My power just went out....
Christopher Ward
what a bad time for a power cut, i was in the process of replacing a 3tb drive with a 4tb, it had only just started.
checking zpool status still shows resilver in progress, should i be worried?
[root@MEDIASERVER ~]# zpool status
  pool: RaidZ2
 state: ONLINE
status: One or more devices is currently being resilvered.  The pool will
		continue to function, possibly in a degraded state.
action: Wait for the resilver to complete.
  scan: resilver in progress since Tue Dec 26 14:43:07 2017
		1.84T scanned out of 22.9T at 401M/s, 15h19m to go
		179G resilvered, 8.01% done
		NAME											STATE	 READ WRITE CKSUM
		RaidZ2										  ONLINE	   0	 0	 0
		  raidz2-0									  ONLINE	   0	 0	 0
			gptid/2640e9fe-7811-11e5-bb3e-0cc47a6ae76e  ONLINE	   0	 0	 0
			gptid/853133de-a5d6-11e6-84d5-0cc47a6ae76e  ONLINE	   0	 0	 0
			gptid/7ec2f55d-df6a-11e6-a9c0-0cc47a6ae76e  ONLINE	   0	 0	 0
			gptid/71add977-fb4a-11e6-8374-0cc47a6ae76e  ONLINE	   0	 0	 0
			gptid/b76b8cd3-e1b4-11e6-98a3-0cc47a6ae76e  ONLINE	   0	 0	 0
			gptid/d2d515de-0f39-11e7-b8b1-0cc47a6ae76e  ONLINE	   0	 0	 0
			gptid/df4ec194-fe7a-11e6-be9d-0cc47a6ae76e  ONLINE	   0	 0	 0
			gptid/291ed957-7811-11e5-bb3e-0cc47a6ae76e  ONLINE	   0	 0	 0
			gptid/0d7329d5-ea4b-11e7-b159-0cc47a6ae76e  ONLINE	   0	 0	 0  (resilvering)
			gptid/29e70777-7811-11e5-bb3e-0cc47a6ae76e  ONLINE	   0	 0	 0
errors: No known data errors
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0h4m with 0 errors on Tue Nov 21 03:49:39 2017
		freenas-boot								  ONLINE	   0	 0	 0
		  gptid/a501240c-7803-11e5-8b89-0cc47a6ae76e  ONLINE	   0	 0	 0
EDIT: second power cut while it was resilvering again
Jailer
Not strong, but bad
Good lord get a UPS! Let it finish and see what the output of the scrub is.
scrappy
Do a scrub after resilvering is complete. Doubt anything bad happened.
scrappy
rs225
Any problem with the resilver is unlikely, since it is going to actually back up and redo some of the resilver when it restarts.
Arwen
Uh, guys, ZFS was designed WITHOUT the need for a UPS. (Of course, a UPS is very nice to have for the home, and necessary for office environments in my opinion.)
Remember, ZFS is a copy on write file system. So it updates data, file attributes, directorys, and file system configurations into free, empty space. Then, when completely written, updates something called an Uber block. Each disk has them, (well, probably 2 sets, beginning of disk and end). These describe the latest state of the ZFS pool at the time it was last written to. So if a write was in-complete, then old data is still good. And a re-silver will simply resume where it left off.
The designers of ZFS tested some of the concepts, like Uber blocks, by using power fails.
rs225
Just make sure your controller and disks are respecting cache flushes. If they don't, then you get to restore from your well kept backups.
