BUILD NAS Build for a first-timer
horizon
Hello there,
after a little research I've put together a FreeNAS rig.
I will be using this machine to back up my Workstation, my 2 Laptops and to store my music and video files.
The server should be able to render FullHD movies using DLNA software like Plex or Serviio.
And lastly I will install a download manager on it to run over night when I'm not using my connection.
*updated
http://de.pcpartpicker.com/p/TNtQnQ
Supermicro X10SLH-F
Intel Xeon E3-1230v3 3.3GHz
Samsung ECC Unbuffered DDR3-1600 8GB x 2
SeaSonic 360 Watt Gold
Western Digital Red 3TB 3.5" 5400RPM x 6
Fractal Design Define R4
Total price is about 1600€.
The motherboard has everything I need, enough SATA ports, onboard USB, IPMI, ECC Unbuffered, Intel LAN.
The Xeon E3 is powerful enough to encode 1080p content.
The RAM is compatible with the board, 16 gigs is plenty and I could upgrade to 32.
I'm not fully settled wether to use 2TB or 3TB drives but I will use RaidZ2.
I have decided to use RaidZ2 over RaidZ1 since the latter is not safe enough for me.
With 2TB drives I would get a total 8000GB and with 3TB drives I'd get 12000GB.
Not sure with the case but I've used it before and I really like it, the Node 304 doesn't have good airflow imho.
Lastly I will connect the server to an UPS to ensure proper shutdown incase of a blackout.
Is this rig powerful enough to do backups, encode FullHD and run a download manager?
Are 6 drives into one Raid Z2 raid kinda safe?
Thank you
BigDave
FreeNAS Enthusiast
Your board is socket 1155, your CPU is socket 1150 (haswell).
Just pick out a supermicro X10 board or buy instead a E3-1230 V2 for the X9 board.
Other than that your choices are top shelf!!!
BigDave
FreeNAS Enthusiast
BigDave
FreeNAS Enthusiast
Ive seen the E3 1231 V3 CPU cost the same as the 1230 here in the US and it's 100MHz faster if you go with X10 board
horizon
Thanks for that, too. This rig should be powerful enough for my needs, right?
BigDave
FreeNAS Enthusiast
Oh my, yes!
marbus90
I'd drop down to a X10SLL-F X10SLL+-F X10SLM-F or X10SLM+-F. SATA speed and NICs make no difference.
Well, X10 boards with matched NICs are very slightly less prone to weird networking issues (probably hardware defects of some kind that are more prevalent on the X10SLL-F/X10SLM-F). Not that I'd worry about it, but since you were thinking of getting the most expensive model, might as well get at least an X10SLL+-F.
