Hi All,
I'm new in FreeNAS.
I catch a problem with my Seagate 3Tb disks. So, I have 2 massive first with 2 Saegate 2Tbx2 disks and second with Seagate 3TBx2 disks. All 3Tb disk marked as end_of_life. I've replace these to another server and recheck with BIOS, Raid Controller BIOS and Seagate tools - All tools show me that disks has good state. But FreeNAS all time marked there as end_of_life.
So, How can I resolve this problem? Which tools I must trust?
PS: At the moment I've started long self-test. After continue I'll post results.
Kind Regards
I'm new in FreeNAS.
[root@HFPHFNL001] ~# smartctl -H /dev/ada1 smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p26 amd64] (local build) Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED Please note the following marginal Attributes: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 184 End-to-End_Error 0x0032 099 099 099 Old_age Always FAILING_NOW 1
[root@HFPHFNL001] ~# smartctl -a /dev/ada1
Model Family: Seagate Barracuda 7200.14 (AF)
Device Model: ST3000DM001-1CH166
Serial Number: W1F3FYE5
LU WWN Device Id: 5 000c50 06a3ab655
Firmware Version: CC27
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Thu Oct 29 00:08:08 2015 MSK
SMART support is: Enabled
See vendor-specific Attribute list for marginal Attributes.
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 584) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 336) minutes.
Conveyance self-test routine
SCT capabilities: (0x3085) SCT Status supported.
1 Raw_Read_Error_Rate 0x000f 119 099 006 Pre-fail Always - 218351032
3 Spin_Up_Time 0x0003 094 094 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 229
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 8
7 Seek_Error_Rate 0x000f 072 060 030 Pre-fail Always - 12938741892
9 Power_On_Hours 0x0032 097 097 000 Old_age Always - 3226
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 99
183 Runtime_Bad_Block 0x0032 094 094 000 Old_age Always - 6
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 099 000 Old_age Always - 1 9 16
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 066 051 045 Old_age Always - 34 (Min/Max 34/35)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 226
193 Load_Cycle_Count 0x0032 097 097 000 Old_age Always - 7785
194 Temperature_Celsius 0x0022 034 049 000 Old_age Always - 34 (0 16 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 187 000 Old_age Always - 92
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 2129h+12m+23.358s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 6568419503
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 71675417910
SMART Error Log Version: 1
ATA Error Count: 16 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 16 occurred at disk power-on lifetime: 1495 hours (62 days + 7 hours)
ER ST SC SN CL CH DH
40 51 00 9f a8 46 00 Error: UNC at LBA = 0x0046a89f = 4630687
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
42 00 00 9f a8 46 40 00 00:01:49.056 READ VERIFY SECTOR(S) EXT
42 00 01 9e a8 46 40 00 00:01:48.659 READ VERIFY SECTOR(S) EXT
61 00 01 9e a8 46 40 00 00:01:48.659 WRITE FPDMA QUEUED
42 00 00 9e a8 46 40 00 00:01:48.322 READ VERIFY SECTOR(S) EXT
42 00 01 9d a8 46 40 00 00:01:47.919 READ VERIFY SECTOR(S) EXT
Error 15 occurred at disk power-on lifetime: 1495 hours (62 days + 7 hours)
Error 14 occurred at disk power-on lifetime: 1495 hours (62 days + 7 hours)
40 51 00 9e a8 46 00 Error: UNC at LBA = 0x0046a89e = 4630686
61 00 01 9d a8 46 40 00 00:01:47.918 WRITE FPDMA QUEUED
42 00 00 9d a8 46 40 00 00:01:47.589 READ VERIFY SECTOR(S) EXT
42 00 01 9c a8 46 40 00 00:01:47.182 READ VERIFY SECTOR(S) EXT
Error 13 occurred at disk power-on lifetime: 1495 hours (62 days + 7 hours)
Error 12 occurred at disk power-on lifetime: 1495 hours (62 days + 7 hours)
40 51 00 9d a8 46 00 Error: UNC at LBA = 0x0046a89d = 4630685
61 00 01 9c a8 46 40 00 00:01:47.182 WRITE FPDMA QUEUED
42 00 00 9c a8 46 40 00 00:01:46.855 READ VERIFY SECTOR(S) EXT
42 00 01 9b a8 46 40 00 00:01:46.454 READ VERIFY SECTOR(S) EXT
# 1 Short offline Completed without error 00% 3225 -
# 2 Extended offline Aborted by host 90% 3225 -
# 3 Extended offline Aborted by host 90% 3225 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Kind Regards
