Mystery disk
krikboh
In my system I have six WD Red's for a RAIDZ2 pool and one SATADOM as a boot device. As you can see in the attached Disk View and camcontrol devlist there is another disk listed as Generic 6000 at da6. If I watch the console during a reboot I see a message with failed to connect to da6. I don't know where this disk came from, there is definitely no additional disk in the system, and don't believe it was listed before upgrading to 9.3. Can I safely delete it from the disks?
For those reading this on phones and can't see my signature:
Supermicro X10SLH-F; Xeon E3-1230v3; 4 x 8 GB ECC RAM; RAIDZ2: 6x3TB WD RED
Lian Li PC-V354; IBM Serveraid M1015; Supermicro 16 GB SATA DOM; FreeNAS 9.3;
Asus RT-AC66R; Cisco SG200-08; APC SmartUPS C1000
BigDave
FreeNAS Enthusiast
Would this not be your "disk" on modual? Don't delete it until you know for sure.
krikboh
The SATADOM is ada0.
BigDave
FreeNAS Enthusiast
The camcontrol shows it as da6 because it's plugged in to a SATA port, the system
shows it as ada0 picked up as boot drive?
Is the M1015 crossflashed to IT mode?
krikboh
Yep IT mode firmware v16.
krikboh
Still unsure if I can delete this disk....
Honestly, I have no idea.
I'd definitely back everything up tightly before trying to remove it.
