Need HELP (Bad speed with 10Gb network card in TrueNAS 12)
Njanja
Hey all.
I recently bought a new server and installed the latest version of TrueNAS.
Installation went smoothly. When I tried to set fixed ip and set vlan and lan,
everything stopped working. The only way to get started is to reset the network settings.
I have a Supermicros server with 8 network ports (4 ports 1Gb and 4 ports 10Gb).
When it comes to router, switch 1Gb and switch 10 GB everything is Unifi equipment.
I am looking for this solution:
1 port 1Gb should be used for menage.
3 port 10Gb use for link aggregation, iscsi and smb storage.
I prefer that they are not on the same network. Then I wonder how should I set the NAS.
Should I run link aggregation, should I run VLAN or LAN?
It should be good if there is a good guide on how to set everything.
Personally, I think TrueNA's guides suck. I need examples.
Before I uppdated to TrueNAS 12.
with kind regards
Njanja
Kris Moore
SVP of Engineering
Administrator
Can you get is screenshots / examples of the config you are trying to apply before it "stops working"? We need to understand that to determine if this is a bug or an issue with the config being applied not working on 12.0 specifically.
Njanja
Hi
I start with VLANS in my router.
Only network that works is 10.101.105.15, (It is lan2 my menage)
when I try to ping other vlans, nothing works.
If you need more pictures of settings I can send.
The only problem I have, is setting fixed ip and configuring vlans, bridgs.
Tried link aggregation with 3 10Gb ports, works, but extremely poor.
