is:    Fri Oct 18 18:13:44 2019 +08
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 654) minutes.
  1 Raw_Read_Error_Rate     0x000f   076   064   044    Pre-fail  Always       -       38866261
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       269
  7 Seek_Error_Rate         0x000f   088   060   045    Pre-fail  Always       -       672135520
  9 Power_On_Hours          0x0032   083   083   000    Old_age   Always       -       15631 (85 4 0)
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       270
190 Airflow_Temperature_Cel 0x0022   060   048   040    Old_age   Always       -       40 (Min/Max 33/49)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       230
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       475
194 Temperature_Celsius     0x0022   040   052   000    Old_age   Always       -       40 (0 22 0 0 0)
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       15611 (60 10 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       60920103562
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       31355115592
No Errors Logged
# 1  Extended offline    Completed without error       00%     15629         -
root@freenas:~ #
Hmm, alright so it looks like two of your drives, at one point, had difficulty communicating with the controller. I can see this because the value for UDMA_CRC_Error_Count is > 0 for two drives. That value will typically not get reset; so it if doesn't continue to increate it is likely that while you moved your hardware around etc that it resolved itself.
Alright, I'm nearly ready to offer my idea for a solution. :) Before I do though, can you clarify whether you have the old and new SLOG SSDs inserted currently?
Also, could you give me the full output of zpool status? The copy-paste you did above was extremely helpful, could you do the same with this command? It will print info about all of your pools including, if it is recognized, the affected pool. Could you do the same with zpool import?
1kokies
:) great to hear from you
'idle hands in the devil's workshop' & i have done following so far
"REPAIR LOG 181019
HDA Raid card A
port0-da0, da2, da5 & da3
port1-da1, da4, da6 & da7
1. da0 & da2 appears to have UDMA & Command error. They are both on the same HBA raid card AND on the same
mini SAS 1 port to SATA 4 port cable. Replaced the cable port 0, to power up. All 15 disks detected but Pool unknown
2. Replace cable port 1, to power up, all disks present, Pool unknown
3. Swap HBA Raid to another pcie lane, all disks present, Pool unknown
4. Replace new HBA Raid card, all disks present, Pool unknown"
Hmm, all right so it looks like two of your drives, at one point, had difficulty communicating with the controller. I can see this because the value for UDMA_CRC_Error_Count is > 0 for two drives. That value will typically not get reset; so it if doesn't continue to increate it is likely that while you moved your hardware around etc that it resolved itself.
agreed, da0 and da2 are the disks.
all right, I'm nearly ready to offer my idea for a solution. :) Before I do though, can you clarify whether you have the old and new SLOG SSDs inserted currently?
yes both are always plugged in
glad you liked the copy-paste :)
root@freenas:~ # zpool status
  pool: Data-Media
 state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
        still be used, but some features are unavailable.
  scan: resilvered 56K in 0 days 00:00:02 with 0 errors on Thu Oct 17 00:17:09 2019
        Data-Media                                      ONLINE       0     0     0
          raidz1-0                                      ONLINE       0     0     0
            gptid/151f2837-e61d-11e7-a41a-086266295468  ONLINE       0     0     0
            gptid/bb0c2d26-e5db-11e7-b7ed-086266295468  ONLINE       0     0     0
            gptid/b70cb8cd-e4de-11e7-b58d-086266295468  ONLINE       0     0     0
            gptid/b84b6866-e4de-11e7-b58d-086266295468  ONLINE       0     0     0
errors: No known data errors
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0 days 00:00:12 with 0 errors on Wed Oct 16 03:45:12 2019
        freenas-boot  ONLINE       0     0     0
          da8p2     ONLINE       0     0     0
root@freenas:~ #
root@freenas:~ # zpool import
   pool: Data-Storage
  state: UNAVAIL
 status: One or more devices are missing from the system.
 action: The pool cannot be imported. Attach the missing
        devices and try again.
   see: http://illumos.org/msg/ZFS-8000-6X
        Data-Storage                                    UNAVAIL  missing device
          raidz2-0                                      ONLINE
            gptid/13105a29-c624-11e7-bbe0-086266295468  ONLINE
            gptid/1405e572-c624-11e7-bbe0-086266295468  ONLINE
            gptid/e3502be7-ec58-11e7-81f8-086266295468  ONLINE
            gptid/bfdede03-ed42-11e7-969f-086266295468  ONLINE
          raidz2-1                                      ONLINE
            gptid/367a9015-c625-11e7-bbe0-086266295468  ONLINE
            gptid/18a60acb-ecae-11e7-af1c-086266295468  ONLINE
            gptid/8cc6f7c5-ec2f-11e7-8da4-086266295468  ONLINE
            gptid/0544db8f-ece7-11e7-ad97-086266295468  ONLINE
        logs
          1100341364746838742                           UNAVAIL  corrupted data
        Additional devices are known to be part of this pool, though their
        exact configuration cannot be determined.
root@freenas:~ #
Hey @1kokies, thanks for the output. Very good news, I think. The reason your pool is hosed is just because of that darned log device. :) So, lets tell the system to stop using it! What happens if you do zpool remove Data-Storage 1100341364746838742? After that is the pool available and if so what is the output of zpool status Date-Storage? If not, go ahead and reboot. Is it available now? If so, what is the output of zpool status Data-Storage and if not what is the output of zpool import?
My bet is that whatever we do to solve the problem will require removing the SLOG device, which is what the above commands do. Once we get the pool imported again you'll be able to add the SLOG device back to your pool and use the good SLOG device.
1kokies
Hey @1kokies, thanks for the output. Very good news, I think. The reason your pool is hosed is just because of that darned log device. :) So, lets tell the system to stop using it! What happens if you do zpool remove Data-Storage 1100341364746838742? After that is the pool available? If not, go ahead and reboot. Is it available now? If so, what is the output of zpool status Data-Storage?
:) glad we could close the gap and agree on that slog thingy. We stop using it and no need to insert it back also. it's ok if the IO speed is slower, i will manage. But i am not very familiar with shell CLI ya so need a step by step guide, hope you are ok with it.
1. do a
and see if pool is available
2. If it is not available i will re boot and see if pool is available.
3. Then do
let's agree to remove and not add back any slog ya :)
  1. zpool remove Data-Storage 1100341364746838742
  2. If the pool is available
    1. zpool status Data-Storage
  3. If the pool is not available
    1. Reboot
    2. zpool status Data-Storage
  4. If the pool is STILL not available
    1. zpool import
At any point in the above if an error is encountered stop and report back.
Not necessarily. This is a long discussion though and worth having after we get your pool running again.
1kokies
OK did step #1 and returned following
   pool: Data-Storage
  state: UNAVAIL
          raidz2-0                                      ONLINE
          raidz2-1                                      ONLINE
        logs
root@freenas:~ #
root@freenas:~ #
root@freenas:~ #
root@freenas:~ #
root@freenas:~ # zpool remove Data-Storage 1100341364746838742
cannot open 'Data-Storage': no such pool
root@freenas:~ #
Alright, I expected as much. What I'd try at this point is to export your pool via the GUI, do NOT click destroy data. And then try to import it again via the GUI. Once you do that what is the output of both zpool status Data-Storage and zpool import?
1kokies
all right, I expected as much. What I'd try at this point is to export your pool via the GUI, do NOT click destroy data. And then try to import it again via the GUI. Once you do that what is the output of both zpool status Data-Storage and zpool import?
okok just to be extremely sure, i click on the box 'Confirm export/disconnect' only right ? screenshot attached
Correct.
1kokies
OK done the GUI export but when 'import an existing pool' there is no pool to import
Output zpool status Data-Storage & zpool import
root@freenas:~ # zpool status Data-Storage
   pool: Data-Storage
  state: UNAVAIL
          raidz2-0                                      ONLINE
          raidz2-1                                      ONLINE
        logs
root@freenas:~ #
1kokies
i have not re booted though
Alright, that isn't surprising. So, lets try to import it manually to fix it and then get it done through the GUI.
What happens if you type zpool import Data-Storage? If it works you need to try the zpool remove command from above to remove that SLOG device.
If that fails, what about the output of zpool import -F -n Data-Storage?
1kokies
output
root@freenas:~ # zpool import Data-Storage
The devices below are missing or corrupted, use '-m' to import the pool anyway:
            gptid/d3317a51-d4e1-11e7-8c89-086266295468 [log]
cannot import 'Data-Storage': one or more devices is currently unavailable
root@freenas:~ #
output, not sure what 'begin with a letter refers to'
root@freenas:~ # zpool remove 1100341364746838742
cannot open '1100341364746838742': name must begin with a letter
root@freenas:~ #
output=nothing happened, returns back to prompt
root@freenas:~ # zpool import -F -n Data-Storage
root@freenas:~ #
output of all 3 commands
root@freenas:~ #
root@freenas:~ #
root@freenas:~ #
Sorry, the remove command had a typo, you need to do zpool remove Data-Storage 1100341364746838742. I suspect that won't work either. How about zpool import -m Data-Storage? If that works, give me the output of zpool status Data-Storage
1kokies
sorry about typo :), the output
root@freenas:~ #
