Howard Swope
- Nov 19, 2015
I just upgraded from freenas from an earlier version 8 to 9.3.1. I am now seeing errors that I am having difficulty interpreting. I am seeing error reports from smartctrl and zpool. And it seems like my array switches from healthy to degraded every other day.
First the zpool status:
This looks to me like there is a problem with drive 0. And it looks like there is some type of corruption in two system files. But I am not sure what to do with this information.
smartctl output:
Just basic output shows passed across the board:
But looking at all information reveals errors on disk 0 and 3:
Disk 0:
Disk 3
Despite the fact that overall the drives show as PASSED, drive 0 and 3 are showing errors.
Any advice on how to proceed is appreciated.
[XXX] ~# zpool status -x -v
pool: volume0
state: ONLINE
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: http://illumos.org/msg/ZFS-8000-8A
scan: scrub repaired 20.1M in 9h7m with 155 errors on Thu Nov 19 18:07:18 2015
NAME STATE READ WRITE CKSUM
volume0 ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/a653dc0f-8853-11e2-8909-002590a8e414 ONLINE 0 0 1
gptid/a6be6a5f-8853-11e2-8909-002590a8e414 ONLINE 0 0 0
gptid/a729e2c2-8853-11e2-8909-002590a8e414 ONLINE 0 0 0
gptid/a78f764d-8853-11e2-8909-002590a8e414 ONLINE 0 0 0
/var/db/system/cores/syslog-ng.core
/var/db/system/syslog-567b59bd58814d6ebad2ebdfdfba568a/log/telemetry.json.bz2
smartctl output:
[XXX] ~# smartctl -H /dev/ada0 smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p28 amd64] (local build) Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED [XXX] ~# smartctl -H /dev/ada1 smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p28 amd64] (local build) Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED [XXX] ~# smartctl -H /dev/ada2 smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p28 amd64] (local build) Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED [XXX] ~# smartctl -H /dev/ada3 smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p28 amd64] (local build) Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED
Disk 0:
[XXX] ~# smartctl -a /dev/ada0
Model Family: Seagate Barracuda 7200.14 (AF)
Device Model: ST3000DM001-9YN166
Serial Number: W1F18JE7
LU WWN Device Id: 5 000c50 053880e63
Firmware Version: CC4B
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 7200 rpm
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Fri Nov 20 04:54:56 2015 EST
==> WARNING: A firmware update for this drive may be available,
see the following Seagate web pages:
http://knowledge.seagate.com/articles/en_US/FAQ/207931en
http://knowledge.seagate.com/articles/en_US/FAQ/223651en
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Self-test execution status: ( 241) Self-test routine in progress...
10% of test remaining.
data collection: ( 584) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 342) minutes.
Conveyance self-test routine
SCT capabilities: (0x3085) SCT Status supported.
1 Raw_Read_Error_Rate 0x000f 097 097 006 Pre-fail Always - 87436760
3 Spin_Up_Time 0x0003 093 092 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 45
5 Reallocated_Sector_Ct 0x0033 051 051 036 Pre-fail Always - 64736
7 Seek_Error_Rate 0x000f 064 060 030 Pre-fail Always - 2965858
9 Power_On_Hours 0x0032 074 074 000 Old_age Always - 23562
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 45
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 094 083 000 Old_age Always - 188 188 188
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 067 058 045 Old_age Always - 33 (Min/Max 28/34)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 39
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 98
194 Temperature_Celsius 0x0022 033 042 000 Old_age Always - 33 (0 15 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 23562h+42m+12.795s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 1987424826513
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 14117367880170
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Self-test routine in progress 10% 23562 -
# 2 Short offline Completed without error 00% 23558 -
# 3 Short offline Interrupted (host reset) 10% 23557 -
# 4 Short offline Completed: read failure 10% 23533 505182249
# 5 Short offline Completed without error 00% 23509 -
# 6 Short offline Completed without error 00% 23485 -
# 7 Short offline Interrupted (host reset) 10% 23462 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Disk 3
[XXX] ~# smartctl -a /dev/ada3
Serial Number: W1F1ADE8
LU WWN Device Id: 5 000c50 053872c9f
Local Time is: Fri Nov 20 05:01:54 2015 EST
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed.
data collection: ( 575) seconds.
command.
power-saving mode.
recommended polling time: ( 341) minutes.
1 Raw_Read_Error_Rate 0x000f 087 077 006 Pre-fail Always - 235749051
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 48
5 Reallocated_Sector_Ct 0x0033 053 052 036 Pre-fail Always - 62032
7 Seek_Error_Rate 0x000f 064 060 030 Pre-fail Always - 3000421
9 Power_On_Hours 0x0032 074 074 000 Old_age Always - 23565
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 48
187 Reported_Uncorrect 0x0032 001 001 000 Old_age Always - 3054
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 1 1 1
190 Airflow_Temperature_Cel 0x0022 072 062 045 Old_age Always - 28 (Min/Max 24/30)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 43
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 99
194 Temperature_Celsius 0x0022 028 040 000 Old_age Always - 28 (0 14 0 0 0)
197 Current_Pending_Sector 0x0012 084 084 000 Old_age Always - 2704
198 Offline_Uncorrectable 0x0010 084 084 000 Old_age Offline - 2704
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 23565h+20m+39.111s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 2071987855371
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 8952376693249
ATA Error Count: 3040 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 3040 occurred at disk power-on lifetime: 23565 hours (981 days + 21 hours)
ER ST SC SN CL CH DH
40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 00 50 ff ff ff 4f 00 39d+23:22:51.211 READ FPDMA QUEUED
b0 d5 01 00 4f c2 40 00 39d+23:22:51.210 SMART READ LOG
2f 00 01 10 00 00 00 00 39d+23:22:51.095 READ LOG EXT
60 00 50 ff ff ff 4f 00 39d+23:22:47.959 READ FPDMA QUEUED
b0 da 00 00 4f c2 40 00 39d+23:22:47.724 SMART RETURN STATUS
Error 3039 occurred at disk power-on lifetime: 23565 hours (981 days + 21 hours)
2f 00 01 10 00 00 00 00 39d+23:22:47.602 READ LOG EXT
60 00 50 ff ff ff 4f 00 39d+23:22:45.059 READ FPDMA QUEUED
35 00 08 ff ff ff 4f 00 39d+23:22:45.059 WRITE DMA EXT
Error 3038 occurred at disk power-on lifetime: 23565 hours (981 days + 21 hours)
b0 d1 01 01 4f c2 40 00 39d+23:22:45.051 SMART READ ATTRIBUTE THRESHOLDS [OBS-4]
25 00 00 ff ff ff 4f 00 39d+23:22:40.668 READ DMA EXT
b0 d0 01 00 4f c2 40 00 39d+23:22:40.393 SMART READ DATA
Error 3037 occurred at disk power-on lifetime: 23565 hours (981 days + 21 hours)
25 00 00 ff ff ff 4f 00 39d+23:22:37.786 READ DMA EXT
ec 00 01 00 00 00 40 00 39d+23:22:37.778 IDENTIFY DEVICE
25 00 00 ff ff ff 4f 00 39d+23:22:33.977 READ DMA EXT
Error 3036 occurred at disk power-on lifetime: 23565 hours (981 days + 21 hours)
25 00 00 ff ff ff 4f 00 39d+23:22:27.818 READ DMA EXT
25 00 00 ff ff ff 4f 00 39d+23:22:24.033 READ DMA EXT
# 1 Short offline Completed: read failure 90% 23561 340012704
# 2 Short offline Completed: read failure 90% 23559 340468640
# 3 Short offline Completed: read failure 90% 23536 339926120
# 4 Short offline Completed: read failure 10% 23512 506323470
# 5 Short offline Completed: read failure 90% 23488 340468576
# 6 Short offline Completed: read failure 10% 23465 340467664
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
