nemisisak
- Jun 19, 2015
Had a disk failure so no big deal and started a resilver with a fresh disk. I noticed subsequently that I ended up in a resilvering loop and once completed, the resilver would occur again. Another disk was throwing up write and checksum errors. So I replaced that and then my pool went offline.
I reinserted the disk I had just taken out (which was throwing up errors) and pool returned in degraded state with a couple of disks unavailable. Then while starting to troubleshoot another disk was removed by the system and now my pool is unavilable however, it is resilvering, though with 3 disks down my pool should be dead?
Im a little bit lost now on the best way to proceed to resolving the issue. The resilver is not really doing anything and im likely to be dead if it ever completes.
zpool status -v output below shows status and data errors
pool: AllDiskVolume
state: UNAVAIL
status: One or more devices is currently being resilvered. The pool will
continue to function, possibly in a degraded state.
action: Wait for the resilver to complete.
scan: resilver in progress since Sat Jan 30 10:44:53 2021
1.84T scanned at 512M/s, 201M issued at 54.6K/s, 26.4T total
0 resilvered, 0.00% done, no estimated completion time
NAME STATE READ WRITE CKSUM
AllDiskVolume UNAVAIL 1 0 0
raidz2-0 UNAVAIL 2 0 0
gptid/97d632a5-c1b7-11e5-86a6-d050995bee6c ONLINE 0 0 0
3071377810018719211 UNAVAIL 0 0 0 was /dev/gptid/98968966-c1b7-11e5-86a6-d050995bee6c
17494332646787331714 UNAVAIL 0 0 0 was /dev/gptid/9951a8ad-601c-11eb-a9be-d050995bee6c
gptid/9a46ed13-c1b7-11e5-86a6-d050995bee6c ONLINE 0 0 0
gptid/62251196-d9de-11e6-8f47-d050995bee6c ONLINE 0 0 0
16332921663242939337 REMOVED 0 0 0 was /dev/gptid/9c778901-c1b7-11e5-86a6-d050995bee6c
gptid/89295a56-1d10-11e7-809c-d050995bee6c ONLINE 0 0 0
gptid/9e0820a8-c1b7-11e5-86a6-d050995bee6c ONLINE 0 0 0
gptid/9ec371f0-c1b7-11e5-86a6-d050995bee6c ONLINE 0 0 0
gptid/9f7f41f2-c1b7-11e5-86a6-d050995bee6c ONLINE 0 0 0
<metadata>:<0x0>
<metadata>:<0x1>
<metadata>:<0x114>
<metadata>:<0x4d>
<metadata>:<0x50>
<metadata>:<0x260>
<metadata>:<0x6b>
<metadata>:<0x185>
<metadata>:<0x290>
<metadata>:<0xa1>
<metadata>:<0xc6>
<metadata>:<0xc8>
<metadata>:<0xd5>
<metadata>:<0xed>
<metadata>:<0x1f5>
<metadata>:<0x1fc>
AllDiskVolume/iocage/releases/11.3-RELEASE/root:<0x0>
AllDiskVolume/iocage/releases/11.3-RELEASE/root:<0x2b6>
AllDiskVolume/MShare:<0x11db>
AllDiskVolume/.system/rrd-c0708eef149b49a396f66530a6f1b80a:<0xf1>
AllDiskVolume/iocage/jails/MinecraftS/root:<0x2460a>
pool: freenas-boot
state: ONLINE
scan: scrub repaired 0 in 0 days 00:00:46 with 0 errors on Sat Jan 30 03:45:46 2021
freenas-boot ONLINE 0 0 0
da0p2 ONLINE 0 0 0
errors: No known data errors
