ahci timeout, ATA status errors on all disks
mammothman
I just recently set up this system. Some of the specs are attached in the printout below. I am using a Fatal1ty H270 Performance board with the latest firmware. Any help is greatly appreciated as I have been at this for a while and my wife is starting to get mad :D.
Issue:
When I start copying files to the san, it starts copying the files and then after about 20 seconds I start getting the following type of errors and usually by copy speed eventually drops to 0 and it hangs my windows pc that I am using to copy the files. Also have a hard time getting smartctl commands when the errors start.
Trouble shooting I have done:
-ran smart tests that passed
-swapped sata cable on all drives
-changed uefi drive setting from ahci to raid
-moved some drives to different sata power on different cable
-reinstalled freenas and pool from scratch
-tried disconnecting one drive at a time
FreeBSD 11.2-STABLE #0 r325575+97f4f541349(freenas/11.2-stable): Wed Oct 17 18:06:49 EDT 2018
	root@nemesis.tn.ixsystems.com:/freenas-11.2-releng/freenas/_BE/objs/freenas-11.2-releng/freenas/_BE/os/sys/FreeNAS.amd64 amd64
FreeBSD clang version 6.0.0 (tags/RELEASE_600/final 326565) (based on LLVM 6.0.0)
VT(efifb): resolution 1920x1080
CPU: Intel(R) Core(TM) i5-7500 CPU @ 3.40GHz (3408.17-MHz K8-class CPU)
  Origin="GenuineIntel"  Id=0x906e9  Family=0x6  Model=0x9e  Stepping=9
  Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE>
  Features2=0x7ffafbff<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,SDBG,FMA,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,x2APIC,MOVBE,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX,F16C,RDRAND>
  AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM>
  AMD Features2=0x121<LAHF,ABM,Prefetch>
  Structured Extended Features=0x29c6fbf<FSGSBASE,TSCADJ,SGX,BMI1,HLE,AVX2,SMEP,BMI2,ERMS,INVPCID,RTM,NFPUSG,MPX,RDSEED,ADX,SMAP,CLFLUSHOPT,PROCTRACE>
  Structured Extended Features3=0xc000000<IBPB,STIBP>
  XSAVE Features=0xf<XSAVEOPT,XSAVEC,XINUSE,XSAVES>
  VT-x: PAT,HLT,MTF,PAUSE,EPT,UG,VPID
  TSC: P-state invariant, performance statistics
real memory  = 8589934592 (8192 MB)
avail memory = 7918084096 (7551 MB)
Event timer "LAPIC" quality 600
ACPI APIC Table: <ALASKA A M I >
FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
FreeBSD/SMP: 1 package(s) x 4 core(s)
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ioapic0 <Version 2.0> irqs 0-119 on motherboard
root@freenas[~]# smartctl -a /dev/ada0
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:	 Western Digital Black
Device Model:	 WDC WD2003FZEX-00SRLA0
Serial Number:	WD-WMC6N0MA8C43
LU WWN Device Id: 5 0014ee 0af39a89f
Firmware Version: 01.01A01
User Capacity:	2,000,398,934,016 bytes [2.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	7200 rpm
Form Factor:	  3.5 inches
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Mon Nov 19 01:14:56 2018 PST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
										was never started.
Self-test execution status:	  (   0) The previous self-test routine completed
										been run.
data collection:				(	0) seconds.
capabilities:					(0x7b) SMART execute Offline immediate.
										command.
										Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
										power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:		(   2) minutes.
Extended self-test routine
recommended polling time:		( 205) minutes.
Conveyance self-test routine
recommended polling time:		(   5) minutes.
SCT capabilities:			  (0x203d) SCT Status supported.
										SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   0
  3 Spin_Up_Time			0x0027   213   183   021	Pre-fail  Always	   -	   2325
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   35
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x002e   100   253   000	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   100   100   000	Old_age   Always	   -	   34
 10 Spin_Retry_Count		0x0032   100   253   000	Old_age   Always	   -	   0
 11 Calibration_Retry_Count 0x0032   100   253   000	Old_age   Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   35
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   31
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   3
194 Temperature_Celsius	 0x0022   111   110   000	Old_age   Always	   -	   36
196 Reallocated_Event_Count 0x0032   200   200   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0030   100   253   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   0
200 Multi_Zone_Error_Rate   0x0008   100   253   000	Old_age   Offline	  -	   0
SMART Error Log Version: 1
ATA Error Count: 60 (device log contains only the most recent five errors)
		CR = Command Register [HEX]
		FR = Features Register [HEX]
		ER = Error register [HEX]
		ST = Status register [HEX]
Error 60 occurred at disk power-on lifetime: 33 hours (1 days + 9 hours)
  When the command that caused the error occurred, the device was in an unknown state.
  ER ST SC SN CL CH DH
  04 51 00 00 00 00 00  Error: ABRT
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
Error 59 occurred at disk power-on lifetime: 32 hours (1 days + 8 hours)
  04 51 00 00 00 00 40  Error: ABRT
Error 58 occurred at disk power-on lifetime: 26 hours (1 days + 2 hours)
Error 57 occurred at disk power-on lifetime: 26 hours (1 days + 2 hours)
Error 56 occurred at disk power-on lifetime: 26 hours (1 days + 2 hours)
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline	Completed without error	   00%		23		 -
# 2  Short offline	   Completed without error	   00%		20		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
root@freenas[~]# smartctl -a /dev/ada1
Serial Number:	WD-WMC6N0M6PA0Z
LU WWN Device Id: 5 0014ee 059e3f260
Local Time is:	Mon Nov 19 01:15:38 2018 PST
										was never started.
										been run.
										command.
										power-saving mode.
recommended polling time:		( 210) minutes.
194 Temperature_Celsius	 0x0022   112   111   000	Old_age   Always	   -	   35
ATA Error Count: 47 (device log contains only the most recent five errors)
Error 47 occurred at disk power-on lifetime: 34 hours (1 days + 10 hours)
  b0 da 00 00 4f c2 40 08	  00:53:17.198  SMART RETURN STATUS
  ea 00 00 00 00 00 40 08	  00:53:17.198  FLUSH CACHE EXT
  61 00 f8 b8 be 4c 40 08	  00:53:13.542  WRITE FPDMA QUEUED
  61 00 f0 b8 bd 4c 40 08	  00:53:13.542  WRITE FPDMA QUEUED
  61 00 e8 b8 bc 4c 40 08	  00:53:13.542  WRITE FPDMA QUEUED
Error 46 occurred at disk power-on lifetime: 34 hours (1 days + 10 hours)
  b0 da 00 00 4f c2 40 08	  00:48:11.255  SMART RETURN STATUS
  ea 00 00 00 00 00 40 08	  00:48:11.255  FLUSH CACHE EXT
  61 00 38 b8 7e 4c 40 08	  00:48:07.228  WRITE FPDMA QUEUED
  61 00 30 b8 7d 4c 40 08	  00:48:07.228  WRITE FPDMA QUEUED
  61 00 28 b8 7c 4c 40 08	  00:48:07.228  WRITE FPDMA QUEUED
Error 45 occurred at disk power-on lifetime: 34 hours (1 days + 10 hours)
Error 44 occurred at disk power-on lifetime: 34 hours (1 days + 10 hours)
Error 43 occurred at disk power-on lifetime: 34 hours (1 days + 10 hours)
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
root@freenas[~]# smartctl -a /dev/ada2
Serial Number:	WD-WMC6N0M48PZF
LU WWN Device Id: 5 0014ee 0af39a8f4
Local Time is:	Mon Nov 19 01:16:27 2018 PST
SMART Status command failed: Input/output error
Warning: This result is based on an Attribute check.
										was never started.
										been run.
										command.
										power-saving mode.
recommended polling time:		( 208) minutes.
  3 Spin_Up_Time			0x0027   214   183   021	Pre-fail  Always	   -	   2300
  9 Power_On_Hours		  0x0032   100   100   000	Old_age   Always	   -	   35
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   6
194 Temperature_Celsius	 0x0022   111   111   000	Old_age   Always	   -	   36
ATA Error Count: 149 (device log contains only the most recent five errors)
Error 149 occurred at disk power-on lifetime: 35 hours (1 days + 11 hours)
  b0 da 00 00 4f c2 40 08	  00:13:53.704  SMART RETURN STATUS
  ea 00 00 00 00 00 40 08	  00:13:53.704  FLUSH CACHE EXT
  61 00 d8 f0 4d 4b 40 08	  00:13:47.570  WRITE FPDMA QUEUED
  61 00 d0 f0 4c 4b 40 08	  00:13:47.570  WRITE FPDMA QUEUED
  61 00 c8 f0 4b 4b 40 08	  00:13:47.570  WRITE FPDMA QUEUED
Error 148 occurred at disk power-on lifetime: 35 hours (1 days + 11 hours)
Error 147 occurred at disk power-on lifetime: 35 hours (1 days + 11 hours)
Error 146 occurred at disk power-on lifetime: 35 hours (1 days + 11 hours)
Error 145 occurred at disk power-on lifetime: 35 hours (1 days + 11 hours)
# 3  Short offline	   Completed without error	   00%		20		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
This will not have been helpful. Did you set it back?
You are running with the minimum required RAM. Are you doing anything like L2ARC with an SSD (that would be very bad if you were).
You haven't given us a great look at your hardware setup, but I see the WD blacks in the SMART reports... these are not good disks for a NAS.
Perhaps it would also be useful to see the output of zpool status after you have done the pool setup.
mammothman
Yup I changed it back to AHCI. I am not doing anything that is not the default config so no L2ARC. I do have more memory and another power supply I can use if you think this may be a good troubleshooting step. Is there a command I can use to display all the hardware info?
Here is the output from zpool status
 pool: freenas-boot
 state: ONLINE
  scan: none requested
		NAME		STATE	 READ WRITE CKSUM
		freenas-boot  ONLINE	   0	 0	 0
		  mirror-0  ONLINE	   0	 0	 0
			da0p2   ONLINE	   0	 0	 0
			da1p2   ONLINE	   0	 0	 0
errors: No known data errors
  pool: freenaspool
 state: ONLINE
  scan: resilvered 392M in 0 days 00:00:07 with 0 errors on Mon Nov 19 01:48:00 2018
		freenaspool									 ONLINE	   0	 0	 0
		  raidz1-0									  ONLINE	   0	 0	 0
			gptid/8218916c-ebd3-11e8-9fa8-7085c230ca40  ONLINE	   0	 0	 0
			gptid/8587d9b2-ebd3-11e8-9fa8-7085c230ca40  ONLINE	   0	 0	 0
			gptid/86d97eb8-ebd3-11e8-9fa8-7085c230ca40  ONLINE	   0	 0	 0
mammothman
Sovafter no help on here and wasting way too much time on this including trying different memory, system board, processor, sata cables, the only thing left was the hard drives or software. Went to from version 11.2 to 11.1 and voila. Problem fixed. Stable release my ass. You've been warned.
siberian
I've exactly the same problem (same logs, same smart errors), but it started with 11.1 and it's even worse with 11.2.
- HP MicroServer Gen10, 8GB Ram, quad core Opteron X3000
- 4 disks WD2002FFSX (Western Digital Red Pro 2T)
All smart tests on HD passed without any error, all disks replaced by the vendor, MB replaced by HPE, power supply replaced, memtests passed without errors, and I even tried every possible configuration in the bios. I tried also to mess up with tunables (hint.ahci.*) as suggested in other forums for similar issues: no luck at all.
Right now, as it was impossible to make it work properly with FreeNAS, it's serving as iSCSI target with CentOS7 for a small virtualization infrastructure and everything is fine (obviously without all the advantages of FreeNAS and ZFS), so I doubt that it could be just an hardware related issue.
Any idea?
Thank you.
